Bump TopicReply to this topicRSS feed Start new topic Start Poll
> Myvi AirCon, Super loud air con
zero88
post Nov 8 2011, 07:29 PM, updated 7y ago
Group: Junior Member
Hello,
Have a 2007 1.3 (A) Myvi. Since day 1 the aircon compressor has been super loud. The engine itself is silent on idle. When the air con compressor kicks in, I think the whole taman can hear the car !
Aircon has also lost coldness. Tried refilling gas, but no change.
Have been told that myvi aircon's are 'memang loud', to the possiblility that the compressor oil is too little.
Any guidance, suggestions sifu's?
vr2turbo
post Nov 8 2011, 09:03 PM
Group: Newbie
Check with air con mechanic.
Basically the air con system have compressor, condenser, cooling coil, receiver drier and expansion valve.
Since it is already 4 years, maybe you need to change the receiver drier, check the expansion valve
how_88
post Nov 8 2011, 09:08 PM
my myvi air-cond feel like driving rocket....
change compressor still same
vr2turbo
post Nov 9 2011, 07:45 AM
Group: Newbie
QUOTE(how_88 @ Nov 8 2011, 09:08 PM)
Was it compressor problem in the first place?
zero88
post Nov 9 2011, 03:17 PM
QUOTE(vr2turbo @ Nov 8 2011, 09:03 PM)
hey, thanks for the feedback !
Any mech recommended? I stay in PJ. Did try take it to one air con specialist, he wanted rm250 to do a full service. Felt that was a bit too steep, altho he is known for good work. Decided to just fill gas instead, but problem still persists.
vr2turbo
post Nov 9 2011, 06:10 PM
Group: Newbie
QUOTE(zero88 @ Nov 9 2011, 03:17 PM)
Not the gas fault then, something is still wrong. By air con service, does he mean removing the cooling coil to be washed, change the gas (refrigerant), then may cost that much....
I have mechanic in Puchong, will pm you his address. See if you want to try him out.....
anubis808
post Nov 10 2011, 11:00 PM
PM his address too. Need to service my air cond
vr2turbo
post Nov 11 2011, 07:29 AM
Group: Newbie
QUOTE(anubis808 @ Nov 10 2011, 11:00 PM)
Okay, done.....
zero88
post Nov 11 2011, 04:56 PM
QUOTE(vr2turbo @ Nov 9 2011, 06:10 PM)
Yup, remove cooling coil for washing, changing refrigerant and labour. Basicly he said 'take everything out and do'.
Sorry, still pretty noob regarding car aircon's laugh.gif . Is rm250 a reasonable price for all that?
I did drop by the P2 SC and ask, they quoted air con service at rm 125. Forgot to ask what exactly that includes... blush.gif
any suggestions, boss?
vr2turbo
post Nov 12 2011, 11:25 AM
Group: Newbie
Not too sure how much the charges, but to dismantle cooling coil to clean, and if including the gas prices then should be cheap.
Air con service also have the chicken and egg problem.
Some will service their air con yearly to prolong it's use. I am old school so I will repair the air con only when got problem. For some cars nowadays have cabin filter so no need to remove cooling coil to clean but just change the filter.
Jason
post Nov 13 2011, 02:03 AM
Group: Senior Member
service air con..always go back to Denso for Myvi.. the prices in Denso & outside shop same same, you're better off going back to the people who made the air conditioning compressor.
and air con is a hit and miss lah.. my friend's Myvi, 2005.. on his third compressor now.. my Myvi 2006.. used original compressor until now..
I only did service once, last year, at Vision Bangsar, they are authorized and official Denso service centre, and they have the equipment to fully change the compressor oil -- everywhere else they only refill/top up the oil cause no equipment. also, they have the equipment to check the compressor's pressure.. if insufficient pressure..then naturally it won't be cold lah. don't simply go air con shop..go to the experts.
This post has been edited by Jason: Nov 13 2011, 02:04 AM
vr2turbo
post Nov 13 2011, 04:12 PM
Group: Newbie
So far all air con shops I have been to, uses a meter to refill the refrigerant. Cannot agar agr one, and have to be accurate. Too little or too much also will not be cold. Too much , is worst may overpressure and burst some hoses.
Air con fan not working the pressure also will go up.....too hot......
glareguard
post Nov 15 2011, 10:20 PM
would like to know how often do we have to service the aircon. my car is 4 years old and have not service before. only turn on the aircon when it is weather is hot. or when family is in the car.
vr2turbo
post Nov 16 2011, 01:30 PM
Group: Newbie
What do you mean by service? Change the refrigerant and re-oil the compressor or take out the cooling coil to be washed? Some cars are equipped with cabin filters nowadays, so they only change the filter.
