1 ) Can portable air con function like normal wall attached air con ?
2 ) Does portable air con lasts long ?
3 ) Any suggestion for the brand ? price ?
Thanks !
This post has been edited by werty415: Jul 13 2014, 08:33 AM
Portable Air Conditioner, Is portable air con functions well ?
May 25 2014, 11:38 PM, updated 11y ago
#1
7 posts Joined: May 2012 From: Ipoh, Perak |
Hello there, I'm thinking to have a portable air con but not sure about the quality of it.
1 ) Can portable air con function like normal wall attached air con ? 2 ) Does portable air con lasts long ? 3 ) Any suggestion for the brand ? price ? Thanks ! This post has been edited by werty415: Jul 13 2014, 08:33 AM |
May 26 2014, 08:31 AM
#2
56 posts Joined: May 2010 |
i got 2 unit of this, 1 is midea 1.5hp and the other 1 is pensonic 1.0hp
1 ) Can portable air con function like normal wall attached air con ? it does function like wall aircond but noisy, its like opening your car aircond blower at max setting 2 ) Does portable air con lasts long ? currently using it almost 2year, still good 3 ) Any suggestion for the brand ? price ? brand...hmmmm, not so much review of this , so i dont know which brand is good, but the price is from 999 - 1800 and the hp is from 1.0 - 1.5 |
May 26 2014, 11:19 AM
#3
198 posts Joined: Apr 2006 From: KL |
what to ask...the portable air-cond power consumption same with wall mount air-cond??
1.0hp vs 1.0hp |
May 26 2014, 02:23 PM
#4
QUOTE(azlansani @ May 26 2014, 08:31 AM) i got 2 unit of this, 1 is midea 1.5hp and the other 1 is pensonic 1.0hp Yea thanks for all these. It is very helpful ! 1 ) Can portable air con function like normal wall attached air con ? it does function like wall aircond but noisy, its like opening your car aircond blower at max setting 2 ) Does portable air con lasts long ? currently using it almost 2year, still good 3 ) Any suggestion for the brand ? price ? brand...hmmmm, not so much review of this , so i dont know which brand is good, but the price is from 999 - 1800 and the hp is from 1.0 - 1.5 |
May 26 2014, 02:26 PM
#5
May 26 2014, 05:23 PM
#6
QUOTE(werty415 @ May 26 2014, 02:23 PM) i didnt have any wall mounted air-cond so i cant compare, but my electric bill when up +rm70/month using the 1.0hp in a not so seal room air cond on 10pm-5am daily temp set to 26 deg c ( but strangely the air cond seldomly achieve this temp ) 2 adult 1 child room area ~22m square the unit is quit big and heavy + it come with a big vent host , so that you can vent the hot air outside hope this help, |
May 26 2014, 05:37 PM
#7
106 posts Joined: May 2011 |
law of thermodynamic - conservation of energy
you must remember that the heat must go somewhere usually it just blast the hot air at the back useless indoor use only if next to a vent like beside a window or a door |
May 26 2014, 05:41 PM
#8
7,938 posts Joined: Mar 2014 |
QUOTE(stormsea7 @ May 26 2014, 05:37 PM) law of thermodynamic - conservation of energy This most people forget about. It is like you have a fridge. You open the fridge door. Will your kitchen get cooler? Nope you must remember that the heat must go somewhere usually it just blast the hot air at the back useless indoor use only if next to a vent like beside a window or a door |
May 26 2014, 06:14 PM
#9
QUOTE(azlansani @ May 26 2014, 05:23 PM) i didnt have any wall mounted air-cond so i cant compare, Thanks for the details but my electric bill when up +rm70/month using the 1.0hp in a not so seal room air cond on 10pm-5am daily temp set to 26 deg c ( but strangely the air cond seldomly achieve this temp ) 2 adult 1 child room area ~22m square the unit is quit big and heavy + it come with a big vent host , so that you can vent the hot air outside hope this help, where you put the output ? |
May 26 2014, 10:35 PM
QUOTE(Zot @ May 26 2014, 05:41 PM) This most people forget about. It is like you have a fridge. You open the fridge door. Will your kitchen get cooler? Nope bro but according to the member, there's a ducting hose to let the heat go outside of the room. what do you think ? ![]() This post has been edited by werty415: May 26 2014, 10:36 PM |
May 27 2014, 08:05 AM
QUOTE(werty415 @ May 26 2014, 06:14 PM) Thanks for the details the ducting hose is used to channel the hot air outside, the outside wont come through the vent during its operational, because there's always a constant hot air flow outside. where you put the output ? in the picture, the white plastic panel at the end of the hose is the accessories that come with the air-cond, but you must check as my second unit does not have that accessories. my room window is not like in the picture - one big glass ; but the old one; multiple sheet of glass so i just take out one glass sheet and place the end of the vent there, i used polystyrene board ; make a hole the size of the vent end port ; and cut the board to the size of my window and fit it there. hope its help This post has been edited by azlansani: May 27 2014, 08:10 AM |
May 27 2014, 08:22 AM
QUOTE(werty415 @ May 26 2014, 10:35 PM) bro but according to the member, there's a ducting hose to let the heat go outside of the room. what do you think ? Yes that is true. The portable air-con has a hose for this specific purpose. Hot air blown out from the hose has to be isolated from the room/space you want to cool. If not, just wasting electricity.![]() |
May 27 2014, 08:23 AM
QUOTE(werty415 @ May 26 2014, 10:35 PM) bro but according to the member, there's a ducting hose to let the heat go outside of the room. what do you think ? Yes that is true. The portable air-con has a hose for this specific purpose. Hot air blown out from the hose has to be isolated from the room/space you want to cool. If not, just wasting electricity. In case of the fridge, the isolation is the fridge door. The air inside the fridge is cold at the expense of your kitchen (and you while cooking in kitchen ![]() |
Jul 13 2014, 08:36 AM
QUOTE(stormsea7 @ May 26 2014, 05:37 PM) law of thermodynamic - conservation of energy bro but according to the member, there's a ducting hose to let the heat go outside of the room. what do you think ?you must remember that the heat must go somewhere usually it just blast the hot air at the back useless indoor use only if next to a vent like beside a window or a door |
Jul 13 2014, 09:39 AM
276 posts Joined: Jul 2007 |
another thing about portable aircond you have to prepare some cups or mangkuk for the dripping water, in my moms house it will drip alot of water and fill the mangkuk after 30 mins, i solved this by getting an aquarium hose and extending outside the house.
