http://www.majorgeeks.com/download7587.html
- initial release for Windows 8 by Shark007
- highly optimized playback
- based solely on the LAV filters
- will also work on Windows 7
QUOTE
ENJOY FULL PLAYBACK OF ALL OF YOUR MEDIA FILES WITHOUT BREAKING YOUR SYSTEM.
MKV playback is fully supported including thumbnailing. You can choose any media player you want, everything will play.
H264 / AVC, hi10p / 10bit codecs are available for use by all players.
The following filetypes are enabled and SUPPORTED by the installation of the Windows 8 Codecs.
amr | mpc | ofr | divx | mka | ape | flac | evo | flv | m4b | mkv | ogg | ogv | ogm | rmvb | xvid
All of the above filetypes can be queued to the Windows Media Player Playlist using a right-click.
It does not contain a media player and it does not associate file-types. With the Windows 8 codec package installed you will be able to use any media player, limited only by the players' capabilities, to play all movies and video clips. Streaming video is supported in several formats in all popular web browsers. Users of the Windows 8 media center codecs have the ability to choose what is installed and where to install it using the public redistributable. After installation you can select to remove specific portions without removing the entire package. You can also re-add the removed items at any time.
The Windows 8 codecs installation supports 20 localizations. The default is English and the installer includes support for the following other languages; Arabic, Chinese Simplified/Traditional, Japanese, Czech, Danish, Dutch, Finnish, French, German, Greek, Italian, Norwegian, Portuguese, Russian, Spanish, Polish, Swedish and Turkish. Languages can be added upon request.
It is required that you rightclick the installed Settings Application shortcut found on the menu, Start Button\All Programs\Shark007 Codecs and choose 'Run as Adminstrator' to complete the installation setup.
PLEASE UNINSTALL you old version before installing a newer release.
The Windows 7 release = 27MB - This release = 14.7MB >> Biggest difference? ffdshow and gabests filters are removed.
Developer's site: http://shark007.net/win8codecs.html
This post has been edited by cybpsych: Jun 18 2013, 06:52 AM
Mar 1 2012, 09:27 PM, updated 13y ago
Quote
0.0449sec
0.87
5 queries
GZIP Disabled
