 Lighting Control System, Anyone knows any good one?
TSBishop
post Nov 26 2011, 10:40 PM, updated 15y ago
Diagonal Views
Just helping out a friend. He has about 4 groups of 6 x 3 gangs light swithes in his living and dining area(connecting space) That makes 72 switches in one space. rclxub.gif
Dunno if it was the designer's fault or the electrician fault but that is a LOT of switches in one space. Wiring all done but not yet install the switches.
Anyone knows of any lighting control system/home automation system that works and have after sales support? It needs to be connected at the switch area and not to the light fitting itself.
(if not then he can play guess the switch everyday whistling.gif )
weikee
post Nov 26 2011, 10:57 PM
10k Club
QUOTE(Bishop @ Nov 26 2011, 10:40 PM)
Did you ask how much is the wiring cost?
TSBishop
post Nov 27 2011, 01:57 PM
Diagonal Views
QUOTE(weikee @ Nov 26 2011, 10:57 PM)
We were called to assist after the owner terminated the previous designer. blink.gif sweat.gif
JinXXX
post Nov 27 2011, 03:20 PM
possible to "hook up and join" the wiring at the switch wall then only pipe it to the new switch
if you looking for lighting switching control for that amount of lights won't be cheap i think..
http://www.digitallighting.com/animationfo...x%20dimmers.htm
http://lightingcontrols.com/productcatalog/index.asp
http://www.dalicontrol.com/products/dali_control_products
This post has been edited by JinXXX: Nov 27 2011, 03:22 PM
weikee
post Nov 27 2011, 05:42 PM
10k Club
QUOTE(Bishop @ Nov 27 2011, 01:57 PM)
Only rich people easy get slaughter lah. 72 switch actually a good point to do automation system.
TSBishop
post Nov 28 2011, 12:32 PM
Diagonal Views
QUOTE(JinXXX @ Nov 27 2011, 03:20 PM)
Have you used any of them before? Are they reliable?
Read of many systems but want some first hand experience of the products. Reviews cannot be trusted.. whistling.gif
Added on November 28, 2011, 12:36 pm
QUOTE(weikee @ Nov 27 2011, 05:42 PM)
This post has been edited by Bishop: Nov 28 2011, 12:36 PM
JinXXX
post Nov 28 2011, 12:39 PM
QUOTE(Bishop @ Nov 28 2011, 12:32 PM)
nope.. cause mostly ppl who use lighting control are
1. commercial buildings..
2. demo houses/super millionaire houses smile.gif
TSBishop
post Nov 28 2011, 12:51 PM
Diagonal Views
QUOTE(JinXXX @ Nov 28 2011, 12:39 PM)
Now headache. They want to install the switches already and I don't think they realize how many switches there are... rclxub.gif
JinXXX
post Nov 28 2011, 12:58 PM
found a few more lighting control but not in malaysia i think
http://www.simplesolutionsdigital.com/products.php
http://www.futronix.com/home-icon_touch_screen.php
seems like hager also got lighting control..
http://www.hager.co.uk/building-automation...bis-tx/5443.htm
maybe u can check with hager malaysia
This post has been edited by JinXXX: Nov 28 2011, 01:00 PM
TSBishop
post Nov 28 2011, 01:05 PM
Diagonal Views
Anyone with first hand experience? Every product site I go to all say that they are the best. Which one has after sales service. That is why I am reluctant to get it from overseas.
The DALI system you referred to is from Clipsal/Schneider. I wonder if the local supplier has it.
ozak
post Nov 28 2011, 06:13 PM
10k Club
http://SmartHouse.my/ or http://www.smarthouse.com.my/default.asp or http://www.newict.com/
All this are local. The famous and oldest I have check before is X10. Still got few from local but lazy to search the brochure.
pky
post Nov 29 2011, 01:16 AM
Should discuss with the owner how he want the light switching to be such as any group switching needed. Any dimmable light fittings? From here, only decide what control system u need.
Lighting control system could be an overkill for normal houshold application and usually used for area which have lots of lighting and switching sequence such as ball room/convention centre etc.
0.0175sec    0.62    5 queries    GZIP Disabled
Time is now: 11th December 2025 - 10:42 AM
