Photography wanting to buy flash, advise pls
TSjustified
post Dec 1 2014, 08:13 PM, updated 12y ago
canon user. wanting to buy my 1st flash..am pondering between canon 430ii EX or yongnuo 560 (?). pls advise which should i get quality vs price factor? i will be using for general purpose and macro photography specifically.
Wilson Teoh
post Dec 15 2014, 02:30 PM
Yongnuo if u buy high end model is actually quite ok
Layboyzx
post Dec 16 2014, 12:49 PM
Depending on budget, if budget allows better get the 580ii for better build.
else the YN 560 wud serve the purpose well enough.
chiewkit
post Dec 16 2014, 02:26 PM
QUOTE(justified @ Dec 1 2014, 08:13 PM)
YN560 is considered "decent" for its price... I think Nissin would be more "thoroughly tested" as they're in the 3rd party flash business longer than YongNuo...
If you're not gonna be "machine-gun-shooting" the flash away, I think it should be fine... but for macro purpose... you might want to get something else... or perhaps get a off-hotshoe cable or a radio trigger...
you might consider a used 430 EXII is now selling at around ~RM600... it's much more reliable & better build quality... but being used... depends on your luck on how "used" the flash is la~
0.0154sec    0.67    5 queries    GZIP Disabled
Time is now: 22nd December 2025 - 12:59 AM