As for the refrigerant and oil, some do it yearly, some do it once in two years and old school like me, only do it when there is problem with the air con. So the choice is yours...... tongue.gif
taaron
post Nov 17 2011, 11:00 PM
are there any other alternatives besides original Denso a/c compressor for myvi? just wondering if there are aftermarket for those.. at times quite annoying due to the noise of the compressor sad.gif
vr2turbo
post Nov 18 2011, 08:11 AM
Group: Newbie
QUOTE(taaron @ Nov 17 2011, 11:00 PM)
Usually cooling coil maybe not, unless different brands also make for Myvi. As for compressors depends on the bracket and place for mounting. My old Sonata original compressor cost RM1300, so my mechanic changed the bracket and mounted another brand on for me which cost RM600..... rclxms.gif
taaron
post Nov 18 2011, 01:26 PM
QUOTE(vr2turbo @ Nov 18 2011, 08:11 AM)
ok..so basically it's just about the mounting issues..bro, do you think if i change to other car's compressor (which is originally quiet), will installing that into my car the noise also will be quiet?
vr2turbo
post Nov 18 2011, 01:31 PM
Group: Newbie
If the original compressor is really noisy, then yes, but best to check with your mechanic whether can be done or not?
taaron
post Nov 18 2011, 01:39 PM
QUOTE(vr2turbo @ Nov 18 2011, 01:31 PM)
vr2turbo
post Nov 18 2011, 01:43 PM
Group: Newbie
QUOTE(taaron @ Nov 18 2011, 01:39 PM)
you are welcome.....
zero88
post Nov 18 2011, 04:05 PM
QUOTE(Jason @ Nov 13 2011, 02:03 AM)
Hi, mind to share how much the damage to pocket was?
maybe can be used as reference for other people who drop by the thread too.... thumbup.gif
Jason
post Nov 18 2011, 04:55 PM
who say no alternative? never read Myviclub.com? lol. You can use Avanza's piston-type compressor. I am using it now, damn cold even under hot sun, as long as vehicle is moving. of course idling its not so cold, but still colder than original. Avanza is a bigger car.. so air con also colder.
QUOTE(zero88 @ Nov 18 2011, 04:05 PM)
can't remember was between rm150-250. work was about 3-4 hours..they will change all the oil, and also test the compressor, and refill gas if required. very professional. although they deal in high end cars, Lexus, Altezzas, Veilfires.. their staff are friendly and I feel the price I paid is reasonable.
vr2turbo
post Nov 18 2011, 05:52 PM
Group: Newbie
Bro. Jason,
You use piston type compressor, is not heavier for your car engine??
taaron
post Nov 18 2011, 07:08 PM
QUOTE(Jason @ Nov 18 2011, 04:55 PM)
i didn't research much on aircon previously, just that suddenly i felt that compressor noise is very annoying especially during listening to my ICE..
btw bro, since you have used Avanza's a/c compressor on ur myvi, how is the noise? cut down by alot, or still same noisy? Apart from that, are there other a/c parts besides the compressor that you swap in to the myvi?
vr2turbo
post Nov 18 2011, 07:47 PM
Group: Newbie
Is the Myvi air con compressor that bad. I have a few colleague with Mvyi but never heard them say anything about compressor noise??
cheelam
post Nov 23 2011, 01:25 PM
Group: Newbie
QUOTE(taaron @ Nov 18 2011, 07:08 PM)
I doubt the noise is from compressor as it could hardly be related to the ICE system.
QUOTE(vr2turbo @ Nov 18 2011, 07:47 PM)
Agree that Myvi has less problem on the compressor part. Mostly it encounters the heat distribution issues.
Added on November 23, 2011, 2:30 pm
wow.. Myvi uses Avanza's piston-type compressor?!
Just curious how it is modified (i.e. bracket, hoses...) ?
It consumes more power from your engine if compared to original compressor, doesn't it?
This post has been edited by cheelam: Nov 23 2011, 02:30 PM
taaron
post Nov 23 2011, 02:33 PM
QUOTE(cheelam @ Nov 23 2011, 01:25 PM)
what i meant was I don't feel comfortable with other noise while listening to my ICE setup..it is disturbing..try listening to other car with ICE setup, it felt much better as other noise is not much apparent..
cheelam
post Nov 23 2011, 03:21 PM
Group: Newbie
QUOTE(taaron @ Nov 23 2011, 02:33 PM)
Hmm~ it's better to check where the noise is from since it annoys you so much. Sometimes noises may come from other parts such as belt... if it is related to air-cond.
How long have you been servicing your car air-cond?
Could find any car accessory shop or air-cond service centre for advice.
vr2turbo
post Nov 23 2011, 05:54 PM
Group: Newbie
Normally air con compressor only noisy when going to break down...... sad.gif
Jason
post Nov 24 2011, 12:13 PM
QUOTE(vr2turbo @ Nov 18 2011, 05:52 PM)
Bro. Jason,
don't notice the noise.. i just swap the compressor.. thats all.. condenser and the rest all original. my original myvi compressor also no noise. i do hear the compressor when it kicks in, but no funny noise or irritating noise.
what do you mean by "bad"? as i've said..its a hit or miss.. i have one buddy on his third compressor, another one his second, myself on the original one till q3 this year. there are people with brand new myvi with problems.. noisy compressor when kicks in.
