Outline ·
[ Standard ] ·
Linear+
iDVD, can't replace images
TSsupafreak
Aug 12 2006, 03:04 AM, updated 20y ago
Hi all,
I hope someone can help... i dunno wat happened wit my iDVD... the thing worked great the first few times and now out of a sudden, i can't seem to be able to replace the images in the background or placeholders by clicking and dragging... the images bounces back to the file list...
the only way i can replace the images is by doing an import...
I've reinstalled both iDVD and iPhoto but tat didnt solve the problem... can someone help?
wei
Aug 12 2006, 10:01 AM
try moving this file temparary to another folder: ~/Users/Your home folder/Library/Preferences/com.apple.iDVD.plist
Restart/Re-login your Mac. Start iDvd again and try.
TSsupafreak
Aug 12 2006, 03:30 PM
QUOTE(wei @ Aug 12 2006, 10:01 AM) try moving this file temparary to another folder: ~/Users/ Your home folder/Library/Preferences/com.apple.iDVD.plist Restart/Re-login your Mac. Start iDvd again and try. Hi Wei... Thanks for responding... tried ur advise.. still didnt work... any other ideas?...
wei
Aug 12 2006, 05:42 PM
hmm... no idea. maybe u can tell us more details, like: -is it the same photo u trying to replace or it happen to any image? -this happen on any new project or its the same project? -what mac u using? -did you done something to your mac lately? ie upgrade software/hardware?
TSsupafreak
Aug 12 2006, 11:13 PM
QUOTE(wei @ Aug 12 2006, 05:42 PM) hmm... no idea. maybe u can tell us more details, like: -is it the same photo u trying to replace or it happen to any image? -this happen on any new project or its the same project? -what mac u using? -did you done something to your mac lately? ie upgrade software/hardware? I'm using the macbook... juz had the RAMs upgraded... but the problem was thr b4 i upgraded... i tried loads of pics but it kept bouncing back... it happens on new or old projects... havin said tat.. i did a new idvd project juz now... and i replaced the theme music... and voila... suddenly everything is ok... geez... kinda weird... Thanks so much for ur effort Wei...
