using adobe..
so, wut;s the size for start....
currenly i'm using
13.72cm x 8.6cm.. measure my maybank card using the ruler.. is that rite??
thanks
[help] wut is the size: card
Apr 30 2006, 12:39 AM, updated 20y ago
#1
2,723 posts Joined: Jan 2006 From: Pekopon Planet ~~~ |
i wanna design a membership card for a club.. something like KFC club, maybank card...
using adobe.. so, wut;s the size for start.... currenly i'm using 13.72cm x 8.6cm.. measure my maybank card using the ruler.. is that rite?? thanks |
Apr 30 2006, 12:59 AM
#2
1,061 posts Joined: Feb 2006 From: Out of Service |
i think all taht type of card has same size.. atm.. mycard.. even topup card.. let me scale..
are u sure u got 13.72cm x 8.6cm? coz mine is 8.6cm x 5.4cm |
Apr 30 2006, 01:02 AM
#3
Apr 30 2006, 01:11 AM
#4
6,238 posts Joined: Sep 2005 From: Kuala Lumpur |
if you use adobe photoshop, when you create a new document, you can choose to put the size in inches or cm, if im not mistaken
Apr 30 2006, 01:51 AM
#5
Apr 30 2006, 11:34 AM
#6
thanks for ur help
| Change to: | 0.0135sec
0.51
5 queries
GZIP Disabled
Time is now: 26th November 2025 - 05:20 AM |