vr2turbo
post Nov 24 2011, 02:49 PM
Group: Newbie
QUOTE(Jason @ Nov 24 2011, 12:13 PM)
Jason
post Nov 24 2011, 03:14 PM
well.. he said its loud.. loud is relative.. for someone who sat in a 20 year old saga..then sit in myvi he feel the car is quiet.. for someone who sat in porsche panamera then sit in bmw 3 series will feel the bmw is loud..hard to diagnose really.
cheelam
post Nov 24 2011, 04:33 PM
Group: Newbie
get someone experienced/professional to check on the spot instead of keep guessing here without knowing the main cause ^^
vr2turbo
post Nov 24 2011, 09:06 PM
Group: Newbie
QUOTE(Jason @ Nov 24 2011, 03:14 PM)
If drive the car then yes, sound proofing and all that play a part, but not just the air con compressor.
Well, bro. cheelam is correct, and have actually ask him to see a mechanic on this....
zero88
post Nov 25 2011, 01:10 AM
Hello, havent had time to head to the mech yet. Will definitely update here once I have done so.
I can only compare it to the other car I drive, a 11 year old iswara which had it's aircon serviced only once in all tht time. The myvi aircon is super loud when the compressor kicks in as compared to the 11 year old junk. doh.gif
gkl83
post Nov 25 2011, 01:15 AM
i also driving 2007 Myvi... so far never service air con too and still working fine...
hence the sound of compressor wasnt that loud, only the spinning fan is louder than compressor... smile.gif
vr2turbo
post Nov 25 2011, 07:39 AM
Group: Newbie
I thought the Persona fan is the loudest, so high pitch when spinning......
Normally if compressor loud or anything for that matter, means some problem..... sad.gif
This post has been edited by vr2turbo: Nov 25 2011, 07:40 AM
cheelam
post Nov 25 2011, 11:30 AM
Group: Newbie
hey guys,
If the sound is annoying, get mechanics/technicians to give proper advice smile.gif then we'd discuss further here...
There are ways to settle such problem. If that's the nature of your car, then sorry to say IT'S TIME FOR A NEW CAR~ Or just BEAR WITH IT biggrin.gif
By the way, it's advisable to do air-cond service within 1 - 1.5 years. It involves a simple but essential cleaning process, i.e. cleaning the cooling coil, blower fan... in order to keep it young and healthy.
Prevention is better than cure. Cure will cause a large amount of $$. Be a smart driver!
Recommend: Welcome to PM/Visit us for any air-cond related issues or sevices. tongue.gif
ThunderGod_Cid
post Nov 25 2011, 01:24 PM
QUOTE(vr2turbo @ Nov 25 2011, 07:39 AM)
or.. just lack of compressor lubrication
vr2turbo
post Nov 25 2011, 05:40 PM
Group: Newbie
QUOTE(ThunderGod_Cid @ Nov 25 2011, 01:24 PM)
This post has been edited by vr2turbo: Nov 26 2011, 01:50 PM
cheelam
post Nov 26 2011, 11:02 AM
Group: Newbie
QUOTE(vr2turbo @ Nov 25 2011, 05:40 PM)
Imagine if your house ceiling fan make noises, don't think add lubricant can solve the issue permanently.
Similar theory applies to your car air-cond. And normally the air-cond fan will hardly make noises.
vr2turbo
post Nov 26 2011, 01:52 PM
Group: Newbie
QUOTE(cheelam @ Nov 26 2011, 11:02 AM)
The fan will makes noise if the blade touches something. Motor will just slow down or don't work at all...... brows.gif
bodyglove
post Jan 3 2012, 12:43 PM
Pm me affordable aircond service for myvi, need to do full service by remove dash board? At selangor
Added on January 3, 2012, 2:14 pmPm me affordable aircond service for myvi, need to do full service by remove dash board? At selangor
This post has been edited by bodyglove: Jan 3 2012, 02:14 PM
cheelam
post Jan 3 2012, 03:43 PM
Group: Newbie
QUOTE(bodyglove @ Jan 3 2012, 12:43 PM)
pm done!! Happy New Year! Hope to see you soon~
gsdev
post Jan 17 2012, 06:36 PM
QUOTE(cheelam @ Jan 3 2012, 03:43 PM)
Please PM me details on Myvi Air Con service too. My Myvi has aircon problem for some time already. Done flushing via an automated computer air cond machine, changed oil refill Gas etc in Oct 2011, aircon still not so good. It gets not cold on long distance travels...
cheelam
post Jan 17 2012, 06:49 PM
Group: Newbie
QUOTE(gsdev @ Jan 17 2012, 06:36 PM)
pm done smile.gif hope to see you soon!
