please close, thanks
This post has been edited by stickymat: May 15 2018, 04:11 PM
Accessories please close, thanks
Nov 17 2014, 02:18 AM, updated 8y ago
#1
5 posts Joined: Sep 2010 |
This post has been edited by stickymat: May 15 2018, 04:11 PM |
Mar 1 2015, 10:14 PM
#2
145 posts Joined: Mar 2012 |
Still available?
Mar 1 2015, 10:23 PM
#3
Mar 1 2015, 11:28 PM
#4
207 posts Joined: Apr 2005 From: Cheras/Kajang |
how bout the existing Power Outlet Cigarette Lighter Socket? still can use right?
will it affect the current fuse rating? |
Mar 1 2015, 11:39 PM
#5
QUOTE(sakuragi @ Mar 1 2015, 11:28 PM) how bout the existing Power Outlet Cigarette Lighter Socket? still can use right? hi, the existing cigarette socket still can use, totally no effect, no worry.will it affect the current fuse rating? the fuse tap adapter just take power from fuse box (select which fuse you like to use, example: wiper fuse, lamp fuse, almost is choose cigarette fuse) Tips: if your car cigarette fuse is 15A, mean you can use maximun 15A device. If your car dvr is use 2A, then 15A - 2A = 13A, so you have left 13A to use on other device at cigarette socket. This post has been edited by stickymat: Mar 1 2015, 11:40 PM |
Apr 16 2015, 02:27 PM
#6
13 posts Joined: Feb 2009 |
best price bro? and where to make cod?
Apr 17 2015, 07:05 PM
#7
May 13 2015, 09:49 PM
#8
662 posts Joined: Mar 2006 |
Hi possible to cod at Chulan Tower tomorrow?
May 17 2015, 01:16 PM
#9
Jul 10 2015, 03:42 PM
274 posts Joined: Oct 2008 |
can install for me??or easy to DIY?
Jul 14 2015, 07:45 PM
Dec 12 2015, 08:43 AM
72 posts Joined: Mar 2009 From: Kepong, Kuala lumpuR |
which COD area you are?
Jan 20 2016, 11:50 PM
25 posts Joined: Apr 2008 From: in my room |
hi there.. item still available?
Jan 21 2016, 09:15 PM
Feb 29 2016, 01:05 PM
49 posts Joined: Jan 2007 |
bro... this is to replace the visible ciggie port or its an add-on ciggie port? im looking at add-on... sorry for the noob question as im not really familiar with all these electronic parts
Mar 1 2016, 11:04 PM
QUOTE(kevinlau85 @ Feb 29 2016, 01:05 PM) bro... this is to replace the visible ciggie port or its an add-on ciggie port? im looking at add-on... sorry for the noob question as im not really familiar with all these electronic parts hi, boss, this is add on.if interest, can whatsapp me 016-2868088 thanks |
May 24 2016, 04:53 PM
4,865 posts Joined: Mar 2008 |
bro micro mini still available? saw ur lelong store sold out...
May 24 2016, 11:14 PM
May 26 2016, 07:51 AM
May 26 2016, 01:44 PM
| Change to: | 0.0263sec
1.20
5 queries
GZIP Disabled
Time is now: 20th December 2025 - 09:17 AM |
