How to raise CGPA?
If resit a paper and get good grades will that raise the CGPA?
TARC
CGPA, How to raise?
CGPA, How to raise?
Sep 13 2006, 04:33 AM, updated 20y ago
#1
160 posts Joined: Jan 2003 From: PJ |
How to raise CGPA?
If resit a paper and get good grades will that raise the CGPA? TARC |
Sep 13 2006, 06:43 AM
#2
Validating
212 posts Joined: May 2006 |
Yes.... if u get a better grade in the resit paper... ur CGPA will shoot up....... Higher the grade.... higher the CGPA!!!!
cheers mate............... |
Sep 13 2006, 07:20 AM
#3
2,491 posts Joined: Jun 2006 From: KL |
if u resit and score A, ur cgpa will raise up but not that much... only slightly higher..
this is because the total credit hours u taken has increased as well.. the formula to calculate CGPA : [ total of ( credit hours X score ) ]/ Total credit hours score for A = 4, B = 3 and so on.. 1 example: the 1st result u got is A for 4 credit hours subject B for 3 credit hours subject D for 4 credit hours subject CGPA = ( 4x4 + 3x3 + 1x4)/ ( 4+3+4) = 2.9 and u resit for the 3 subject that got D. assume that u got A but the previous credit hours will be included as well new CGPA = ( 4x4 + 3x3 + 1x4 + 4x4 )/ ( 4+3+4+4) = 3.214 the example shows quite high increment as the credit hours u earn is not so high yet. but when u keep on studying, the credit hours will increase, and the score effect to the credit hours will be smaller and smaller. that's y we need to score the 1st few sem or 1st year. mostly the subjects tested in 1st year are easier and the grade effect is very big compared to the senior years.. p/s : i'm also a tarcian. later got exam. still struggling to maintain my CGPA.. |
Sep 13 2006, 07:24 AM
#4
8,913 posts Joined: Mar 2005 |
Your transcript wont be nice. You will have the F for the subject for that semester in your transcript. If you pass, then next semester they again will stated the result.
Yes, will shoot up, consider as normal A. yeahs4.1: You sure the previous credit hours will be included as well? I check my transcript, they just give me the normal credit hour. The 1 I failed before is 0, and only the 1 I resit and pass only. Ex-tarcian here. =) |
Sep 13 2006, 08:01 AM
#5
QUOTE(Joshua_0718 @ Sep 13 2006, 07:24 AM) yeahs4.1: You sure the previous credit hours will be included as well? I check my transcript, they just give me the normal credit hour. The 1 I failed before is 0, and only the 1 I resit and pass only. Ex-tarcian here. =) if ur case is true then it is better lo cheers~ |
Sep 13 2006, 08:18 AM
#6
1,413 posts Joined: Jun 2006 From: Shah Alam |
QUOTE(yeahs4.1 @ Sep 13 2006, 07:20 AM) if u resit and score A, ur cgpa will raise up but not that much... only slightly higher.. sorry to interrupt but isnt that just GPA?isnt CGPA is (previous sem CGPA + current GPA)/2?sorry if it is a mistake.. this is because the total credit hours u taken has increased as well.. the formula to calculate CGPA : [ total of ( credit hours X score ) ]/ Total credit hours score for A = 4, B = 3 and so on.. 1 example: the 1st result u got is A for 4 credit hours subject B for 3 credit hours subject D for 4 credit hours subject CGPA = ( 4x4 + 3x3 + 1x4)/ ( 4+3+4) = 2.9 and u resit for the 3 subject that got D. assume that u got A but the previous credit hours will be included as well new CGPA = ( 4x4 + 3x3 + 1x4 + 4x4 )/ ( 4+3+4+4) = 3.214 the example shows quite high increment as the credit hours u earn is not so high yet. but when u keep on studying, the credit hours will increase, and the score effect to the credit hours will be smaller and smaller. that's y we need to score the 1st few sem or 1st year. mostly the subjects tested in 1st year are easier and the grade effect is very big compared to the senior years.. p/s : i'm also a tarcian. later got exam. still struggling to maintain my CGPA.. |
Sep 13 2006, 08:32 AM
#7
4,784 posts Joined: Sep 2004 From: MY |
QUOTE(Joshua_0718 @ Sep 13 2006, 07:24 AM) You sure the previous credit hours will be included as well? I check my transcript, they just give me the normal credit hour. The 1 I failed before is 0, and only the 1 I resit and pass only. the old grade n credit hrs of same paper wont be counted 'again' in CGPA..Ex-tarcian here. =) however when u resit the target paper on other sem, the paper will be counted together like other paper taken in that particular sem GPA (not repairing your old sem GPA) ex-utm *edit typo -------------------- QUOTE sorry to interrupt but isnt that just GPA?isnt CGPA is (previous sem CGPA + current GPA)/2?sorry if it is a mistake.. nopeit will be calculated like gpa, but this time all subjects in the list thus the more subject in list after few sem, even if u repair a singe grade D subject to grade A, it wont make a significant improvements This post has been edited by e-jump: Sep 13 2006, 08:36 AM |
Sep 13 2006, 12:10 PM
#8
Sep 14 2006, 01:21 AM
#9
Validating
ya..... the NEW Grade replaces the OLD grade...... so no addition of additional Credit hours........