gsdev
post Jan 29 2012, 09:36 AM
QUOTE(cheelam @ Jan 17 2012, 06:49 PM)
Thank you for your help and also thank your co-workers in doing a good job . I definitely would not hesitate to recommend your workshop. I would say from my experience the work was done professionally with good advice and the parts and service cost was very reasonable. My air cond problem is solved and it is definitely very nice to drive with the cool air blowing again. So two thumbs up thumbup.gif
cheelam
post Jan 31 2012, 12:30 AM
Group: Newbie
QUOTE(gsdev @ Jan 29 2012, 09:36 AM)
coolfamousamos
post Feb 15 2012, 10:10 AM
Group: Newbie
pm me full service for myvi 1.3 2009 and your location. tq
cheelam
post Feb 15 2012, 10:35 AM
Group: Newbie
QUOTE(coolfamousamos @ Feb 15 2012, 10:10 AM)
percuma
post Feb 16 2012, 11:09 AM
QUOTE(cheelam @ Feb 15 2012, 10:35 AM)
PM me also location and price... i want to service my MYVI 2006... did'nt service acc since buy it...
thanks in advance
cheelam
post Feb 16 2012, 12:16 PM
Group: Newbie
QUOTE(percuma @ Feb 16 2012, 11:09 AM)
thanks in advance
AskDS
post Feb 21 2012, 04:56 PM
My 2006 MyVi aircond also has not been serviced before since purchased. Reading this thread make me think that I need to service it.
Bro cheelam, please PM me your location and price. TIA.
cheelam
post Feb 23 2012, 07:44 PM
Group: Newbie
QUOTE(AskDS @ Feb 21 2012, 04:56 PM)
pm done
UncleLim
post Mar 9 2012, 08:04 PM
QUOTE(cheelam @ Feb 23 2012, 07:44 PM)
pm done
pm me oso, thnks!
cheelam
post Mar 10 2012, 10:04 AM
Group: Newbie
QUOTE(UncleLim @ Mar 9 2012, 08:04 PM)
pm me oso, thnks!
hiphip
post Mar 27 2012, 03:10 PM
Group: Newbie
Hi,
could you please pm me the details if i want to change my myvi (model 2009) compressor+labor+gas and service together?
Thanks
cheelam
post Mar 27 2012, 05:58 PM
Group: Newbie
QUOTE(hiphip @ Mar 27 2012, 03:10 PM)
Hi,
Thanks
pm done~ Great day!
This post has been edited by cheelam: Mar 27 2012, 05:58 PM
panterna
post Apr 21 2012, 01:00 PM
hi
pls pm the price for myvi 2006 aircond servicing
sometimes the air will blow only in the inside, not coming out the vents.. sad.gif
rajasiang
post Jun 7 2012, 01:38 AM
Group: Newbie
Hello,
Pls pm me myvi 1.3 2008 aircon servicing charges(what's included ie gas, labour etc) and if needed to change compressor, cooling coil, valve etc and it's charges.
Thanks
billy_overheat
post Jun 7 2012, 01:48 AM
-Cardistrize-
My compressor went kaput after it had large noise. You better check on it. I've changed to a new one and for now, it's been doing good with acceptable kicking in sound.
cheelam
post Jun 7 2012, 11:00 AM
Group: Newbie
QUOTE(panterna @ Apr 21 2012, 01:00 PM)
hi
sent you pm on 21Apr
QUOTE(rajasiang @ Jun 7 2012, 01:38 AM)
Hello,
Thanks
Added on June 7, 2012, 11:00 am
QUOTE(billy_overheat @ Jun 7 2012, 01:48 AM)
This post has been edited by cheelam: Jun 7 2012, 11:00 AM
yohmawar
post Jun 29 2012, 05:37 PM
Group: Newbie
Hi guys..
really need your suggestion on where to service my aircon and the estimation price.
never service it before. I own Myvi 1.3 ezi 2005
preferably in puchong, pj or shah alam...
there's one car service centre wanna charge me rm800..
Thanks
cheelam
post Jun 29 2012, 06:11 PM
Group: Newbie
QUOTE(yohmawar @ Jun 29 2012, 05:37 PM)
Hi guys..
Thanks
Erm.. price is varied by the way they do the service.
Fyr, our full service includes: opening dashboard, cleaning air-cond system, air-cond gas refill, air-cond vacuum, replacing a/c valve and receiver drier. Price is much lower than yours.
norhairy
post Jul 9 2012, 04:37 PM
pm me your location and best price for Myvi 2009. My air cond seems not too cold when sunny day..TQ
cheelam
post Jul 9 2012, 07:05 PM
Group: Newbie
QUOTE(norhairy @ Jul 9 2012, 04:37 PM)
gn01117135
post Jul 11 2012, 09:07 AM
hi guys, sifus, pls advice, or share ur exp if u encounter same wif me
the air is very small when aircond is open for 10mins, when i off for 15mins the air normal back,
now is getting serious, my car will overheat when aircond is opne, when aircond is off , the temp goes down, izzit my aircond fan problem??
kwokthai
post Jul 11 2012, 02:56 PM
TQ
alex_cyw1985
post Jul 11 2012, 03:01 PM
QUOTE(kwokthai @ Jul 11 2012, 02:56 PM)
TQ
PM the same info. thx
ermasobri
post Aug 14 2012, 11:01 PM
Group: Newbie
Bro pm me your shop details. I have problem with my myvi 1.3 2005, when im on button a/c you can heard sound coming out and no sound when off that button. Tq
cheelam
post Aug 15 2012, 07:16 PM
Group: Newbie
QUOTE(gn01117135 @ Jul 11 2012, 09:07 AM)
TQ
QUOTE(alex_cyw1985 @ Jul 11 2012, 03:01 PM)
QUOTE(ermasobri @ Aug 14 2012, 11:01 PM)
It's good to check and identify where the sound comes from.
