 Testing and Integration Engineer, anybody work as it? knows the job spec?
TSnumber8
post Jul 11 2006, 03:01 PM, updated 20y ago
It's Not About The Number, It's About The Position...
hi dudes... i wanna ask around if anybody ever works as this Testing and Integration Engineer... does it got anything to do with performing coding / programming.... did some checking and found out got to write test scripts? how does that go? what does it means? some people say it is done on ms word? huh? icon_question.gif here is what i manage to gather so far... thanks guys...
-plan and implement testing programme
-write test scripts and preside over testing exercise
-prepare test reports
-manage observation reports
-document and manage interface control items
-manage integration of the system
-feedback on the quality of the software that was tested
HappyUser
post Jul 11 2006, 04:08 PM
Have you applied for this job yet or were u offered it? I believe this company is X_ _ _ _E right?
msnice
post Jul 11 2006, 05:19 PM
is that what they ask u? or is that their job specification?
Did u went to the interview ? If so..mind to share the experience.
test script will be depends on the testing approach that you going to use.
manual testing or automated testing.
manual testing will be using certain template and most likely will be using MSWord to develop the manual test script.
And automated testing, will be using automation tools to execute the test.
For automation testing, u need programming/ scripting skills, basically based on what the language the company use.
for more info, I believe, Mr Google would be glad to help.
TSnumber8
post Jul 11 2006, 10:55 PM
QUOTE(HappyUser @ Jul 11 2006, 04:08 PM)
just came across it... thinking of applying...
goliath
post Jul 11 2006, 10:59 PM
Expect more than what you have listed in your first post. Normally company loves to summarise everything as short as possible. At times, they will assign you to different position. So, be sure to ask about that when you attend for interview.
TSnumber8
post Jul 11 2006, 11:10 PM
QUOTE(msnice @ Jul 11 2006, 05:19 PM)
no lah.. i am thinking to apply the post... thanks for the info dude...
TSnumber8
post Jul 11 2006, 11:24 PM
QUOTE(goliath @ Jul 11 2006, 10:59 PM)
0.0135sec    0.47    5 queries    GZIP Disabled
Time is now: 8th December 2025 - 01:27 PM