Tats how the CGPA shoots up!!!!!!! |
Sep 14 2006, 03:35 AM
ok i get the point
hrmm another question bout cgpa lets say done with diploma will the diploma cgpa affect my degree cgpa? |
Sep 14 2006, 06:21 AM
i believe its a totally new world
ie. u'll start from scratch for ur degree CGPA, while some subjects credits taken during diploma can be transfered juz like that |
Sep 14 2006, 09:02 AM
809 posts Joined: Dec 2004 |
u need to check whether ur college/uni adds the credit hours that u failed or replaces it. if the hours r replaced then u just need to score no need to worry. in my uni, the failed cr hours are added into the cgpa. no turning back
Sep 14 2006, 06:06 PM
52,874 posts Joined: Jan 2003 |
I think you can improve the grades and CGPA by retake those subjects which have bad grades.
However, a general theory about CGPA is it's easy to lose, hard to gain. |
Sep 14 2006, 06:43 PM
Sep 14 2006, 09:18 PM
2,702 posts Joined: Dec 2004 From: P8X-86A |
How about Unimas?
Sep 15 2006, 08:27 PM
Elite
10,672 posts Joined: Jul 2005 From: shah alam - skudai - shah alam |
QUOTE(e-jump @ Sep 14 2006, 06:21 AM) i believe its a totally new world it depends. simplest way to check is if u're offered 1st of degree instead of 4th year. if it's 1st year, it means u're points will start all over again from zero. if it's 4th year (or somewhere around that) in case of twinning or integrated programmes, u will continue ur CGPA points from where u've left off.ie. u'll start from scratch for ur degree CGPA, while some subjects credits taken during diploma can be transfered juz like that QUOTE(plankton @ Sep 14 2006, 09:02 AM) u need to check whether ur college/uni adds the credit hours that u failed or replaces it. if the hours r replaced then u just need to score no need to worry. in my uni, the failed cr hours are added into the cgpa. no turning back as far as i know, all schools will replace ur subject's credit hours with the new ones. here's why:in tertiery education, u accumulate credit hours to determine the level of study u're in. for example, diploma is around 70-90 credit hours, degree is about 160-190credit hours, masters is around 200++ and phd is reaching 300. u accumulate all of them in totality, which means that after finishing ur masters, u will accumulate 200credit hours in total from after STPM to masters (not 90+190+200). so in this case, if they dont replace ur credit hours, imagine if u keep on taking failed subjects again and again, ur credit hours will burst, and they might have to give u a degree after 5 years repeating ur diploma subjects again and again. that's why credit hours are not added, but replaced. replacing credit hours would mean lesser students dont have to take more credit hours in order to get better results. we cant punish students just for being a slow starter but as mentioned earlier, new results wont change that particular semester's result statements. u will only see change on the new semester's results. do note that schools will usually allow u to resit a subject IF u actually fail them. they wont simply let u resit any subjects, mostly because of logistic issues. failure rates are different between schools. some regard D is fail, but some take D+, and there are schools that regards C- is a fail. |
Nov 8 2006, 03:11 PM
496 posts Joined: Jan 2003 |
better discuss on tips on how to get better cgpa without repeating the subject.