May you find our location MAP or refer our signature below.
Pm-ed done!
luluby
post Aug 20 2012, 08:31 AM
can any one pm me the address for air corn service?
cheelam
post Aug 20 2012, 09:06 PM
Group: Newbie
QUOTE(luluby @ Aug 20 2012, 08:31 AM)
archery
post Aug 26 2012, 11:59 PM
hi guys, need some advice
i have myvi 2005..my problem is
1)aircond is not cold?
2)there will be water at the dashboard near aircond hole..like freezing or something?
cheelam
post Aug 27 2012, 11:02 AM
Group: Newbie
QUOTE(archery @ Aug 26 2012, 11:59 PM)
Combined both situation, most probably there is blockage inside your car air-cond system which doesn't allow the cold air flow into your car. Therefore, you can't find the air is cold and water exixts near the aircond vent.
Normally this can be solved by doing a full air-cond service.
Yet, it's good to confirm your issue by a mechanic to check on your air-cond system.
peeyaw
post Nov 21 2012, 12:58 PM
noob question from me.. every how many months we should service our air cond eh?
motomeiji
post Nov 21 2012, 01:02 PM
QUOTE(peeyaw @ Nov 21 2012, 12:58 PM)
shop told me every year. but the F with it, drag 2 years.
cheelam
post Nov 21 2012, 02:22 PM
Group: Newbie
normally 1-2 years, subject to your car usage too.
njan77
post Nov 22 2012, 04:34 AM
Just yesterday my Myvi 2005 complete repair air Cond cost me RM730 including service, recommend by my cousin. Never service since day 1.
1. Aircon service RM250
2. Change cooling coil RM250 (He said sudah reput, but from what i see still OK, but just change since i dont want him to sabotage if didn’t change- left the car overnight)
3. Change fan motor RM150 (motor kaput)
4. Change dryers.
5. Top up gas/oil.
6. New filter and modify filter housing.
On item 2 and 3, I not really sure on the condition, but cannot tahan anymore after almost 4month without aircond. I am not sure whether I am being over charged?
cheelam
post Nov 22 2012, 09:39 AM
Group: Newbie
QUOTE(njan77 @ Nov 22 2012, 04:34 AM)
4. Change dryers.
5. Top up gas/oil.
panterna
post Dec 22 2012, 09:57 PM
PM me location and price... i want to service my MYVI 2006... didn't service acc since buy it...
irwazna
post Dec 22 2012, 10:19 PM
Just service my aircond, myvi year 2007 (1st time)..behind jusco maluri..cost me around rm450..good service..recommended..
cheelam
post Dec 23 2012, 04:31 PM
Group: Newbie
QUOTE(panterna @ Dec 22 2012, 09:57 PM)
pm you the price
May you click our location from the signature below.
rumpus
post Dec 26 2012, 01:00 PM
Group: Newbie
QUOTE(cheelam @ Dec 23 2012, 05:31 PM)
pm you the price
Sorry Bro,
Just wanna share in this forum my Myvi 2007 early.
Perodua USJ 19 charge for aircond service and change part almost rm 1700
Labour charge Rm 400.
Item remove.
1. Cooling coil
2. compressor clucth(not compressor)
3. Receiver Drier
I dont now why.
cheelam
post Dec 26 2012, 02:22 PM
Group: Newbie
rumpus
post Dec 26 2012, 03:04 PM
Group: Newbie
I Just to want to know the pricing original parts for Coling coil, receiver drier, compressor, condenser, valve (MYVI 1.3 Auto) ?.
Plz let me knw
cheelam
post Dec 26 2012, 03:55 PM
Group: Newbie
QUOTE(rumpus @ Dec 26 2012, 03:04 PM)
Plz let me knw
mindfaucet
post Feb 4 2013, 06:35 PM
Group: Newbie
hi there,
now my myvi (2009) aircond first time broke down.. 2 shops I went also said the same thing.. "boss, your compressor rosak!" then said must change this, this and this... all together RM1k wor.. another shop said, 700+ for ori parts, 400+ for recond parts.. so what is exactly they will change and pricing? will someone share this with me.. thanks
cheelam
post Feb 4 2013, 07:19 PM
Group: Newbie
QUOTE(mindfaucet @ Feb 4 2013, 06:35 PM)
hi there,
The price is almost that.
Most importantly you'd find the reliable shop to conduct the job.
mindfaucet
post Feb 7 2013, 03:28 PM
Group: Newbie
QUOTE(cheelam @ Feb 4 2013, 07:19 PM)
So its normal then. Thanks bro cheelam!!
