Item(s): Note3 Aluminium Bumper (0.7mm) with Aluminium Back Cover Full Set FOC SP
for Note3
1 for RM80
BEST PRICE for Postage
1 for RM85
- High aircraft grade aluminium case anodized to create an cool style.
- Super Slim (0.7mm)
- Slim, sleek and one-piece design bumper
- FOC Screen Protector
Item(s): URBAN ARMOR GEAR for Note2 / Note3 / Galaxy S4
for UAG Note2 N7100 , UAG S4 I9500
1 for RM60 (Note2/S4)
1 for RM80 (Note3)
BEST PRICE for Postage!
Add RM5
Protect your Samsung Galaxy Note2 with a UAG Composite Hybrid case. The buttons and ports are uniquely designed for easy access and ease of use. The front of the cases are designed to maximize access to the touch screen. The low profile design easily slips in and out of pockets and fits most popular sound docks. It features a unique bezel that eliminates unwanted flash interference and ensures beautiful pictures every time. The bumpers are integrated into the overall design and maximize impact resistance. The skid pads provide grip on surfaces when your device is laying face up or down. There is a soft rubber lining that features a weight reducing honey comb pattern. This case ensures a tight fit that will not loosen over time or interfere with the functionality of your device. The included ultra clear adhesive screen protector resists scratches. This is the perfect case for those who live a rugged outdoor lifestyle.
Features:
Lightweight and Durable
No Added Bulk
Fits Device Perfectly
Impact Resistant Bumpers
Flash Bezel
Low Profile Design
Skid Pads
Ultra Clear Screen Protector Included
Hard Outer Shell
Soft Impact Resistant Core
Over Sized Buttons
Color : SCOUT (Black), OUTLAND (Rust), NAVIGATOR(White), AERO (Slate)
Item(s): Buff Armor Screen Protector for ALL PHONE
Available for Phone:
S3, S4, Note2, Iphone4, Iphone5, HTC ONE M7, Xperia Z
1 for RM35
1 for RM 40
What is the maximum level of the shock it can protect?
Buff Ultimate Shock Absorption Screen Protector may protect your device from daily life general/ accidental shocks very effectively. However, Buff may not guarantee the full protection for any intentional powerful impacts on the device. Also please note that the attached conditions of the film and device using environment may affect the level of the shock abortion film provides.
- Shock Absorption
- Air Bubble-releasing
- Scratch Proof
- Stretch Resistance
- Non Slip Grip:
Item(s): Tempered Glass-M Screen Protector
1 for RM80
1 for RM85
1) High quality tempered glass
GLASS-M is made of tempered glass, which is 8 times stronger than normal glass, high transparency, high sensitivity, delicate touch and ultra hardness which protects mobile phone screen from scratches and external shocks
2) Shatter-proof
It effectively prevents mobile phone screen from shatter once drop down the ground accidently. GLASS-M IS safe to use and passes many safety measurement.
3) Colorized optical coating
Coloried optical coating layer does not influence the screen displaying, while screen on, it keeps original high transparency and while screen off, it instantly appears amazing and dreamy color. Becomes a cosmetic mirror, you can enjoy your beauty anytime.
4) AF CLOATING
AF Coating on GLASS-M can prevent greasy dirt and fingerprint. It is easy to clean, brings you smooth surface and delicate touch.
5) Scientific thickness
6) GLASS-M is made of Asahi Glass with senior process. Its 0.4mm thickness wont affect mobile phone screen display. It not only protects your mobile phone but also keeps original mobile phone display.
7) Proprietary technology
GLASS-M is made with proprietary technology, which makes easier application. It can be used repeatedly, which adhesive residue and bubbles
Item(s): Note2 Otterbox DEFENDER KNIGHT FOC Screen Protector
Free color micro usb cable
1 for RM150
1 for RM 155
Note 2 Otterbox DEFENDER Series
The Samsung Galaxy Note 2 delivers a whole new level of innovation for the Galaxy Note category. It enables unique experiences in personalized and expressive content creation, making it the ultimate smartphone for on-the-go creativity. Don’t let this device go naked a day longer.
The Defender Series Galaxy Note 2 case delivers three layers of protection, allowing users to take their technology anywhere with the confidence knowing it's sheltered. The first layer features a two-piece inner shell with a built-in screen protector. The second layer is a silicone slip-cover that fits snugly over the inner shell, protecting against drops, bumps and shocks. A holster is included with the case and features a swiveling belt-clip that will hold the device with the screen facing in or out. Get protection that inspires confidence with the Defender Series Galaxy Note 2 case from OtterBox.