Nov 8 2006, 03:18 PM
Elite
Nov 8 2006, 03:59 PM
3,282 posts Joined: Sep 2005 |
TARC is total failure by giving people to fail, but let them to resit & possible to get back an A in the fail subjects.. (frankly, good chances in getting A or B in the failing papers coz lecturer wil mark more leniently/ give more tips
This is simply unfair for those that study hard but fail to get an A for that particular subject. I failed to get a UTAR schoalrship bcoz I did not get perfect score of 4.00. (at that time, UTAR require 4.00 to apply the scholarship) For ur information, the credit hours won't increase if u fail even a lot of papers. Therefore, it means that ur CGPA will raise substantially if u score AA for 2 papers taht u fail. It replace the grade & credit hours u get.. I hate TARC policy Anyway, when u go for job inerview, u just need to show ur graduation certificate, there is no need to show ur transcript. |
Nov 9 2006, 09:43 PM
2,381 posts Joined: May 2005 From: Narnia |
i got 3.37 for my CGPA;
got kinda dissapointed because i need at least 3.65 to get scholarship next time. will it be easy to raise it until at least 3.65 in the next remaining semester? issit only possible by getting all As? |
Nov 9 2006, 10:22 PM
17,875 posts Joined: Jan 2005 |
QUOTE(doinkz_gaara @ Nov 9 2006, 09:43 PM) i got 3.37 for my CGPA; It also depend on how many credit hours left in your new semester. It is possible to raise the CGPA if you scored all As got kinda dissapointed because i need at least 3.65 to get scholarship next time. will it be easy to raise it until at least 3.65 in the next remaining semester? issit only possible by getting all As? |
Nov 9 2006, 10:31 PM
QUOTE(Irresistible @ Nov 8 2006, 03:59 PM) TARC is total failure by giving people to fail, but let them to resit & possible to get back an A in the fail subjects.. (frankly, good chances in getting A or B in the failing papers coz lecturer wil mark more leniently/ give more tips well, you can always point out your strong points in scoring the papers in one try by bringing along the transcript to interview.This is simply unfair for those that study hard but fail to get an A for that particular subject. I failed to get a UTAR schoalrship bcoz I did not get perfect score of 4.00. (at that time, UTAR require 4.00 to apply the scholarship) For ur information, the credit hours won't increase if u fail even a lot of papers. Therefore, it means that ur CGPA will raise substantially if u score AA for 2 papers taht u fail. It replace the grade & credit hours u get.. I hate TARC policy Anyway, when u go for job inerview, u just need to show ur graduation certificate, there is no need to show ur transcript. I myself not a scorer. but i got clean sheet of no fails and drops, and even finish my engineering course early/on time even with re-sit 2 paper to raise my cgpa (but cant do much *oh, manage to finish a 10-semester course in 9 semesters too This post has been edited by e-jump: Nov 9 2006, 10:35 PM |
Nov 10 2006, 01:28 PM
QUOTE(doinkz_gaara @ Nov 9 2006, 09:43 PM) i got 3.37 for my CGPA; CGPA 3.65 -3.7499 : 50 % tuition fee waiver for Advanced Diplomagot kinda dissapointed because i need at least 3.65 to get scholarship next time. will it be easy to raise it until at least 3.65 in the next remaining semester? issit only possible by getting all As? CGPA 3.75-6.8499 : 75% Above 3.85 : 100% But, I heard that the requirement will be higher later bcuse some courses there is more than 25% of students are scholarship holder.(GPA >3.65) Anyway, u still can get a good GPA la, up to 3.70, & I assumed you are in final semester of Year 1 Diploma. But, u can't get more than 1 B in the following 3 semesters. Try to get CGPA 3.50 to get a distinction, make ur parents proud !! I think u can do it. Calculate CGPA : Example, Math 3 credit hours * A (4 point) = 12 English 3 credit hours *B (3 point) =9 Basic Electronic 5 credit hours *A =20 Statistic 4 credit hours * B =12 Physics 4 credit hours *A =16 Total 69 CGPA : Total marks/ accumulated credit hours =69/19 =GPA 3.6316 I hope thats help to guide how many As u should get in the following sem to get a scholarship QUOTE(e-jump @ Nov 9 2006, 10:31 PM) well, you can always point out your strong points in scoring the papers in one try by bringing along the transcript to interview. U r from TARC?? I don't know TARC can graduate early.I myself not a scorer. but i got clean sheet of no fails and drops, and even finish my engineering course early/on time even with re-sit 2 paper to raise my cgpa (but cant do much *oh, manage to finish a 10-semester course in 9 semesters too |
Nov 10 2006, 01:45 PM
580 posts Joined: Jun 2006 From: Kay_Hell |
