Dota 2 - Blank screen, cant/often blank screen when alt tab
Feb 17 2013, 12:39 AM, updated 13y ago
#1
1,298 posts Joined: Aug 2006 |
any method to solve this problem? once u in game, it is not suggest to alt tab to jump out from game. It will become blank screen when u tab it back? got any solution?
Feb 17 2013, 12:43 AM
#2
2,131 posts Joined: Sep 2010 |
play at cc? its probably because ur hardware, try this. change to fullscreen, 16:9. then select the highest resolution, then change to 16:10 highest resolution. apply and try.
#3
5,144 posts Joined: Oct 2009 |
Feb 17 2013, 04:02 AM
#4
77 posts Joined: Aug 2008 From: Klang, Selangor |
change fullscreen into borderless windowed mode, but fps will drop little bit
Feb 17 2013, 10:22 AM
#5
QUOTE(am3rr @ Feb 17 2013, 12:43 AM) play at cc? its probably because ur hardware, try this. change to fullscreen, 16:9. then select the highest resolution, then change to 16:10 highest resolution. apply and try. i not believe is hardware problem.my card is 560ti with enough ram.my setting is 1920 max setting,full screen.play at cc also same with low setting.only the screen is blank,the gaming and sound still goingThis post has been edited by shinzhizu: Feb 17 2013, 10:24 AM |
Feb 17 2013, 10:28 AM
#6
Feb 17 2013, 12:53 PM
#7
QUOTE(shinzhizu @ Feb 17 2013, 10:22 AM) i not believe is hardware problem.my card is 560ti with enough ram.my setting is 1920 max setting,full screen.play at cc also same with low setting.only the screen is blank,the gaming and sound still going update graphic driver. im using the same gc without any problem |
Feb 17 2013, 12:55 PM
#8
392 posts Joined: Jun 2008 From: BATU PAHAT |
try diff resolution
Feb 17 2013, 01:24 PM
#9
753 posts Joined: Jan 2008 |
borderless window
Feb 17 2013, 03:54 PM
Feb 17 2013, 03:55 PM
Feb 17 2013, 07:26 PM
371 posts Joined: Sep 2006 |
try this right click on dota 2 select Properties and Set Launch Options, then enter the following:
-windowed -w 1920 -h 1080 -noborder -novid replaced 1920x1080 with your actual resolutions |
Feb 17 2013, 10:03 PM
That is because you are still using directx 9 or there is a -nod3d9ex in your launch command.
Im using that command and encounter the same problem and set to borderless window seem is the only solution for me. |
Feb 18 2013, 09:10 AM
Feb 18 2013, 09:11 AM
QUOTE(chesterchek @ Feb 17 2013, 10:03 PM) That is because you are still using directx 9 or there is a -nod3d9ex in your launch command. i not using the shortcut, but will check is it there got tat in the launch command.Im using that command and encounter the same problem and set to borderless window seem is the only solution for me. |
Mar 9 2013, 05:13 PM
QUOTE(chesterchek @ Feb 17 2013, 10:03 PM) That is because you are still using directx 9 or there is a -nod3d9ex in your launch command. u mean this dota 2 is using directx 10 and me currently using directx 9 will have problem?Im using that command and encounter the same problem and set to borderless window seem is the only solution for me. |
Mar 10 2013, 08:04 AM
1,701 posts Joined: Oct 2010 From: Under your bed |
Same problem when playing with laptop. just alt + D saja. lol
| Change to: | 0.0198sec
0.71
5 queries
GZIP Disabled
Time is now: 14th December 2025 - 05:25 PM |
