 timing belt, change interval
TSbodybuilder
post Nov 11 2013, 09:58 AM, updated 13y ago
Myvi 1.0 2005 milage 130k km
Last changed timing belt:
21-09-2009, 79,000.00km
so my timing belt age: 4years 2months , 51k km
Should I change it now or wait until the belt reaches 80k km?
my water pump no chg b4...shd i chg it 1 shot?
SUSraynman
post Nov 11 2013, 10:11 AM
I thought the Myvi uses timing chain?
OKLY
post Nov 11 2013, 10:17 AM
The Penguin Vader
Staff
QUOTE(raynman @ Nov 11 2013, 10:11 AM)
Only the EJ-VE aka 1.0 litre engine is using timing belt, the K3-VE (1.3) and 3SZ-VE (1.5) is using timing chain.
SUSraynman
post Nov 11 2013, 10:19 AM
theanswer
post Nov 11 2013, 10:41 AM
4 years=50k km...i think can wait til 80k km.
MR_alien
post Nov 11 2013, 12:04 PM
Mr.Alien on the loss
wait till 80k and change the water pump with it
joefbi
post Nov 11 2013, 12:23 PM
joefbi a.k.a roketx
QUOTE(MR_alien @ Nov 11 2013, 12:04 PM)
+1
6UE5T
post Nov 11 2013, 06:48 PM
QUOTE(bodybuilder @ Nov 11 2013, 09:58 AM)
Well what is the recommended change interval from Perodua? You should check and follow that instead of listening from various people who may not really know as well. If got unlucky and the belt broke at say 78k kms, then how?? biggrin.gif
This post has been edited by 6UE5T: Nov 11 2013, 06:49 PM
MR_alien
post Nov 11 2013, 09:20 PM
QUOTE(6UE5T @ Nov 11 2013, 06:48 PM)
how to detect is to go look at the belt...see if its cracked
if it is...the change
incredibless
post Nov 11 2013, 09:28 PM
sometimes depends hw u use ur car.. if u drive in city with alot of jams. den better to change now coz u mentioned its oredi 4years+ even its only 51k, the condition of the belt might nt be in good shape.. if you are frequent highway user, then continue to use it till 70-80k...i just changed my waja timing belt even it clocked 45k+ but the belt's age is 5years. the condition of the belt is quite bad n luckily it did not snap.. laugh.gif . the choice is yours...if me just change it for the sake of less headache and major $$$$
6UE5T
post Nov 11 2013, 10:39 PM
QUOTE(MR_alien @ Nov 11 2013, 09:20 PM)
You would not be able to see every inch of the belt so you may think it's still ok while in fact may not be. Best is to follow manufacturer recommendation of not to exceed certain kms of use. If you exceed and it fails, then you only have your self to blame.
wil-i-am
post Nov 15 2013, 11:55 PM
10k Club
Oredi 90k km n still driving
Can wait until 100k km?
sjz
post Nov 16 2013, 12:44 AM
Usual car interval is about 90k km.
For hot weather like Malaysia, the rubber will become harder faster then European countries...
So should be 60k km or 48 months whichever comes first...
SUSjolokia
post Nov 16 2013, 03:26 PM
So Hot It Burns..!!!
Yep ! agreed one must look at duration as well as mileage, city car engine which often catch in traffic jam may have higher wear & tear then the odometer record, engine is running even ur car might not move a lot.
Mileage or time period which ever come first, I remember one of my friends car timing belt snap in the middle of highway drive, the whole engine jam, almost get into nasty accident, the repair cost him many folds if the timing belt & water pump price.
Be warned.
xxboxx
post Nov 16 2013, 04:00 PM
The mind is for having ideas, not holding them
QUOTE(incredibless @ Nov 11 2013, 09:28 PM)
agreed.
better get it changed now since already 4 years plus. the belt being exposed to hot and cold, the rubber might have harden due to already 4 years +, it can easily crack and snap.
dtna7
post Nov 16 2013, 08:43 PM
you wouldn't wanna risk it to snap that could cause much more damage than just a timing belt replacement. blush.gif
but it wouldn't be wise to replace them too early as well.
I'd check the interval needed + get a mechanic to inspect it for hardening/cracks (even small ones i'd opt for a change too)
unitron
post Nov 17 2013, 06:31 AM
W1(R)3d
Get a car using timing chain instead of belt
Then no need bother replace
This post has been edited by unitron: Nov 17 2013, 06:31 AM
sjz
post Nov 17 2013, 02:57 PM
QUOTE(unitron @ Nov 17 2013, 06:31 AM)
i heard they say timing chain need replaced too, and its more expensive than replacing a timing belt..
timing chain lifespan maybe just maybe a few times longer than timing belt (90k for normal timing belt)..
This post has been edited by sjz: Nov 17 2013, 02:58 PM
0.0205sec    0.52    5 queries    GZIP Disabled
Time is now: 14th December 2025 - 02:42 AM