KiAN008
post Feb 18 2013, 04:25 PM
QUOTE(irwazna @ Dec 22 2012, 10:19 PM)
can pm me the address , need service my car air-con ..
thk Q
chyap99
post Jun 16 2013, 06:28 PM
Possible modify it to increase the wind level and more cold ?
Muntash
post Jun 26 2013, 02:17 PM
Bro cheelam
Can pm me ur location
Pm also the pricing original parts for  Coling coil, receiver drier, compressor, condenser, valve (MYVI 1.3 Auto)
jialitrading
post Jul 15 2013, 08:23 PM
Please let me know the price of Full Service For Myvi AC 1.3 2005 & prices of below parts:
1. Cooling coil
2. Receiver drier
3. Compressor
4. Condenser
5. Valve
CT2009
post Sep 22 2013, 02:26 PM
Please let me know the price of Full Service or repair For Myvi AC 1.3 2005 & prices of below parts:
1. Cooling coil
2. Receiver drier
3. Compressor
4. Condenser
5. Valve,
If gas leak, what problem, n where can i find good workshop, pay cash or accept credit card
9926
post Sep 23 2013, 04:53 PM
QUOTE(CT2009 @ Sep 22 2013, 02:26 PM)
1. Cooling coil
2. Receiver drier
3. Compressor
4. Condenser
5. Valve,
cooling coil 380
drier 90
condenser 320
valve 120
price from denso bangsar, i just sent my myvi to change these stuff just now...all include around 1336 except compressor...
CT2009
post Sep 24 2013, 08:12 AM
hai thanks..do you know normally how much be the compresor price? and may i know where is the denso bangsar? what about the service charge? thanks
QUOTE(9926 @ Sep 23 2013, 04:53 PM)
cooling coil 380
drier 90
condenser 320
valve 120
9926
post Sep 24 2013, 06:02 PM
QUOTE(CT2009 @ Sep 24 2013, 08:12 AM)
http://cforum1.cari.com.my/forum.php?mod=v...&extra=page%3D1
i have uploaded my opinion and receipt here,but it is in chinese...the price i gave to you included the 6% tax and service charge already which written as labour...the compressor they quote me price below 1000 exclude labour...original denso and is new...the address you can get from this website
http://www.asiapacific.com.my/tomsracing/contacts.html
CT2009
post Sep 24 2013, 09:43 PM
thank you very much!
xander
post Sep 29 2013, 03:53 PM
Finally
I think one of the reason it is so expensive is the trouble of removing the whole dashboard n change the items in there. So even if is a small problem once they opened it they will asked u to might as well change everything
dannytay_76
post Dec 21 2013, 04:58 PM
Group: Newbie
Guys, today I went to service my aircon at a so called Auth Denso dealer in penang - Motorcold. Supposedly have over 30 yrs of experience but don't let that fool, you.
If anyone ever go there, be careful of what you are asking them to do. Firstly they don't outright tell you the price of parts,, quietly scrolling into piece of paper and give you an estimate. Then promise you heaven and end up cannot deliver - and when things don't work to their favor they start blaming you.
I was lucky to meet the boss of the shop but NEVER deal with the two punks who may appear to be such an expert but deep down just another piece of empty vessel. Yes empty vessel as they told me crap stories and tried to modify my stock hoses.
Worse all, I am charge RM 1000 for a Myvi compressor. It appears compressor and magnetic clutch does not come together...I am surprise. From what I hv searched in the Internet, most dealers charges at most 950 for a full set compressor.
So folks,, I trust that you are wiser then me. Stay away from these crooks. I am going to write to Denso and complain about them next week.
Cheers .
miccsk
post Dec 25 2013, 05:47 PM
Group: Newbie
QUOTE(cheelam @ Nov 23 2011, 03:21 PM)
miccsk
post Dec 25 2013, 05:49 PM
Group: Newbie
cheelam
post Dec 25 2013, 06:33 PM
Group: Newbie
QUOTE(miccsk @ Dec 25 2013, 05:49 PM)
ethan99
post Dec 27 2013, 01:33 AM
QUOTE(zero88 @ Nov 8 2011, 07:29 PM)
Hello,
Same for my Myvi also... Settle my Aircon in this workshop at Puchong ... I don't hv the address. Here is the contact for the workshop boss +60 11 1069 8998(Chinese man) he can give good discount and trusted
gjoey
post Dec 27 2013, 08:47 AM
Guys,
If you think that your compressor is giving out (abnormal noise), always check your refrigerant color via the peek window. If it's getting darker, then change the compressor ASAP before the gas contaminate the whole system. MYVI receiver dryer is sealed with the condenser. Once your compressor jammed, the metal debris will be all over the condenser core and inside the receiver dryer. The contaminated oil will still circulated in the system. Once this happened, you need to change your compressor and the condenser, flush out the whole system from the contamination.
Reference
There is other condenser which has more cores than the OEM (OEM has about 38 cores. Aftermarket have about 45 - 50 cores). It's taller but share the same width. The more cooler gas circulated, the longer your compressor can last.
