 Tyre recommendation for Honda Civic 2007
TSbobby1988
post Oct 27 2012, 08:45 PM, updated 14y ago
Recently I changed all four of my tyre to YOKOHAMA brand tyre for my Civic FD2. The tyre noise is so so noisy even at 60km/h.. By the time I reach 100km/h above, it is practically riding in a freaking train..
I wanna know what is suitable tyre for this car that priority is quietness and comfort ?
6UE5T
post Oct 27 2012, 10:23 PM
Try Michelin Pilot.
dixon102
post Oct 28 2012, 01:54 PM
try Michelin PS3 225/45/17. It has very good performance+queit.
nestum
post Oct 30 2012, 08:17 PM
maybe wheel bearing spoil , pls check !!
btw what model u using?
phas3r
post Oct 30 2012, 09:26 PM
What size ? If 215 45 17 u may try goodyear asymmetric 2. Around rm500 a piece. Superb grip yet reasonably quiet
Yes wheel bearing is a possibility as well
This post has been edited by phas3r: Oct 30 2012, 09:27 PM
cfa28
post Nov 1 2012, 05:23 PM
QUOTE(khinfai @ Oct 27 2012, 08:45 PM)
1. Which Yokohama model - I use C-Drive 2 and its not noisy.
2. How old is the tyre - make sure u did not get cheated by buyinng old tyres which already hardened
3. What size is your Civic - 215/45/17. Got plenty of choices. AY2 is a good choice but expensive and some say got vibration issue at high speeds.
0.2229sec    0.48    5 queries    GZIP Disabled
Time is now: 30th November 2025 - 09:26 PM