QUOTE(Irresistible @ Nov 8 2006, 03:59 PM) TARC is total failure by giving people to fail, but let them to resit & possible to get back an A in the fail subjects.. (frankly, good chances in getting A or B in the failing papers coz lecturer wil mark more leniently/ give more tips Hey Irresistible, what's your CGPA? As i know, to get scholarship in UTAR, CGPA 3.9 & above can get full waiver of fees. Sometimes, student don't work hard but want to envy on other student's good achievement. If students can attend every lecture, finish up tutorials given(no copy), ask questions whenever in doubt(if not u will be lost) and do their revision every week(no last minute revision) I believe everybody also can do it.....u want the big share, must sacrifice more.... This is simply unfair for those that study hard but fail to get an A for that particular subject. I failed to get a UTAR schoalrship bcoz I did not get perfect score of 4.00. (at that time, UTAR require 4.00 to apply the scholarship) For ur information, the credit hours won't increase if u fail even a lot of papers. Therefore, it means that ur CGPA will raise substantially if u score AA for 2 papers taht u fail. It replace the grade & credit hours u get.. I hate TARC policy Anyway, when u go for job inerview, u just need to show ur graduation certificate, there is no need to show ur transcript. |
Nov 10 2006, 05:05 PM
Nov 10 2006, 06:44 PM
QUOTE(niu_niu @ Nov 10 2006, 01:45 PM) Hey Irresistible, what's your CGPA? As i know, to get scholarship in UTAR, CGPA 3.9 & above can get full waiver of fees. Sometimes, student don't work hard but want to envy on other student's good achievement. If students can attend every lecture, finish up tutorials given(no copy), ask questions whenever in doubt(if not u will be lost) and do their revision every week(no last minute revision) I believe everybody also can do it.....u want the big share, must sacrifice more.... My time is GPA 4.0 to get a scholarship for UTAR. I think I m only one year senior than u...My CGPA is 3.92 for diploma (2Bs ), but frankly speaking I strongly rely on tips, (Ya, the tips motivate me to study hard, u know la Diploma exam papers come out exactly like tutorial questions, no tips also can score lo) My Advanced Diploma result, is totally failure, just merely get an BBB result, or even worse result. Fail my ACCA, don't know la... I bcome lazy when I go to KL, too much entertainmnet & demotivate by the quality of lecturers.. My study technique may not work well in higher level, memorizing without thorough understanding that FAIL me. Anyway, my undertstanding ability is not good la even compared to average students. I think Failure come from people like me that give all sorts of non-sense excuse to be "lazy"!! |
Nov 10 2006, 06:50 PM
15 posts Joined: Oct 2006 |
If i know I'm not doing in well in that paper, I'll let my lecturer know to give me C- in final exam so can repeat
But I'm lazy person *I think |
Nov 10 2006, 07:13 PM
QUOTE(Irresistible @ Nov 10 2006, 01:28 PM) CGPA 3.65 -3.7499 : 50 % tuition fee waiver for Advanced Diploma thxies!~CGPA 3.75-6.8499 : 75% Above 3.85 : 100% But, I heard that the requirement will be higher later bcuse some courses there is more than 25% of students are scholarship holder.(GPA >3.65) Anyway, u still can get a good GPA la, up to 3.70, & I assumed you are in final semester of Year 1 Diploma. But, u can't get more than 1 B in the following 3 semesters. Try to get CGPA 3.50 to get a distinction, make ur parents proud !! I think u can do it. Calculate CGPA : Example, Math 3 credit hours * A (4 point) = 12 English 3 credit hours *B (3 point) =9 Basic Electronic 5 credit hours *A =20 Statistic 4 credit hours * B =12 Physics 4 credit hours *A =16 Total 69 CGPA : Total marks/ accumulated credit hours =69/19 =GPA 3.6316 I hope thats help to guide how many As u should get in the following sem to get a scholarship U r from TARC?? I don't know TARC can graduate early. now i'm only in my 2nd sem; hopefully i can catch up~ i didnt mean to be evil; but sometimes will group assignments drag u down? i got good marks for individual but super low marks for group assignments; really dont know wat to do~ |
Nov 10 2006, 07:33 PM
225 posts Joined: Oct 2005 |
QUOTE(doinkz_gaara @ Nov 10 2006, 07:13 PM) thxies!~ dont worry, u just 2nd sem,still 5 sem to go if u are diploma and 3 sem to go if u are advance diploma. but normally most of the students will become more lazy from sem to sem,and 1st sem normally is the most hardworking. -.- now i'm only in my 2nd sem; hopefully i can catch up~ i didnt mean to be evil; but sometimes will group assignments drag u down? i got good marks for individual but super low marks for group assignments; really dont know wat to do~ To get the scholarship,just study hard a bit lo, try to understand all the studies and then u sure can manage to score it. try score 3.85 in order to get a full scholarship la. i already regret no study more hardworking in diploma,just get 3.8444 CGPA, 0.01 different make me cant get the full scholarship. Study hard la. Actually group assignment cant cause u drop so much mark in diploma, because lecturer at least give average mark for assignment. The most important is try score well in exam because exam contribute 80%, ur group assignment just 10% around becoz another participation and test will normally contribute another 10%marks. Haiz,now last sem of advance diploma already...hope graduate smoothly and try to get a best job la. Cheers!~~ This post has been edited by bennyhwl: Nov 10 2006, 07:35 PM |
