i have an old proton wira which i plan to modify the engine.
which type of engine ok?
usually cost how much?
thank you.
Mod Proton Wira, Worth it?
Oct 4 2014, 08:49 AM, updated 12y ago
#1
58 posts Joined: Oct 2010 |
which type of engine ok? usually cost how much? thank you. |
Oct 4 2014, 09:05 AM
#2
303 posts Joined: Nov 2013 |
4G93 DOHC - RM7-8k complete i think
Oct 4 2014, 09:23 AM
#3
4 posts Joined: Nov 2010 |
depends on what kind of mods u planning to do.... if u r on budget 4g13/15 has abundant parts and economical.... whereas 4g93 DOHC it will be a bit difficult to maintain because well it has twin cam.... cam will sure be expensive if u were to upgrade it and u have more valve spring and valve... if u wan power and dont mind spending money go for 4g63t if u wan power to be on ur side... if N/A i dun see why not....
Oct 4 2014, 09:37 AM
#4
QUOTE(drunkmunky @ Oct 4 2014, 09:23 AM) depends on what kind of mods u planning to do.... if u r on budget 4g13/15 has abundant parts and economical.... whereas 4g93 DOHC it will be a bit difficult to maintain because well it has twin cam.... cam will sure be expensive if u were to upgrade it and u have more valve spring and valve... if u wan power and dont mind spending money go for 4g63t if u wan power to be on ur side... if N/A i dun see why not.... 4g63t how much on the market?fc high ar? |
Oct 4 2014, 09:51 AM
#5
Oct 4 2014, 11:47 AM
#6
1,008 posts Joined: Jan 2005 From: Shah Alam SDE |
IMO, TS current engine is what?
if wira 1.5 carb then just upgrade to MMC injection.. from there there's a lot of performance part for it if wira 1.5 injection SIEMENS then its kinda troublesome, try to change to MMC injection if wira 1.6/1.8 single cam injection, its a lot better.. just modified the current engine where there still a lot of performance parts if wira 1.8 DOHC its the best engine either to upgrade turbo engine and sell of the engine to get better performance or just upgrade the engine.. but extra torque require a lot of modification which the cost could be sky rocket, either words its high maintenance.. i did try to mod wira 1.6 single cam.. its quite good too, just minor mod like piggyback, better outflow n inflow, racing clutch, racing disc n racing brake pad, higher compression ratio etc.. i can get 0-100km/h in 8s flat.. its not major mod eg block cutting and balancing, racing cam, racing valve, racing valve spring, stand alone ECU etc.. even the head also almost completely stock.. so imagine for those turbo engine.. huhu |
Oct 8 2014, 03:49 AM
#7
43 posts Joined: Feb 2009 |
budget play = 93sohc
or else gsr/mivec T if u have the money |
Oct 8 2014, 08:58 AM
#8
2,730 posts Joined: Jan 2003 From: In the shadows behind you |
QUOTE(oniomaniac @ Oct 4 2014, 09:37 AM) QUOTE(arza04 @ Oct 4 2014, 09:51 AM) 4g63 cannot endorse, not legal but if dont mind As what arza04 posted.since it is not legal for proton cars except perdana, less market therefore cheaper price 5-6k FC? compare to 4g15 high lor..better dun mod if have fc in mind JPJ changed the rule for Proton... i.e there is a special rule for Proton now. 4G63 cannot lulus JPJ for Wira.. if you mod then kena JPJ road block then sorry for you.... |
Oct 8 2014, 03:42 PM
#9
1,422 posts Joined: Apr 2006 |
Oct 8 2014, 08:59 PM
8,930 posts Joined: Nov 2005 From: Subang Jaya |
4g93sohc also damn cun edi bro
Oct 8 2014, 10:33 PM
481 posts Joined: Feb 2008 From: from da land of dori dori |
4g93 dohc NA lagi cun....stock standard quite power & torque compared to sohc..
Oct 9 2014, 12:57 AM
#12
221 posts Joined: Dec 2013 |
4g93 DOHC cun d....
Oct 9 2014, 11:12 PM
4,221 posts Joined: Dec 2007 From: Somewhere on Earth |
4g15 carb also can be fast, buy a DCOE weber (damn i love weber), get tuned length exhaust manifold, mild camshaft, stiffer valve spring, adjustable, proper tires, something at least PS3.
Oct 12 2014, 11:30 AM
thanks everyone for the advices
| Change to: | 0.0294sec
1.04
5 queries
GZIP Disabled
Time is now: 15th December 2025 - 11:40 AM |
