 lightning fried my ethernet port, how to check if other hardware affected?
TSgooni3
post Nov 14 2011, 08:43 PM, updated 15y ago
guys, i desperately need ur help
few days ago, there was a thunderstorm and it happened to fried both my computers' ethernet port, both my computer was on (was switched off before i went out, powered up by lightning, is this even possible?) both had errors.
okay after i restarted it, everything was fine except the ethernet ports. none were detected (device manager doesnt show)
my question is,
1. how to check if other hardware is affected?
2. i do not want to wait until something fails only to find out about it =(
Additional info,
1. my computer is fairly new (less than 6 months) and it's under warranty, the motherboard's ethernet port is screwed (i probably change the motherboard with warranty)
2. no burnt smell that i notice of. ( i assume the lightning goes in thru the router and reach my computer, but my modem is fine - using unifi, fibre optics can get zapped? )
SUSHuman10
post Nov 14 2011, 08:49 PM
QUOTE(gooni3 @ Nov 14 2011, 09:43 PM)
my question is,
Additional info,
Strike by lighting, i bet 90% chance that it cant be warranty(most warranty sure exclude burn and lightning). Another 10% is you somehow to "tipu" them that it is like that, not by lightning.
jiraiya77
post Nov 14 2011, 09:15 PM
are you sure it ethernet port that fried?i think its ur modem.happen to me last time.i change my network adapter.still cannot connect to internet.at last,buy new modem.problem settled.
Einstien
post Nov 14 2011, 10:05 PM
i recently had the same prob with a Gbyte board lightning strike burn my modem also but send to SDS for warranty the Realtek lan controller got one hole also but they still warranty for me . Just try to warranty see your luck
marsha1l
post Nov 14 2011, 10:18 PM
water-cooling PC enthusiast
and i dont think the lightning strike would suddenly switch on ur computer impossible..unless the pc wasnt properly shutdown?..
the power would fry the modem before it could reach ur pc..
anyway..try check ur modem first..but since u use optic cable...i dont think ur modem is fried..but just double check..
Neo|ofGeo
post Nov 15 2011, 12:22 AM
Stop Complaining and Read
Elite
QUOTE(marsha1l @ Nov 14 2011, 10:18 PM)
well exception for apartment since they still use copper
but does TS live in apartment i don't know = =''
TSgooni3
post Nov 15 2011, 01:40 PM
i dont live in apartment
erm.. the modem i'm quite sure didn't fry.. because all other wireless network devices still able to connect to the modem
thing is.. i cannot even detect the Ethernet port under device manager =(
marsha1l
post Nov 15 2011, 02:06 PM
just double check the modem with other pc?..
and ethernet port..what measure did u take to troubleshoot it?..mind telling us..
try download the driver?
TSgooni3
post Nov 15 2011, 02:23 PM
it won't install the driver..
okay.. let me put this clearly again.
On my first pc, the Ethernet port is connected to the motherboard (onboard ethernet port) the light is still on when I plug out the cable. (i'm not sure if the light should always be on or not) so, i'm assuming the port is spoilt since the light should be off once you remove the cable? windows error msg shows please install driver if you have a network adapter (windows 7) - but cannot install cause cannot detect under device manager - if the port is onboard port can it be detected under device manager under network adapters?
On my second pc, the Ethernet port is a separate card connected to the motherboard (RM50) and doesn't light up even after I plug in the cable. (Card can be detected under device manager and it says device is working properly)
On my modem currently, there is no light on all 4 Ethernet ports. Other than that, all wireless devices are working
I'm probably suspecting the port on my first pc is spoilt and the modem is probably faulty also on the Ethernet cable side.
update : i noticed my first pc's lan port has 2 lights (1 is off, the other is on, yellow colour)
motherboard model is P67A-UD3-B3
This post has been edited by gooni3: Nov 15 2011, 02:32 PM
marsha1l
post Nov 15 2011, 03:06 PM
QUOTE(gooni3 @ Nov 15 2011, 02:23 PM)
it should not light up after u disconnect the cable..
anyway..unifi user will use 2 device..one is the modem which is the big white device and a wireless router..which light on the modem switched on?
correct me if im wrong regarding the device that tm provided..
TSgooni3
post Nov 15 2011, 03:08 PM
no, the modem PORT lights are all off even after i plugged in all the Ethernet cables
there are 4 ports. i plug in 4 cables all off. normally at least 3 will light up
marsha1l
post Nov 15 2011, 06:29 PM
ok the port light is off...wat about the other light which indicate the power and the internet connection isp?..
if those light are on..u need to try configure the modem again..using hyperterminal..
TSgooni3
post Nov 16 2011, 01:40 AM
the rest all on
Dennos
post Nov 16 2011, 07:58 AM
giga mobo can warranty, i used to warranty mine two years ago. There's a significant burn mark behind the mobo.
TSgooni3
post Nov 20 2011, 01:59 AM
guys.. i trouble shoot already..
there are 4 ports on the dir 615 modem. 2 of them are fried, which the same 2 connected to my both comps killed the ethernet port
guess need to call tmnet to change the modem, as well as claim the giga motherboard warranty..
gonna think of surge protector next..
i tested it with a brand new router..
marsha1l
post Nov 20 2011, 02:03 AM
wow..using optic fibre can still get fried eh..hahaha...thx for the good info..
mekboyz
post Nov 20 2011, 02:16 AM
QUOTE(gooni3 @ Nov 20 2011, 01:59 AM)
btw semi-related- dont use the unifi dlink modem tmnet gave you. it is horrible. there are better alternatives
http://klseet.com/index.php?option=com_con...id=42&Itemid=39
sniper69
post Nov 20 2011, 08:47 AM
.: One Shot One Kill :. .+|Level 9 Type Shit|+.
ligthning still fry your hardware, the most safest way, unplug all wire connected, the power cable, the RJ-45 that connected to your PCs, the RJ-11 (Streamyx) that connected to modem. i'm not sure about Unifi though, as i don't have Unifi. but still, same concept applied to it. unplug it all.
about warranty, just send them to warranty, say that you don't know anything after switch it on. settle. that works everytime. i mean, how the hell do we know we got strike by lightning right? be really n00b in this matter, HAHAHA
DarkSilver
post Nov 20 2011, 10:39 AM
Idiosyncrasy
Elite
Just send it to WARRANTY if it doesn't have any physical damage which is visible on the Motherboard like burn marks, bended, black stain, etc. But, don't tell it's died to due lightning strike. Just tell them, it's malfunction all in a sudden.
I'd encountered this problem before. My Ethernet Port died due to lightning strike, I sent the Motherboard to warranty and I've a fixed Motherboard back weeks later.
Lightning loves Ethernet Port.
Next time, use a USB WiFi Adapter.
sniper69
post Nov 20 2011, 11:02 AM
QUOTE(DarkSilver @ Nov 20 2011, 10:39 AM)
if only the wifi is reliable good as LAN connection, i mean for gaming purposes, Wifi would do any better?
2 Pages  1 2 >Top
0.0181sec    0.25    5 queries    GZIP Disabled
Time is now: 15th December 2025 - 06:06 AM