QUOTE(doinkz_gaara @ Nov 10 2006, 07:13 PM) thxies!~ Now, u have no problem la to catch up .... U should try to aim GPA 3.80now i'm only in my 2nd sem; hopefully i can catch up~ i didnt mean to be evil; but sometimes will group assignments drag u down? i got good marks for individual but super low marks for group assignments; really dont know wat to do~ or even higher bcause still got chances. If u are exempted English & b. Malysia in 1st semester, ur chances to get GPA 3.85 full scholarship is still possible by getting straight As in this sem & following sem. My Advice : Do ur Tutorial !! Ya, I understand it !! I face the same situation when I study Advanced Diploma bcause my teacher group us according to Surname. I was forced to join the students that I didn't plan to join. Our group assignment is always the lowest, & all the assignment is done by me. My group members didn't help & one of them even tell me :" Your Diploma result so good, why do assignment so low marks ??" When I was Diploma, I always join with all the Top student in my class for assignment. (I didn't much involve also So the result doinkz_gaara, for ur info, Diploma awarding scheme (show by my lecturer in his room) : A : 70 marks above B: 56 --69 C: 40-55 D: 35-39 (provided GPA above 2.00 ,if not is a F) F: Below 40 What couse u r ?? Engineering course is more tough, is already good if can get GPA 3.5 above. |
Nov 10 2006, 07:55 PM
QUOTE(e-jump @ Sep 13 2006, 08:32 AM) the old grade n credit hrs of same paper wont be counted 'again' in CGPA.. TARC should follow this rewarding System, but NO, TARC work on the opposite way........however when u resit the target paper on other sem, the paper will be counted together like other paper taken in that particular sem GPA (not repairing your old sem GPA) ex-utm *edit typo -------------------- nope it will be calculated like gpa, but this time all subjects in the list thus the more subject in list after few sem, even if u repair a singe grade D subject to grade A, it wont make a significant improvements This post has been edited by Irresistible: Nov 10 2006, 07:58 PM |
Nov 10 2006, 08:40 PM
QUOTE(Irresistible @ Nov 10 2006, 07:33 PM) Now, u have no problem la to catch up .... U should try to aim GPA 3.80 im in mass communication: advertising..or even higher bcause still got chances. If u are exempted English & b. Malysia in 1st semester, ur chances to get GPA 3.85 full scholarship is still possible by getting straight As in this sem & following sem. My Advice : Do ur Tutorial !! Ya, I understand it !! I face the same situation when I study Advanced Diploma bcause my teacher group us according to Surname. I was forced to join the students that I didn't plan to join. Our group assignment is always the lowest, & all the assignment is done by me. My group members didn't help & one of them even tell me :" Your Diploma result so good, why do assignment so low marks ??" When I was Diploma, I always join with all the Top student in my class for assignment. (I didn't much involve also So the result doinkz_gaara, for ur info, Diploma awarding scheme (show by my lecturer in his room) : A : 70 marks above B: 56 --69 C: 40-55 D: 35-39 (provided GPA above 2.00 ,if not is a F) F: Below 40 What couse u r ?? Engineering course is more tough, is already good if can get GPA 3.5 above. muz be more hardworking this sem! |
Nov 11 2006, 12:11 AM
QUOTE(Irresistible @ Nov 10 2006, 06:44 PM) My time is GPA 4.0 to get a scholarship for UTAR. I think I m only one year senior than u... Wah....CGPA 3.92 My CGPA is 3.92 for diploma (2Bs ), but frankly speaking I strongly rely on tips, (Ya, the tips motivate me to study hard, u know la Diploma exam papers come out exactly like tutorial questions, no tips also can score lo) My Advanced Diploma result, is totally failure, just merely get an BBB result, or even worse result. Fail my ACCA, don't know la... I bcome lazy when I go to KL, too much entertainmnet & demotivate by the quality of lecturers.. My study technique may not work well in higher level, memorizing without thorough understanding that FAIL me. Anyway, my undertstanding ability is not good la even compared to average students. I think Failure come from people like me that give all sorts of non-sense excuse to be "lazy"!! U thk u r from TARC Penang branch right? As i know, Penang branch always produce top students without fail and all of them are really good with scholarships...no kidding.....I, myself from KL branch can notice that.... Yes, when comes to Adv Dip, many ppl flop bcoz of the pressure to study..... My advice for ppl who want to maintain their good results in Adv Diploma: 1) 4get about the past(Diploma) no matter how worse or good is ur grades. U r starting from zero in Adv Diploma, thus need to work extra for the grades....no kidding 2) Chase n run for the lecturers....ask ask ask....dont stop asking...... 3) Sleep, eat n relax loh!!!! The best thing about Adv Dip(for acca is like that, not sure about other course) is that the results will be released annually. So, u dont need to worry about ur scholarship being taken away halfway thru the year, for eg beginning sem 2 of 1st year. U still got the waived fees....U will only know about ur fate at the end of sem 2 each year...... |
Nov 17 2006, 04:59 PM
19 posts Joined: Nov 2006 |
Hey guys!
