with CL 2.5 stable at 310 MHz 2.5-4-3-8 1T ~2.85v
MemTest #5
Memtest #7
SuperPi 32M
OCCT Pass
CL 3 rock solid at 315 MHz 3-4-3-8 1T ~2.85v
TEAM Xtreem PC 4000 1GB Kit, TCCD @ 315 MHz
Feb 25 2006, 06:59 PM, updated 20y ago
#1
Validating
85 posts Joined: Jan 2003 From: Jakarta-ID |
Feb 25 2006, 11:51 PM
#2
10,688 posts Joined: Jan 2005 |
315MHz.. nyumm nyumm..
how much 1 pair cost?? |
Feb 26 2006, 12:01 AM
#3
VIP
15,903 posts Joined: Jan 2003 From: Miri |
QUOTE(gengstapo @ Feb 25 2006, 11:51 PM) 315MHz.. nyumm nyumm.. checkout babyelf's bulk how much 1 pair cost?? |
Feb 26 2006, 12:11 AM
#4
Feb 26 2006, 12:16 AM
#5
4,504 posts Joined: Jan 2003 From: Setapak |
Nice temp with high voltage. Can u give ur spec like mobo? cooler?
Feb 26 2006, 12:28 AM
#6
Validating
Thanks guys..
I'm using Air Cooling Gigabyte G-Power Pro @ Max RPM. My Venice not good enough, so i have to raise vcore to make this processor stable. This TEAM cost me 150 US$ for 1 GB Kit...i think cheap enough for TCCD chips. My Spec : Processor Athlon64 3000+ (Venice) 0520 CPMW Motherboard DFI NF4 Ultra-D VGA Card Gigabyte GV-NX68G256D-B Power Supply TAGAN U-15 580W This post has been edited by Benny Lodewijk: Feb 26 2006, 12:32 AM |
Feb 26 2006, 12:46 AM
#7
QUOTE(Benny Lodewijk @ Feb 26 2006, 12:28 AM) Thanks guys.. Open case? Can i borrow ur ram for test my both venice? Joke only. I'm using Air Cooling Gigabyte G-Power Pro @ Max RPM. My Venice not good enough, so i have to raise vcore to make this processor stable. This TEAM cost me 150 US$ for 1 GB Kit...i think cheap enough for TCCD chips. My Spec : Processor Athlon64 3000+ (Venice) 0520 CPMW Motherboard DFI NF4 Ultra-D VGA Card Gigabyte GV-NX68G256D-B Power Supply TAGAN U-15 580W |
Feb 26 2006, 02:16 AM
#8
Feb 26 2006, 03:20 AM
#9
Feb 26 2006, 04:22 AM
3,159 posts Joined: Dec 2004 From: >Taiping,Perak< |
Nice TCCD there
Mar 8 2006, 07:31 PM
1,848 posts Joined: Jan 2003 From: Boleh Land |
sweet rams, my friend is using a pair of this baby, darn clockable~~
Mar 8 2006, 11:55 PM
159 posts Joined: Jun 2005 From: Langkawi...Subang...Seberang Jaya...Sg Petani |
nice ram... can u pm me ur genie settings?
Mar 25 2006, 02:01 PM
Great result there.
Mar 25 2006, 03:10 PM
904 posts Joined: Jan 2003 From: Trg / Jay Bee |
nice temp for air cooling..
Mar 25 2006, 07:22 PM
889 posts Joined: Sep 2005 From: Malacca |
QUOTE(gengstapo @ Feb 26 2006, 02:16 AM) gosh...confirm ke if join dpt cecah 315Mhz- klu spec aku? QUOTE(ikan_semilang @ Feb 26 2006, 03:20 AM) da miskin ke? This post has been edited by nelza_ax: Mar 25 2006, 07:24 PM |
Mar 25 2006, 09:13 PM
206 posts Joined: Aug 2005 From: selangor |
kulus take tccd x-tream la.
Mar 26 2006, 08:26 PM
Mar 27 2006, 01:26 PM
8,753 posts Joined: Jan 2003 |
TCCD also can clock very high... erk.. miss my TCCD..
Mar 30 2006, 08:54 AM
4,695 posts Joined: Jan 2003 From: So would I be out of line if I said.... |
QUOTE(Benny Lodewijk @ Feb 26 2006, 12:28 AM) Thanks guys.. which bios version did u use?I'm using Air Cooling Gigabyte G-Power Pro @ Max RPM. My Venice not good enough, so i have to raise vcore to make this processor stable. This TEAM cost me 150 US$ for 1 GB Kit...i think cheap enough for TCCD chips. My Spec : Processor Athlon64 3000+ (Venice) 0520 CPMW Motherboard DFI NF4 Ultra-D VGA Card Gigabyte GV-NX68G256D-B Power Supply TAGAN U-15 580W |
Apr 10 2006, 10:28 AM
Validating
Apr 10 2006, 10:34 AM
Validating
Also i've tested Team Xtreem PC4400 1 GB Kit
![]() ![]() My genie setting : RAM Frequency 200(1/01) CPC - Enabled TCL - 2.5 Trcd - 3 Tras - 7 Trp - 3 Trc - 7 Trfc - 14 Trrd - 3 Twr - 3 Twtr - 2 Trwt - 3 Tref - 3120 Twcl - 1 Bank Interleave - disable DQS Skew - Auto Skew value - 0 Dram Drive Strength - 7 DRam Data STR - level 2 Max Async - 8ns Dram response - Normal Read Preamble - 5ns Dynamic counter - Enable idle cycle limit: AUTO R/W Queue Bypass - 16X Bypass Max - 7X 32 Byte Disable(4 bursts) vdimm 2.7v Pict after removed the heatspreader ![]() This post has been edited by Benny Lodewijk: Apr 10 2006, 10:34 AM |
Apr 10 2006, 11:03 AM
mine GSkill pc 4400 TCC5 only can get only 310 HTT for now..must tweak sum more and hope can get 320 HTT
Apr 14 2006, 01:36 AM
Oct 1 2008, 04:07 PM
153 posts Joined: Sep 2008 From: PJ |
Oct 1 2008, 09:09 PM
2,765 posts Joined: Nov 2005 From: **Hornbills** |
| Change to: | 0.0202sec
0.29
5 queries
GZIP Disabled
Time is now: 6th December 2025 - 11:46 PM |
