 Changed username -everything gone wrong!, help needed!
TScarpathia
post Jun 3 2006, 10:54 PM, updated 20y ago
Hello guys-
i went to change the ownership name ( the house icon under the desktop icon in finder) and all my bookmarks in safari,bit torrent files and everything on my desktop is gone! i tried changing back to the original name but its not working
anyone can help or am i screwed?
vandetta
post Jun 4 2006, 04:07 PM
i've done something like that b4, and then when i restart it goes back to the same state as b4 i change the name, the name also change back to old one, not new one.. if u restart but still same prob happen, i think your bookmarks, safari setting still saved in your old profile in library or macintosh hd, can try to find it.. cannot tell u where is it because im not typing this on mac tongue.gif
wei
post Jun 5 2006, 11:28 AM
Get your Macs done right!
and why u change that?
all the setting are store inside ur user home folder.
if you want to rename it, pls use System Preferences > Accounts
to locate ur desktop's file (if OS X didnt re-built your folder) it's under HD > Users > "your account name" > Desktop
Do a repair permission and see if it fix the problem. if not you have to do a more painful rebuilting process.
This post has been edited by wei: Jun 5 2006, 11:29 AM
TScarpathia
post Jun 5 2006, 10:25 PM
Well, im already doing the painful process of rebuilding everything - luckily only my desktop files and bookmarks+ mp3 on itunes is missing - everything else on c drive still in tact.
lesson learnt.
wei
post Jun 6 2006, 08:47 AM
well to let you know what happen is actually the OS X rebuilt a fresh "User" folder after you rename it. Because OS X couldn't find the original folder (eh... where is it?).
So, my advice is to do your backup for the User folder. If you do not have the habits of putting files direct into your Harddrive. All your files that store in Documents, Movies, Musics, Pictures, Desktop. As well as your personal bookmarks, playlist, photo reel will all store in your User folder.
0.0129sec    0.52    5 queries    GZIP Disabled
Time is now: 19th December 2025 - 09:37 PM
