Alcohol 52% CD & DVD emulation software can create virtual CD/DVD-ROM drives and play CDs & DVDs without the need for the physical disc. This piece of emulation software allows users to play CDs & DVDs without the need for the physical disc. Notebook users and PC Game players will benefit the most from Alcohol 52%. It is not necessary to carry the physical discs and CD & DVD-ROM drive, if users need to present their works to the customers from their notebook. It is not necessary to insert the CD & DVD discs if users want to play PC Games in their computer. Alcohol 52% copies an "invisible" CD & DVD disc to the harddisk.
Update log :
NEW SPTD driver version 1.35.NEW SPTD driver version 1.35.
NEW Full Windows Vista RC2 (Build 5744) compatibility 32Bit and 64Bit editions.NEW Full RC2 of Windows Vista (Build 5744) compatibility 32Bit and 64Bit editions.
NEW RMPS V2, a totally new generation of our RMPS featureNEW RMPS 7202. a totally new generation of our RMPS feature
NEW Option to install Alcohol with or without Virtual drive function.NEW Option to install Alcohol with or without Virtual drive function.
NEW EWSS (Enhanced Weak Sector Scanner).NEW EWSS (Enhanced Weak Sector Scanner).
NEW. Shell Context Menu support in all x64 platforms. (XP, Windows Server 2003 and Vista RC2).NEW. Shell Context Menu support in all x64 platforms. (XP. Windows Server 2003 and Vista RC2).
UPDATE Shell Context Menu to sort drive list by drive letter, and single menu item when only one virtual drive is installed.UPDATE Shell Context Menu list to sort drive by drive letter. and single menu item when only one virtual drive is installed.
UPDATE Alcohols Sector Viewer in CD/DVD Manger, now provides more detailed information for DVD.UPDATE Alcohols Sector Viewer in CD/DVD Manger. now provides more detailed information for DVD.
UPDATE Alcohol data type profiles.UPDATE Alcohol data type profiles.
UPDATE"Ignore Media Type" Function; to include DVD media.UPDATE "Ignore Media Type" Function; to include DVD media.
UPDATE. Alcohols help filesUPDATE. Alcohols help files
UPDATE Language TranslationsUPDATE Language Translations
UPDATE Alcohols Virtual Drive engine.UPDATE Alcohols Virtual Drive engine.
UPDATE Alcohols read engineUPDATE Alcohols read engine.
FIX Missing installed device drivers list in Alcohols system report for X64 platforms.FIX Missing installed device drivers list in Alcohols system report for X64 platforms.
FIX "Invalid User Buffer." Error, that affected some systems.FIX "Invalid User Buffer. "Error. that affected some systems.
FIX. Minor bugs reported by users.FIX. Minor bugs reported by users.
FIXProblem related to U3 USB if RMPS function was activeFIXProblem related to U3 USB if RMPS function was active
FIX Problem related to Acronis True Image issueAcronis True Image issue related to FIX Problem
FIX Problem related to Mac Drive issueFIX Problem issue related to Mac Drive
Download
Source: 9down
Alcohol 52% 1.9.6.4629 Free Edition
Nov 3 2006, 12:49 AM, updated 20y ago
Quote
0.0147sec
0.49
5 queries
GZIP Disabled