Jul 13 2014, 09:42 AM
Jul 13 2014, 12:46 PM
QUOTE(thahirah @ Jul 13 2014, 09:42 AM) another thing about portable aircond you have to prepare some cups or mangkuk for the dripping water, in my moms house it will drip alot of water and fill the mangkuk after 30 mins, i solved this by getting an aquarium hose and extending outside the house. I see . What is the age of your air con bro ? brand ? |
Jul 13 2014, 03:53 PM
QUOTE(werty415 @ Jul 13 2014, 12:46 PM) its Mdea brand, Not sure if it depends on the humidity of the house, but you can normally see some split unit aircond they have a water outlet pipe right?Portable aircond have that too but it just drips behind it. |
Jul 13 2014, 06:44 PM
QUOTE(thahirah @ Jul 13 2014, 03:53 PM) its Mdea brand, Not sure if it depends on the humidity of the house, but you can normally see some split unit aircond they have a water outlet pipe right? I see, maybe the pipe is loose ? other than that, Is it still functioning well ? t Portable aircond have that too but it just drips behind it. |
Jul 14 2014, 01:00 PM
3,617 posts Joined: Oct 2010 |
kimsim
Jul 14 2014, 01:15 PM
977 posts Joined: Jun 2009 |
QUOTE(werty415 @ Jul 13 2014, 06:44 PM) I have a Hesstar 1.0HP one. Have been using it for nearly 4 yrs. It says 'auto-evaporate water, no need drainage', but after about 1.5 yrs, the small PVC plate provided to put at the drip hose (sticks out about an inch) gets full very fast after turning the unit off. So I just bought a rubber hose from hardware shop and extend the drip hose to my bathroom.As for the exhaust hose mounting, I just grab a piece of plywood about the size of a multisheet glass and fix them in after cutting a hole to fit the hose. And one more thing, this unit needs the usual cleaning like wall-mounted split units (inside, not just the filters) when the wind felt weak. I was fed up after asking few contractors because they said never cleaned this type before so not interested to do the job. The HQ says need to deliver the unit to them for cleaning service, but that things is darn heavy... So I decided to dismantle the covers and clean the inside myself. Did it twice already. So far so good. Save some $$ too. |
Jul 14 2014, 01:26 PM
10,340 posts Joined: Jan 2003 |
QUOTE(thahirah @ Jul 13 2014, 03:53 PM) its Mdea brand, Not sure if it depends on the humidity of the house, but you can normally see some split unit aircond they have a water outlet pipe right? Which Midea unit you have? It suppose to have an evaporator built in and it suppose to auto switch off when the water level is full. If your unit have this feature and it is still dripping water then you need to go claim warranty.Portable aircond have that too but it just drips behind it. http://www.midea.com/my/consumer/air_condi...227_53915.shtml QUOTE No Bucket Design Bucket free design brings satisfying cooling power. Draining of condensate water is not required as it would be evaporated automatically along the operation. ![]() |
Jul 14 2014, 05:18 PM
QUOTE(kuntilanak @ Jul 14 2014, 01:15 PM) I have a Hesstar 1.0HP one. Have been using it for nearly 4 yrs. It says 'auto-evaporate water, no need drainage', but after about 1.5 yrs, the small PVC plate provided to put at the drip hose (sticks out about an inch) gets full very fast after turning the unit off. So I just bought a rubber hose from hardware shop and extend the drip hose to my bathroom. Hey man , thank you so much for your details ! it helps. Update us here if there's anything new As for the exhaust hose mounting, I just grab a piece of plywood about the size of a multisheet glass and fix them in after cutting a hole to fit the hose. And one more thing, this unit needs the usual cleaning like wall-mounted split units (inside, not just the filters) when the wind felt weak. I was fed up after asking few contractors because they said never cleaned this type before so not interested to do the job. The HQ says need to deliver the unit to them for cleaning service, but that things is darn heavy... So I decided to dismantle the covers and clean the inside myself. Did it twice already. So far so good. Save some $$ too. |
Mar 2 2015, 09:36 PM
276 posts Joined: Jan 2003 |
Where can buy those
Mar 3 2015, 11:38 PM
Mar 4 2015, 11:51 PM
60 posts Joined: Jun 2011 |
Im wondering which one is more power saving? Portable 1.0hp or normal 1.0hp.