So, change it fast (If your compressor gonna kaput) or don't turn on the aircond until the compressor get changed can save you a lot of $$.
i'am no aircond specialist...but this what I've told and experienced.
cheelam
post Dec 27 2013, 09:48 AM
Group: Newbie
QUOTE(gjoey @ Dec 27 2013, 08:47 AM)
Guys,
Reference
iskazulka
post Dec 27 2013, 03:46 PM
IINM, when your aircond is not cold, don't simply go to shop and ask for top up gas. you are just wasting your money. gas only be lessen when there got leaking.
Mr_47
post Dec 27 2013, 04:12 PM
***NOT MODERATOR *** Post : +10,000,000,00 Warn: 100%
From: Bora-bora u jelly? Special: Age of multi-monitor
paip aircond bocor somewhere go check or change condenser or host
JtrippleH
post Jun 20 2014, 11:29 PM
Group: Newbie
Hello brother cheelam, in need of help here. My 2007 Myvi aircon has a loud noise when I turn it on. I went to a nearby mechanic and he quoted RM 2k to fix it. And our conversation started out like this
Mech: have to open and see. but once open and see the gas will come out. if dowan repair also need refill gas and labour charge.
Me: okla. but quote me a estimated price la at least i can prepare the dough.
Mech: when open need change compressor la, then cooling coil la, the hoses also etc etc. everything kau tim for you 2k la. tomorrow you bring your car here and leave it here 3-4 hours. (direct cantonese translation)
I am not expert. But I am pretty sure it just the condenser or maybe the oil that needs refilling but he said its not that simple. whistling.gif
missysleepy
post Jul 8 2014, 11:40 AM
After reading this thread, I feel Perodua Service with Denso authorized dealer must be every expensive. correct? Im not sure which shops that provides alternative to this and charge cheaper but honest as well to tell you that this parts really need to be change when its due instead of using naked eye to inspect but no machine or whatsover to do the test.
Like earlier post, machine to do the testing is the only way to tell the air cond parts has reach its cycle or due time. We have seen many workshop mechanics will just probably think its time to change and you have to change it bcos after all you have sent your car to service and a labour cost already incur so why wait?
Can someone teach me what were the things that require change as soon as you have sent it for servicing. thanks.
un.deux.trois
post Aug 25 2014, 12:50 PM
I sent my myvi to Perodua service centre, the personnel said my compressor is spoiled and replacement is about rm1800++. Is this reasonable? I haven't said yes yet, thought of going to other workshops since the price is quite steep. Any recommendations? Thanks.
psychicd
post Aug 25 2014, 02:16 PM
last time changing my AC motor pulley cost me RM380..thought i heard he said RM180..later not enough money he followed me to my home to get money from my wife..daym expensive that pulley..
dkrk
post Aug 25 2014, 03:23 PM
Group: Newbie
Guys, sidetrack abit yo....
What will be the reason a/c totally not functioning at all blink.gif blink.gif
officeBoy
post Sep 1 2014, 11:19 PM
Hey Sifu,
What will happen if compressor in leaking? also what is condenser about? can i still turn on the air-cond?
daniel2006
post Oct 10 2014, 08:19 AM
QUOTE(un.deux.trois @ Aug 25 2014, 12:50 PM)
hi bro..have u repair? how much it cost?
un.deux.trois
post Oct 10 2014, 09:12 AM
QUOTE(daniel2006 @ Oct 10 2014, 08:19 AM)
I did it outside, changed a number of things and set me back RM1,500. At Perodua the total bill would have been ++RM2,500 because they said more components needed to be replaced after their complete assessment.
This post has been edited by un.deux.trois: Oct 10 2014, 09:12 AM
TANNY
post Oct 17 2014, 10:17 PM
If doing the normal service of air con, need to open up the dashboard for Myvi?
androsswinx
post May 11 2015, 02:53 PM
Group: Newbie
pm done
Hi,
Pls, Pm me the aircon service price for Myvi 2006 and Viva 2010.
Thanks
cheelam
post May 12 2015, 05:27 PM
Group: Newbie
QUOTE(androsswinx @ May 11 2015, 02:53 PM)
Hi,
Thanks
sure...
interkrome
post Nov 10 2015, 12:04 PM
Hi,
Please pm price for servicing myvi 2007 with cabin filter installed. Planning to change the fan. LAst service 3 years ago.
This post has been edited by interkrome: Nov 10 2015, 12:05 PM
cheelam
post Nov 10 2015, 03:49 PM
Group: Newbie
QUOTE(interkrome @ Nov 10 2015, 12:04 PM)
Hi,
givsasi
post Mar 2 2016, 08:13 AM
Hi, cheelam please pm me ur address, i wanted to service my myvi 2006 aircon, very bad condition now!!
cheelam
post Mar 2 2016, 11:07 AM
Group: Newbie
QUOTE(givsasi @ Mar 2 2016, 08:13 AM)
notious
post Mar 22 2016, 11:47 AM
hi cheelam, what is the price for some mech bearing in myvi 2007. aircon died. pls pm thx
therain01
post Mar 26 2016, 12:22 AM
Hi. Any idea what went wrong if this happen to myvi AC.
