QUOTE(Tommykeng @ Mar 15 2012, 05:45 PM)
Naughty_Kidz , do you mean that SHOULD let headlamp Breathe So that vapour wont Stay RIGHT ?
means let air GO IN and OUT to balance the Outside Temperature Right ?
Coz I think the theory is same like , during raining day, IF WE Do not open air cond , water vapour stick inside windscreen
But after turn on Air Cond (Outside too Hot) , water vapour stick @ outside
So the BEST WOULD be balance the temperature IN and out so that no water vapour Right ??
Do i get the theory right bro ?
If my theory right , den it means my headlamp cannot BREATHE . also mean i gonna make Breathe hole LARGER??
But stock no drill hole den i also no need drill hole lor , use back stock breathe hole ok already ?
Originally isn't the hole same size? The other headlamp hole isn't it same size? So just by this question we'll know if it same and last time no problem, then surely some thing else that causes it. And the most common reason is from the silicone leak.
You can't just make breather hole and the air will circulate fast enough to make the vapor disappear, you might make it worse. Some car headlamp with breather hole actually have hose that blow air inside, then only can make the vapor disappear.
