 Can I OC my E6300 using stock fan and heatsink?
TSCanopies
post Nov 16 2006, 05:41 PM, updated 20y ago
Hey just as above the title..
pls tell me...
can I still OC if using stock Fans and heatsink????
mruzian
post Nov 16 2006, 05:46 PM
Androidify
of course u can!!!!
but there is a high probabilty ur proc will burned
by using a good HSF
This post has been edited by mruzian: Nov 16 2006, 05:47 PM
kenzo
post Nov 16 2006, 05:53 PM
not advisable to do so....even if u could...how high can u go...no difference wan like that...
TSCanopies
post Nov 16 2006, 05:55 PM
Oic...so that means OC processor nid buy good fan la?
wat means HSF?????
and If wanna OC GC...should I buy another Fans???
Can OC ram or not???
btw..anyone can show me what fans should i buy??
LittleLinnet
post Nov 16 2006, 06:03 PM
Iophobia
Buying a better heatsink or fan is to boost your overclock and maintain your hardware life
You sure can overclock using stock cooler, but the temperature will be limiting your overclock
HSF = heatsink fan
Rams sure can be overclocked
your budget ?
Btw, continue your discussion here, another similar thread AT HERE
This post has been edited by LittleLinnet: Nov 16 2006, 06:04 PM
sHawTY
post Nov 16 2006, 06:04 PM
Frequent Reporter
QUOTE(Canopies @ Nov 16 2006, 05:55 PM)
wat means HSF?????
Bukan change fan liao...
Change the heatsink...
If you want to oc you're processor, change the heatsink of you're processor...
If you want to oc you're graphic card, change the heatsink of you're graphic card...
TSCanopies
post Nov 16 2006, 06:47 PM
Oic...if i wan to OC my ram....change wat???
sHawTY
post Nov 16 2006, 07:00 PM
Frequent Reporter
QUOTE(Canopies @ Nov 16 2006, 06:47 PM)
U can buy those Ram Heatspreader...
TSCanopies
post Nov 16 2006, 08:03 PM
walao..so many still hv to spend...aiks..better play stock 1st...
hey..if i wanna OC my palit sonic ddr3 7300gt version...can i just use the stock of the GC and Oc???
soulfly
post Nov 16 2006, 08:33 PM
revving towards 10,000 rpm
VIP
Please refer to existing threads to clear your doubts.
0.0135sec    0.59    5 queries    GZIP Disabled
Time is now: 30th November 2025 - 06:07 PM
