Outline ·
[ Standard ] ·
Linear+
tiles chip, how to fix it?
TSxSean
Dec 5 2011, 02:41 PM, updated 15y ago
is there any solution to fix/cover tiles chip?
after reno and move in things, found out so many small chips...some quite big like 4-5mm...
my tile is beige color with some white color...so i think it can be cover with white color ...
what things that can be use to cover/fix it?
weikee
Dec 5 2011, 02:52 PM
TSxSean
Dec 5 2011, 03:04 PM
QUOTE(weikee @ Dec 5 2011, 02:52 PM) weikee, i've tried white cement...and it not waterproof..somemore i rub with my finger and it will gone... not try the white acrylic sealer/caulk
weikee
Dec 5 2011, 03:08 PM
Sure you use cement, or just putty? I use white cement and it really strong as cement. And apply a sealer on top too.
ozak
Dec 5 2011, 03:46 PM
TSxSean
Dec 5 2011, 03:53 PM
QUOTE(ozak @ Dec 5 2011, 03:46 PM) i tot is different things.. ozak, still use the caulk to fix it? thanks
ozak
Dec 5 2011, 04:40 PM
QUOTE(xSean @ Dec 5 2011, 03:53 PM) i tot is different things.. ozak, still use the caulk to fix it? thanks I use it to fill the gap.
@Adele
Dec 5 2011, 05:05 PM
Ya I also got this problem le. Only my Niro and feruni tiles hv absolutely no problem. The rest like guocera, white horse and alpha all chipping badly. Worse still my tiles are dark brown in color. Also looking for ways to cover it up...help!
weikee
Dec 5 2011, 05:29 PM
caulk got come in black color gray hard to find.
TSxSean
Dec 5 2011, 09:16 PM
QUOTE(weikee @ Dec 5 2011, 05:29 PM) caulk got come in black color gray hard to find. weikee, what is the different silicone sealant vs caulk? i see the pic, caulk just look like silicone sealant.... Added on December 5, 2011, 9:17 pmQUOTE(weikee @ Dec 5 2011, 03:08 PM) Sure you use cement, or just putty? I use white cement and it really strong as cement. And apply a sealer on top too. the sealer? is it sealer for paint? This post has been edited by xSean: Dec 5 2011, 09:17 PM
weikee
Dec 5 2011, 09:43 PM
Caulk is just a term. You have Silicon and Acrylic. Acrylic, can be paint on, Silicon you can't. But silicon more lasting.
TSxSean
Dec 6 2011, 01:27 AM
QUOTE(weikee @ Dec 5 2011, 09:43 PM) Caulk is just a term. You have Silicon and Acrylic. Acrylic, can be paint on, Silicon you can't. But silicon more lasting. u mean silicone sealant is also silicone caulk?