What if like I need to repeat a subject, then my CGPA will be decreased mendadak right? But then, like the next semester, I score on the subject that I need to repeat, my CGPA will be increased or just naik sikit sahaja? |
Nov 17 2006, 05:27 PM
QUOTE(Starlet666 @ Nov 17 2006, 04:59 PM) Hey guys! Increased substantially, From F (fail) to A . Normally, like GPA 1.8 to GPA 2.6 or even more... What if like I need to repeat a subject, then my CGPA will be decreased mendadak right? But then, like the next semester, I score on the subject that I need to repeat, my CGPA will be increased or just naik sikit sahaja? I show the detailed calculation already & I use simple example to explain it. Not understand?? |
Jan 17 2007, 12:06 PM
1,902 posts Joined: Jan 2003 From: Kuala Lumpur |
Wow, i didn't know if one were to resit they can actually get higher grades. In the college that i am studying as long as u resit it doesn't matter how much u get, for instance, 90 marks they will still give u a D.
So it will be better off not to resit. |
Jan 17 2007, 01:50 PM
782 posts Joined: Jul 2005 |
QUOTE(Starlet666 @ Nov 17 2006, 04:59 PM) Hey guys! if u score, suppose ur CGPA will increase mendadak la..What if like I need to repeat a subject, then my CGPA will be decreased mendadak right? But then, like the next semester, I score on the subject that I need to repeat, my CGPA will be increased or just naik sikit sahaja? |
Jan 17 2007, 07:04 PM
3 posts Joined: Oct 2006 |
got a question,we need how many CGPA to take a degree course or enter uni?lets say the diploma CGPA just 2 only can take degree course?
Jan 17 2007, 07:14 PM
929 posts Joined: Jan 2006 |
depends on your dip subject..mybe u just carry fwd the sbject so just 2yrs only degree
Jan 17 2007, 07:48 PM
so that mean as long as the diploma CGPA is 2 or above then its not a problem to take a degree course?
Jan 17 2007, 08:34 PM
i think the cgpa is not a problem. u just need to pass all the subject requirements by the uni or by the course that u want to take.
Jan 18 2007, 03:20 AM
2,967 posts Joined: May 2006 |
errr...
passing is not enuf at least get a b+ as a minimum that's how i always maintain |
Jan 18 2007, 11:40 AM
458 posts Joined: Dec 2006 From: punked |
after industrial training~~ cgpa goes up. provided u do as told by yur supervisor...
Jan 18 2007, 01:22 PM
149 posts Joined: Jan 2007 From: 天堂 |
QUOTE(chocobee_2707 @ Jan 17 2007, 08:34 PM) i think the cgpa is not a problem. u just need to pass all the subject requirements by the uni or by the course that u want to take. i agreed with him.....i know pass the subjects that u take is not enuff ...butonce u get fail for either one of ur subjects.. is like a black spot....u cant graduated with first honor....thats uni's system... although u score well after resit that subject....u cant get the first honor anymore....is kinda cruel system in local uni.... therefore...before u maintain to score well .....the first step is to pass all the subjects..correct me if im wrong |
Jan 20 2007, 09:03 AM
5,726 posts Joined: Feb 2006 From: Penang |
well, if u resit ur paper, the cgpa will increase , if the paper got 4 credit hour for example. u might want to score a high cgpa high earlier and quite difficult to do it in the end coz just a slight increase in the end of semester in cgpa like 'pecahan'- divide a high no. yielding in a low value. thats why final year student resit their paper to increase the cgpa.
Jan 20 2007, 09:28 AM
50 posts Joined: Sep 2006 |
QUOTE(Irresistible @ Nov 8 2006, 03:59 PM) TARC is total failure by giving people to fail, but let them to resit & possible to get back an A in the fail subjects.. (frankly, good chances in getting A or B in the failing papers coz lecturer wil mark more leniently/ give more tips Good day everyone!This is simply unfair for those that study hard but fail to get an A for that particular subject. I failed to get a UTAR schoalrship bcoz I did not get perfect score of 4.00. (at that time, UTAR require 4.00 to apply the scholarship) For ur information, the credit hours won't increase if u fail even a lot of papers. Therefore, it means that ur CGPA will raise substantially if u score AA for 2 papers taht u fail. It replace the grade & credit hours u get.. I hate TARC policy Anyway, when u go for job inerview, u just need to show ur graduation certificate, there is no need to show ur transcript. Such a good threat here that has attracted so many tarcians to express their opinion regarding CGPA... Ohhh... repeat stil having the chance to obtain A!!!!!!!!!! Until today i jz realized that! (then i should try to fail n resit, instead of ready hard Irresistible should b my senior kua~ |
Jan 20 2007, 09:29 AM
Elite
be aware that most universities do not allow students to resit their subjects UNLESS they fail them. it means, once u know u're didnt score the subject, u gotta deal with the lecturer or the head of school to fail u. if u wait until u registered for next semester's subjects, the grades will already finalized and the only way to change it is to bring it up to the next senate meeting of the university.
