 Help for overclocking, Kingston's. 2400c11 beast
TShydeist6055
post May 14 2014, 05:35 PM, updated 12y ago
Hi guys I need help.. I am using asus maximus ranger mono with 2400c11 beast. But bios only stated 1333mhz not 2400mhx... While I change xmp and set profile 1 to 2400mhz.. And computer in bootloop can start. Every few sec it shut down on and shut down on and shut down.. I Ned to reset thru pressing the mono reset button.
What is the problem ? Help is extremely helpful.
TShydeist6055
post May 14 2014, 05:36 PM
Can't start. I really wan it to run in 2400mhz
cstkl1
post May 15 2014, 05:13 PM
Elite
QUOTE(hydeist6055 @ May 14 2014, 05:36 PM)
Full spec
keyo
post May 16 2014, 02:22 PM
vdimm adjust to 1.65
cstkl1
post May 16 2014, 09:39 PM
Elite
QUOTE(keyo @ May 16 2014, 02:22 PM)
keyo
post May 16 2014, 11:16 PM
QUOTE(cstkl1 @ May 16 2014, 09:39 PM)
salah ke sorry noob
cstkl1
post May 16 2014, 11:21 PM
Elite
QUOTE(keyo @ May 16 2014, 11:16 PM)
salah ke sorry noob
its more than that.
its his digital/analogue voltage. he needs to up it to boot.
and to make it superstable set the rtls manually.
TShydeist6055
post May 20 2014, 01:28 AM
Intel i7 4770k
Asus maximus VII ranger
Kingston hyper x 2400 c11
650watt power supply seasonic
Asus r9 280x direct cu ii top.
Obsidian 600t
Noctua d 13 cooler.
This r my spec.
But when enter bios ram running at 1333mhz only why?
When I change to 2400mhz without OC the processor it will bootloop without even entering windows.. Any idea situ.. Pls help.
TShydeist6055
post May 20 2014, 01:30 AM
QUOTE(cstkl1 @ May 15 2014, 05:13 PM)
Full spec
Intel i7 4770k
Obsidian 600t
Noctua d 13 cooler.
This r my spec.
keyo
post May 21 2014, 09:43 AM
saya tak pernah pakai intel kalau adjust xmp tu timing dia set automatik ke
Aloysiusyong
post Jun 17 2014, 12:51 PM
guys, since it helps on overclock
i want to know whether my Laptop can be overclock or not ?
dun_panic
post Jun 20 2014, 12:59 AM
QUOTE(hydeist6055 @ May 20 2014, 01:28 AM)
Intel i7 4770k
Obsidian 600t
Noctua d 13 cooler.
This r my spec.
same spec here.. i just change the dram freq auto-2400. heck, i set it @ 2600 with 1.67v
0.0207sec    0.45    6 queries    GZIP Disabled
Time is now: 30th November 2025 - 11:35 AM