COLOUR: BLACK-BLACK / BLACK-GREY / GREY-WHITE
Item(s): USB LED Touch Light (100 lumen)
1 for RM18
1 for RM 23
USB LED Touch light :
100 lumen with 3 modes selection: Bright, Brightness, SOS (no Batteries required just plugin to Power bank)
Item(s): Note2 NFC Tags
1 for RM25
Package for Aluminium Back Cover with NFC Tags is RM70
1 for RM 30
Here is the solutions for Note2 Aluminium Back Cover with NFC Tags
Item(s): Tactical Utility Bag Pouch
1 for RM120 (for Black Color)
1 for RM140 (for Other Color)
1 for RM 130 (Black Color), RM150 (Other Color)
- having problem with your Smartphone where to put, here is Pouch.
- Waterproof
- for S3, Note, Note2 or Other Smartphone
Item(s): X6 Phone Holder for Car
for S2, S3, Note, Note2 or Other Smartphone
1 for RM60
1 for RM 70
Item(s):Note1 Aluminium Back Cover
1 for RM40
1 for RM 45
-Aluminium back housing case battery cover.
-Distinctive and elegant appearance, make your phone look more exquisite and classic.
-Skin-tight, Lightweight, Durable and Stylish.
-Works great in protecting the internal components of your phone from scratches, bump and dirt.
-Slim and compact design, perfectly fit for your phone.
Color: All Color
Item(s): Galaxy Note2 Aluminium Bumper FREE stylus pen
1 for RM 80
1 for RM 85
CNC machined from a solid block of aircraft grade aluminum.
High grade aluminum case anodized to create an cool style.
Made of two parts, one for back and one for front to combine into one.
Item(s): Galaxy Note2 Aluminium Bumper & Back Cover
1 for RM 60
1 for RM 65
Item(s):Note2 Aluminium Back Cover
1 for RM20
1 for RM 25
Color: All Color
Item(s):mico usb color cable (2 meter)
for S2, S3, Note, Note2, Sony, HTC and Android phone
1 for RM16
1 for RM 20
color: Black, Red, Purple, Yellow, Blue, Orange, Green
Item(s):S3 Aluminium Back Cover
1 for RM40
1 for RM 45
Color: Red, Blue, Green, Silver, Grey, Black, Gold, Purple, Rose Red
Item(s): SGP Galaxy S3 Neo Hybrid
1 for RM 45
1 for RM 50
SPIGEN SGP Galaxy S3 Neo Hybrid is an assembly-type case with a TPU back cover and a polycarbonate frame. Neo Hybrid is form-fitted to effectively protect your phone from external impacts. Neo Hybrid is designed to highlight the curves of the Galaxy S3. Galaxy S3 Neo Hybrid fits precisely onto the phone for a natural and sleek look. Made with a new TPU material, the Neo Hybrid will not sag or expand due to the heat of the device.
Color : Red, Green, White, Yellow
Item(s):SGP Mobile Stand Kuel S20 for Galaxy S3
1 for RM50
1 for RM 55
•Compatible with case equipped mobile devices
•Can be rotated 30 degrees in any direction
•Gel Type Suction Cup and Suction Lever work together to secure the S20 on any flat surface
•Can be cleaned easily with water
•The ball-and-socket joint inside the S20 adds extra frictionmto secure the stand in any angle
•Free Stop Hinge easily adjusts and holds the stand firm at any angle
•Gel Type Suction : Polyurethane + Elastomer
for Galaxy S3, Galaxy S2, Iphone 4, Iphone 4S
Color: Red, Blue
Item(s): Power4 Flowing Light Visible micro usb cable for Samsung Phone and Tab
1 for RM 50
1 for RM 55
- Charges USB-enabled devices with flowing LED light.
- Visible LED light flowing speed indicates charging rate and status.
- Compatible with Samsung Galaxy Tab, Galaxy Note, Galaxy S2 , Galaxy S3, cameras and more.
- Prevent phone or tab battery over charge.
Color : Black/Blue, White/Green, Pink/Blue
Item(s): PINENG Universal 5600mAh Power Bank External Battery
Grade A++ (Aluminium Housing)
1 for RM 110
1 for RM 115
Perfect companion for iPhone 4S, 4, iPad 1, iPad 2, iPod, Samsung S2, Galaxy Note and other devices. And most importantly is its user-friendly size and portability.