Mar 5 2015, 11:55 PM
Sep 4 2015, 06:57 PM
486 posts Joined: Dec 2013 |
Quadpost
This post has been edited by gogocan: Sep 4 2015, 11:14 PM |
quadpost
This post has been edited by gogocan: Sep 4 2015, 11:15 PM |
Sep 4 2015, 11:13 PM
I wonder why up until now, no big name like samseng, hitachi toshiba come with portble aircond?only those ayam brand like MEC / i brand / midea produce such technology? Or is it a scam?
Sep 5 2015, 11:11 AM
5,144 posts Joined: Oct 2009 |
My electric bill is around RM80~RM85, one of my housemate has this portable AC. He uses for around 8H/day.
My bill now is around RM120~RM130. |
Sep 6 2015, 12:06 PM
28 posts Joined: Jan 2015 |
QUOTE(ledtechn @ Mar 4 2015, 11:51 PM) Sharing my experience..I got 1 midea portable aircond.. 1hp.. Seems like the normal wall mounted aircond save more electricity than the portable 1. The main issue with the portable aircond is the noise produced and hot air not properly dissipated outside the room thru the hot air duct which will cause the aircond work harder to cool down the air. |
Apr 15 2016, 12:20 PM
4 posts Joined: Jan 2006 |
Apr 15 2016, 12:27 PM
QUOTE(keeks @ Apr 15 2016, 12:20 PM) Actually both work the same way. Fridge removes heat inside the fridge to outside of the fridge. Aircon removes heat inside of a room to outside of the room. So, if you want to use your fridge as air-con, you just need to make sure the fridge body is outside the room completely |
Sep 1 2016, 05:05 PM
#35
3 posts Joined: May 2016 |
QUOTE(kuntilanak @ Jul 14 2014, 01:15 PM) I have a Hesstar 1.0HP one. Have been using it for nearly 4 yrs. It says 'auto-evaporate water, no need drainage', but after about 1.5 yrs, the small PVC plate provided to put at the drip hose (sticks out about an inch) gets full very fast after turning the unit off. So I just bought a rubber hose from hardware shop and extend the drip hose to my bathroom. The size of the rubber hose? As for the exhaust hose mounting, I just grab a piece of plywood about the size of a multisheet glass and fix them in after cutting a hole to fit the hose. And one more thing, this unit needs the usual cleaning like wall-mounted split units (inside, not just the filters) when the wind felt weak. I was fed up after asking few contractors because they said never cleaned this type before so not interested to do the job. The HQ says need to deliver the unit to them for cleaning service, but that things is darn heavy... So I decided to dismantle the covers and clean the inside myself. Did it twice already. So far so good. Save some $$ too. Can the water be channelled to higher window or it's gravitational? Mine is Hesstar HAC-AE90. Thanks. This post has been edited by aq4912: Sep 1 2016, 05:07 PM |
Sep 1 2016, 05:36 PM
503 posts Joined: Jan 2011 |
my dad has one. (floor mounted)
He works in an ice factory, where he scrapes extra unusable ice (damaged/dropped on floor) sometimes into a plastic bag and brings home to pour into the water inlet, makes it more cooler This post has been edited by lunatique: Sep 1 2016, 05:36 PM |
Sep 2 2016, 01:01 AM
5,184 posts Joined: Jan 2009 |
This thing inefficient and is a waste of electricity due to its design
It uses the room cold air to cool down its hot condenser coil and compressor, the heat is then thrown out as hot air. Means cold air in the room also get thrown outside used for cooling compressor and hot condenser coil. Only half gets back in the room. A split unit hot condenser and compressor is cooled by blower fan of the outdoor unit. No wastage of using cool air in the room to cool compressor down. Cool air remains in the room, faster cooling more efficient. This post has been edited by Mea Culpa: Sep 2 2016, 01:03 AM |
Sep 2 2016, 08:42 AM
QUOTE(aq4912 @ Sep 1 2016, 05:05 PM) The size of the rubber hose? Wah, you necro my post... Can the water be channelled to higher window or it's gravitational? Mine is Hesstar HAC-AE90. Thanks. Anyway, the water rubber hose size is about 1/4', I think. Can't remember as I don't use it anymore. The water outlet is just a drainage, so of course it is governed by gravity. You go decide how to get rid of that water lor... good luck. |
Sep 8 2016, 12:27 PM
139 posts Joined: Jul 2012 |
It is very noisy .. For me not worth it
| Change to: | 0.0339sec
0.80
6 queries
GZIP Disabled
Time is now: 16th December 2025 - 12:49 AM |