if u know u're not scoring a subject, either drop the subject or fail urself. getting a minimum pass grade might be the end of u in the future. remember, failing is not as bad as getting a minimum pass... hehe |
Jan 20 2007, 10:15 AM
whoa TARC resit paper can obtain A also meh?and the resit paper is easier to get an A compared to the 1st exam and result will be replaced just like that?that's something and kinda unfair to others..example u get B or C for exam and ur fren fail,he resits and gets A..what would u react?
my college resit paper max will get pass C and most of the candidates will pass This post has been edited by afosz: Jan 20 2007, 10:15 AM |
Jan 20 2007, 11:43 AM
QUOTE(afosz @ Jan 20 2007, 10:15 AM) whoa TARC resit paper can obtain A also meh?and the resit paper is easier to get an A compared to the 1st exam and result will be replaced just like that?that's something and kinda unfair to others..example u get B or C for exam and ur fren fail,he resits and gets A..what would u react? thats why uni's system wont give them graduate with honor....once u resit...u wont get first class anymore although u score A after resit the subject....its kinda unfair for those who get Bs or Cs if they threat the resiter equally with those ppls that nv resit for their course.....my college resit paper max will get pass C and most of the candidates will pass |
Jan 23 2007, 02:57 AM
QUOTE(shinya118 @ Jan 18 2007, 01:22 PM) i agreed with him.....i know pass the subjects that u take is not enuff ...but once u get fail for either one of ur subjects.. is like a black spot....u cant graduated with first honor....thats uni's system... although u score well after resit that subject....u cant get the first honor anymore....is kinda cruel system in local uni.... therefore...before u maintain to score well .....the first step is to pass all the subjects..correct me if im wrong QUOTE(Fairy6262 @ Jan 20 2007, 09:28 AM) Good day everyone! time and time againSuch a good threat here that has attracted so many tarcians to express their opinion regarding CGPA... Ohhh... repeat stil having the chance to obtain A!!!!!!!!!! Until today i jz realized that! (then i should try to fail n resit, instead of ready hard Irresistible should b my senior kua~ this all depends on the uni i dunno about tarc but other universities allow repeaters to repeat and get an A for the simple reason that the uni must let them graduate cuz until u pass that subject, u wont be able to grad and i dunno bout other unis, but mostly even if u fail, if u manage to repeat and get an A, and upgrade ur CGPA beyond the par for honours (usually 3.5 and above). |
Jan 23 2007, 08:24 AM
QUOTE(afosz @ Jan 20 2007, 10:15 AM) whoa TARC resit paper can obtain A also meh?and the resit paper is easier to get an A compared to the 1st exam and result will be replaced just like that?that's something and kinda unfair to others..example u get B or C for exam and ur fren fail,he resits and gets A..what would u react? Resit also can get A meh ? I don't think so lah! It is unfair and unacceptable. my college resit paper max will get pass C and most of the candidates will pass |
Jan 23 2007, 09:49 AM
Elite
why not?
tertiery education is different from school days. the point here is KNOWLEDGE gathering where exams dont really matter. in this system, the institution recognizes the fact that some students learn slower than others (not including dislexic or other forms of learning disabilities). it's not fair to punish such students for their shortcomings. so what does the system offer? u can still score if u study longer. if u fail this time, trying again until u pass. now... isnt that a great environment to LEARN? |
Jan 23 2007, 10:25 AM
13,340 posts Joined: Feb 2005 From: back from vacation XD |
when looking 4 jobs,will interviewers c the CGPA result transcript or just the graduation scroll?