-Super-bright LED Flashlight can work above 600 hours after fully charged.
- Enjoy 25 hours Movie time for iPhone 4S 4 3Gs 3G and iPod Touch 1G 2G 3G 4G 5G .
- Capacity 56000mAh: Can charge up to 200% of iPhone 4 battery capacity.
- Compatible with iPhone 4S 4 3Gs 3G, iPod Touch (1G 2G 3G 4G 5G), Samsung, LG, HTC, Sony Ericsson,Nokia,Sony PSP, Tab, PS Vita and much more.
SPECS:
- Model: PN-906
- Input: DC4.8-5.2v 1A(max), Output: 5V-1000mA
- Weight: 136g
- Dimension: 76 x 58 x 21mm
- Battery Capacity: 5600mAh
- CE, FC, RoHS Authentication
Colors: Silver and Grey
Item(s): 2.1A USB FAST Charger
1 for RM 45
1 for RM 50
- for All Samsung Android Phone (Galaxy Note, Galaxy S3, Galaxy S2, Nexus)
- Faster then original charger (original is 1.0A)
- For other Devices also can is USB port
- Galaxy Note 2500 mah less than 2 hour
Item(s): New Design Galaxy S2 Aluminium (Just slot in like note aluminium)
1 for RM 60
1 for RM 65
Item(s): Galaxy Note Aluminium Bumper Free Screen Protector & stylus pen
1 for RM 70
1 for RM 75
Item(s):Galaxy S2 SGP Linear
1 for RM 38
1 for RM 40
SGP Linear Case is composed of 3 separate pieces : upper frame, lower frame and back cover. It is available in 6 Pure Series and 8 Color Series! From Modern and Gentle to Romantic and Humorous, each differently colored piece can be combined to create a personal Linear Case.
Item(s): Galaxy S3 Aluminium (New design for side button)
Free USB cable (While stocks last), Free HD Screen Protector
1 for RM 65
1 for RM 70
Specifications:
- All Aluminum construction made from 6061 T-6 anodized aluminum.
- CNC Machined from solid Billet for ultimate durability and precise fit.
- 6 sided protection defends Samsung S3 against shocks, drops and movement.
- Weighs 28 grams, less than an ounce.
- Balanced feel and easy access to all buttons, sim card, headphone jack and charging slot.
- Zero grounding precise fit; metal does not touch any part of the antennae.
Color : Red, Blue, Silver, Grey, Black, Gold, Purple, Green, Sky Blue, Rose Red
Item(s): USAMS Dual USB Port Car Charger
1 for RM 35 / Free Poslaju
Perfect companion for iPhone 4S, 4, iPad 1, iPad 2, iPod, Samsung S2, Galaxy Note and Galaxy TAB other devices.
Main Feature:
Suitable Model: iPhone/iPod/iPad 1/iPad 2/The New iPad 3rd
Material: ABS engineering plastic
Double USB interface, different power, car supplies
Input: 12-24V DC
Output: 5V-3.1A
Specification:
Weight: 10 g
Package:
1 x car charger
Colors: WHITE / BLACK
Item(s): Galaxy Note iMak Anti-Dust Silicone Case Free HD screen protector
1 for RM35
1 for RM 35
- Well designed slot for buttons
- Protects the sides of your Samsung Galaxy Note from scratches and dirt
- Offers protection when your Samsung Galaxy Note is falling down
Color: Black, purple, orange, rose red
Item(s): Galaxy Note Leather Belt Pouch Holder
1 for RM 50
1 for RM 50
Item(s): Galaxy S2 SGP Neo Hybrid
1 for RM 35
1 for RM 38
high polymer coated Premium silicone case, and the Frame part is UV coated Polycarbonate frame
**********************IMPORTANT READING *******************************
- All prices shown is best price already.
- COD available
Areas includes: Kepong, Jalan Ipoh, The Curve,Kota Damansara, Kelana Jaya, Sri Hartamas.
Questions? Feel free to contact me!
Call/SMS : 018.2709083
PM or Email: ocase555@gmail.com[/b]
This post has been edited by ocase: Feb 19 2014, 11:48 AM
Mar 6 2012, 06:01 PM, updated 12y ago
Quote
0.0352sec
0.40
6 queries
GZIP Disabled
