Sorry if it this question being asked alot.
Thanks in advance
Xbox to monitor with HDMI and DVI ports, Help thanks.
May 18 2013, 10:08 AM, updated 13y ago
#1
596 posts Joined: Jun 2012 From: Penang , Malaysia |
I was wondering when I'm my Xbox is connected to the monitor via the hdmi cable. Will there be any sound coming through my normal headphones if I plug it into my audio out port in my monitor. And what if I want to plug in my gaming headset which consist of like two cable which their heads are red and white. How can I do that?
Sorry if it this question being asked alot. Thanks in advance |
May 18 2013, 11:10 AM
#2
0 posts Joined: Aug 2012 |
There's this thing called XBOX 360 Audio Adapter. You can actually just plug behind of your monitor and plug those 2 cables in.
This is why I'm either getting a LED TV,32" or the new Astro A40 gaming headset which could cost you at RM1000+ each. |
May 18 2013, 12:41 PM
#3
148 posts Joined: Jan 2009 |
QUOTE(DanielPodolski @ May 18 2013, 11:10 AM) There's this thing called XBOX 360 Audio Adapter. You can actually just plug behind of your monitor and plug those 2 cables in. You might want to check back on the Astro headsets. Try browsing through the gaming headset thread in the hardware section here in LYN.This is why I'm either getting a LED TV,32" or the new Astro A40 gaming headset which could cost you at RM1000+ each. Been reading that the newer version of Astro headsets have problem out of the box in regards to QC. Had mine from the 2011 edition, loved it a lot |
May 18 2013, 01:55 PM
#4
QUOTE(soul_fly9900 @ May 18 2013, 12:41 PM) You might want to check back on the Astro headsets. Try browsing through the gaming headset thread in the hardware section here in LYN. They said only some will know the problem. Probably new users will not get it?Been reading that the newer version of Astro headsets have problem out of the box in regards to QC. Had mine from the 2011 edition, loved it a lot |
May 18 2013, 02:24 PM
#5
May 18 2013, 02:29 PM
#6
May 18 2013, 06:39 PM
#7
I cracked open the casing of my component cable , and fits like a charm , but , when I plug in the red and the white cable of my headset to the red and white of my component cable , still no sound . Sobs
May 18 2013, 06:41 PM
#8
Daniel , where can I get the Audio Adapter Cable? Does in fit into the slim model while the HDMI cable is still intact?
May 19 2013, 10:05 AM
#9
QUOTE(jvilous @ May 18 2013, 06:41 PM) Daniel , where can I get the Audio Adapter Cable? Does in fit into the slim model while the HDMI cable is still intact? Should be. You can check it out on amazon.comhttp://www.amazon.com/gp/product/B004TEN2T...&pf_rd_i=507846 |
May 19 2013, 10:17 AM
Where did you get yours bro?
May 19 2013, 10:20 AM
I found out that my LED TV was using that Red,Yellow and White adapter for the Astro so I tested out just now.. It work...I think.
Come online dude. |
May 19 2013, 10:31 AM
Sure sure , but I can't talk =(
May 19 2013, 03:18 PM
Guys , does the audio adapter fits in well with the xbox slim model , with the hdmi cable intact?
May 19 2013, 03:34 PM
Do you know the place where you put the XBOX VGA cable in? It should fit perfectly.
May 19 2013, 05:19 PM
Daniel , where did you get your audio adapter?
May 20 2013, 03:33 PM
I'm getting a TV this week so I won't have the much burden to get a XBOX 360 Audio Adapter from America.
May 20 2013, 03:36 PM
If you have Facebook,find KULShopper. Not sure whether is it a small S or capital S. They can get them for you.
This post has been edited by DanielPodolski: May 20 2013, 03:37 PM |
May 20 2013, 06:21 PM
Don't really trust that service though , anyone in Malaysia selling audio adapters?
May 21 2013, 09:53 AM
You can ask them about everything.. I don't know..maybe...use a TV? The pros here might know a thing or 2 the whereabout to get audio adapter here in Malaysia.
May 21 2013, 05:46 PM
Anyone ? Where to get audio adapters?
| Change to: | 0.0200sec
0.66
5 queries
GZIP Disabled
Time is now: 22nd December 2025 - 03:00 PM |