Jan 23 2007, 10:44 AM
434 posts Joined: Sep 2005 |
Jan 23 2007, 01:07 PM
QUOTE(skylinegtr34rule4life @ Jan 23 2007, 10:25 AM) I think ur graduation scroll will indicate whetner u are a good student or not. like graduate with distinction/ 1st class vs graduate with pass/2nd lower class. I was once asked which "part (eg. AR, AP, costing, GL)" of accounting department u wan to get into ?? I answer costing. The interviewer ask me : "What is ur grade for Costing ? let me see your college result !!" If u are freshgraduate, CGPA does matter a lot !! CGPA is an indication whetner u are capable or not to perform, whetner u are smart enough to listen to instruction, whetner u are fast enough to learn !! However, Expected salary sometimes is determinant whetner u get the job. If u demand too high regardless u are the best student of the year, u won't get hired!! |
Jan 23 2007, 01:23 PM
QUOTE(azarimy @ Jan 23 2007, 09:49 AM) why not? No, I don't agree !!tertiery education is different from school days. the point here is KNOWLEDGE gathering where exams dont really matter. in this system, the institution recognizes the fact that some students learn slower than others (not including dislexic or other forms of learning disabilities). it's not fair to punish such students for their shortcomings. so what does the system offer[ If u wan to study longer, u can study like 12-15 hours a day to catch up!! I am a slow (very slow) student myself, but doesn't mean that I have the advantage of failing & repeating the same subject. In your way, it is encouraging them to repeat and repeat the same subjects and by dropping other subjects. This cycle just go on and on, endlessly. In the real world, employer won't let u to "repeat" !!! So, come on... If resit, there's OK, but u get an "A", it is encourage student to fail. (The fact is TARC failing rate for diploma is ranging 30-40%) |
Jan 23 2007, 04:23 PM
QUOTE(Irresistible @ Jan 23 2007, 01:23 PM) [ agreed!!! it's kinda unfair for those who get Bs n Cs....they cant resit....private colleges shouldnt based on this kind of system...it's indirectly to encourage students get fail rather than get Bs n Cs......some says " try to ask the lecturer to fail me" ? is it logic? inside their mind only have As or Fail?No, I don't agree !! If u wan to study longer, u can study like 12-15 hours a day to catch up!! I am a slow (very slow) student myself, but doesn't mean that I have the advantage of failing & repeating the same subject. In your way, it is encouraging them to repeat and repeat the same subjects and by dropping other subjects. This cycle just go on and on, endlessly. In the real world, employer won't let u to "repeat" !!! So, come on... If resit, there's OK, but u get an "A", it is encourage student to fail. (The fact is TARC failing rate for diploma is ranging 30-40%) |
Jan 23 2007, 06:28 PM
Elite
dude, this system is being used WORLDWIDE. deal with it.
the slower students will have to pay more, and spend more time. in the world where everyone is whining about why it takes so long to do a degree, TIME is not a luxury most people used to have. why are we questioning this? have u not been to a proper university before? |
Jan 23 2007, 06:40 PM
hmm...
the most important question is why are u even asking the question on the justice to allow students to repeat and get an A if ur slow, then study smart not study hard do u really think those who failed are dumb i begin to think dat way since high school i never scored a single thing except science,agama islam and english (i was one of the best malay student for english...i mean i speak,write and understands better in english than those malay who stayed overseas all their lives) but those who didnt score in exams could have scored better outside...in the real world... thats what we call street smart smart lawyers arent the one who can argue on laws itself...they are the ones who can manage the case by just go straight forward and essentially know who the judge of the case and make do with so little knowledge they have smart doctors know what their patients wants and needs...not just administer this and dat drugs based on the rule of the book smart student would know how to get to the lecturer in exams...not just blabber this and that vomiting what they have learnt all this while the most basic thing about being smart is to know the most simple way,not the easy way at most times aint simple, but in knowing its simple he embroadens it to reach the objective it boils back to common sense i'd prefer a late bloomer in my company than an egoistical brainy ones cuz the latter might not know how to handle people so live with it CGPA does reflect who u are but thats marginally important priority should be given to ur command in using ur common sense or basically street smart This post has been edited by gtoforce: Jan 23 2007, 06:41 PM |
Jan 23 2007, 07:17 PM
QUOTE(azarimy @ Jan 23 2007, 06:28 PM) dude, this system is being used WORLDWIDE. deal with it. Since threadstarter is stating TARC. the slower students will have to pay more, and spend more time. in the world where everyone is whining about why it takes so long to do a degree, TIME is not a luxury most people used to have. why are we questioning this? have u not been to a proper university before? What TARC will do for those that fail during the last semester is they will be shortlisted for a simple test. Eventually, all of them will pass and attend the same graduation ceremony with their friends (same batch).* Therefore, there is no wasting time, A resit paper in TARC cost RM 50 (around that,right?) Can u afford?? *This apply to those that fail one to two papers. If more than that, ya u have to resit again. |
| Change to: | 0.0310sec
1.85
5 queries
GZIP Disabled
Time is now: 19th December 2025 - 01:45 AM |
