 Inspira Owners required, Need advice on tyres
TS1dollar
post Oct 18 2013, 01:32 PM, updated 13y ago
For those Inspira owners who are still on Stock 16" Rims.
What tyres are you using?
Mine is long over due and i am looking to change but need some review.
Standard Continental CC5 is not too bad but I want to explore others.
Size 205 / 60 / R16 available in the market
Yokes C Drive 2
Continental CC5
Michelin XM2
Michelin Primacy 3ST
Goodyear Eagle Efficient Grip
Also need some sifoo advice on,.. IF i were to change to 225 / 55 / R16, possible ?
Technically speaking my wheels will be out of the arches by 2cm or so, right ?
With 222 / 55/ R16 i have more choices of tyres
Nexen 8000
Michelin PS3
Toyo C1S
Toyo T1
Goodyear Eagle F1 Directional
I do not want to change or up size the rims, want to maintain the original specs due to the torque and power.
Appreciate any input & advices.
This post has been edited by 1dollar: Oct 18 2013, 01:46 PM
hanif444
post Oct 18 2013, 02:42 PM
205/60x16 or 215/60x16 are best..
selinix
post Oct 23 2013, 07:14 PM
Upgrading to 17 inch won't affect your torque and power, at least this is what I felt after upgrading mine. One of the reason is that most after market rims are actually lighter than the stock 16 inch rims.
Another reason to go with 17 inch rims because you get more tyre choices and also the price difference between 16 inch tyre and 17 inch tyre is actually very minimal to no difference. Of course you get to add some aesthetic value to your car as well.
6UE5T
post Oct 24 2013, 12:45 AM
QUOTE(1dollar @ Oct 18 2013, 01:32 PM)
Yokes C Drive 2
Continental CC5
Michelin XM2
Nexen 8000
Michelin PS3
Toyo C1S
Toyo T1
Yes you can opt for 225/55/16. It won't make your tire sticks out of the fenders as you're still using the same std rims. Among the above choices of 225 tires, the best ones would be the PS3, Toyo T1 Sport, and GY F1-D5. Maybe better avoid Nexen, already got report of buldging in from one member in ZTH forum.
TS1dollar
post Oct 29 2013, 04:44 PM
thank you all for your input & advices.
nzh0920
post Oct 29 2013, 05:12 PM
QUOTE(6UE5T @ Oct 24 2013, 12:45 AM)
but the problem is 6.5j stock rim sweat.gif i think better off with 215 55 r16 smile.gif
6UE5T
post Oct 29 2013, 05:59 PM
QUOTE(nzh0920 @ Oct 29 2013, 05:12 PM)
Ok but diameter of 215/55/16 will be 1.1cm smaller than your std size, which means your ride height will also be reduced by 0.55cm. I think is best if you just stick to the original size of 205/60/16 then.
TS1dollar
post Oct 29 2013, 07:16 PM
was trying to look up for thaqt info,.. thanks!
OK so no 225 for me then HAIHzzz...
cybersonic23
post Oct 29 2013, 08:35 PM
QUOTE(selinix @ Oct 23 2013, 07:14 PM)
Hi Selinix, may i know what is the tyre size when you changed to 17 inch rims? icon_question.gif
selinix
post Oct 29 2013, 09:13 PM
QUOTE(cybersonic23 @ Oct 29 2013, 08:35 PM)
215 / 50 / r17
cybersonic23
post Oct 30 2013, 03:00 PM
QUOTE(selinix @ Oct 29 2013, 09:13 PM)
215 / 50 / r17
looks like i'll be changing to 17" rims with Achilles ATR Sport... ^^
Christina Leo
post Oct 30 2013, 05:19 PM
Tumpang tanya, whats the average price of a 17" tyre? I'm getting my inspira soon and would like to upgrade to 17" rim. Need some info on the tyre price. thanks
selinix
post Oct 31 2013, 01:42 AM
QUOTE(Christina Leo @ Oct 30 2013, 05:19 PM)
from 200 - 500+ also got.. depends on what brand you go for .. archilles , neuton , nexen are the cheaper one
0.1506sec    0.45    5 queries    GZIP Disabled
Time is now: 9th December 2025 - 10:33 AM