1. AC is very cold when the car is moving 40km/h and above under very hot day.
2. In a very hot day, the AC compressor hardly stop. It will stop for a couple of seconds only after running for a minute. This happens when the temperature is set to middle, with blower at 2.
Here comes the problem,
At very hot day, when come to bad traffic, which is about 15 minutes of not moving, the air con cooling efficiency will started to drop. the aircon compressor still running at this time.
If the car keep stucking at bad traffic for another 3 minutes, the compressor will stop functioning. AC blower will give ambient air only. RPM will rise to 2000. The RPM will only back to normal idle when the AC is switch off.
Wait for 3 minutes and turn on the AC, the compressor will start functioning again, and giving slight cool air.
The AC cooling effectiveness will only back to normal when the car is out of bad traffic.
Sorry for the lenghtly description as I was trying to describe the symptoms of the AC issue.
BTW, some may think it is due to faulty radiator fan, rest assured it is a new denso motor. The fan has been running at its own capacity.
update:
5 out of 6 aircon service providers were trying to persuade me to get the whole aircon system changed. price ranging from rm1200 to rm2700. One buglar even told me that they can't flush my system as it will contaminate his machine.
thanks to bro boarulez suggestion and advice i was able to guess what is the possible aircon issue and narrow down my search to get my aircon system fixed at very reasonable price.
This post has been edited by therain01: Mar 31 2016, 03:38 PM
cheelam
post Mar 26 2016, 03:04 PM
Group: Newbie
QUOTE(notious @ Mar 22 2016, 11:47 AM)
sh91
post Mar 26 2016, 07:46 PM
Group: Newbie
Hi, here is my issue on Myvi 2007
Aircond died around end of December 2015, then went to mech nearby my home(SNW) for repair.
Then the mech says compressor kong, then ok loh, change it.
Got damaged RM 550 with 3 months warranty. Everything went nice and good.
After 3.5 months, aircond kong again and went back to the mech: says aircond oil seal cap or something(not good at aircond mechanism and all) rosak, then changed it for RM 180 mad.gif mad.gif bangwall.gif bangwall.gif (a not around during the repair) and im a happy man again.
Then since yesterday, from KL go to Kampar and poff, aircond rosak again. bangwall.gif bangwall.gif bangwall.gif
So...seriously, i think i got scammed and so. ranting.gif ranting.gif ranting.gif
Cheelam, can you please quote me based on changing the compressor?
boarulez
post Mar 27 2016, 01:17 AM
Usually 600 including flushing and drier pack
therain01
post Mar 27 2016, 02:32 AM
Cheelam, please quote me as well with changing compressor, drier, flushing and of course recharge. Might need to replace expansion valve as well if necessary.
The car is p2 myvi 2005. Thanks.
cheelam
post Mar 28 2016, 12:49 PM
Group: Newbie
QUOTE(therain01 @ Mar 27 2016, 02:32 AM)
cheelam
post Mar 28 2016, 01:06 PM
Group: Newbie
QUOTE(sh91 @ Mar 26 2016, 07:46 PM)
Thanks for sharing your aircond issue.
Did you take the Recond unit compressor?
kcirdenk
post Apr 11 2016, 10:16 AM
QUOTE(therain01 @ Mar 26 2016, 12:22 AM)
update:
Hi bro,
I'm currently having the same problem as you.
Can I know what parts you change & the how much for the cost?
TQVM.
therain01
post Apr 11 2016, 01:05 PM
QUOTE(kcirdenk @ Apr 11 2016, 10:16 AM)
Hi bro,
TQVM.
Parts replaced are compressor and condenser. Cost me Rm600 for the parts c/w aircon system flushing and gas recharge.
kcirdenk
post Apr 11 2016, 01:17 PM
QUOTE(therain01 @ Apr 11 2016, 01:05 PM)
I see. Tq for the info bro.
Btw, before you change your new compressor, did your old compressor make loud noise as well?
therain01
post Apr 11 2016, 02:52 PM
QUOTE(kcirdenk @ Apr 11 2016, 01:17 PM)
Yes the old compressor did produce very loud noise when engaged.
It started with short humming sound since few years ago but no performance hit. The sound getting louder and louder as time past until it caused very high pressure due to both compressor and condenser aging. The compressor will stop running until the pressure gets to normal level.
kcirdenk
post Apr 11 2016, 02:53 PM
QUOTE(therain01 @ Apr 11 2016, 02:52 PM)
Ah I see. Thanks again for the info.
Sean77
post Apr 12 2016, 02:09 AM
chnaged both compressor& condenser only rm600? Quite cheap.. i had similar prob...condenser n service also rm600 d
therain01
post Apr 12 2016, 01:42 PM
QUOTE(Sean77 @ Apr 12 2016, 02:09 AM)
Yeah. Reasonable price compared with those
trying to charge thousands.
Probably low operating cost. It's a 1 man show specialist operate under a Tyre shop umbrella.
cheelam
post Apr 12 2016, 08:09 PM
Group: Newbie
Installing a new radiator fan set onto a Perodua Myvi (First Generation)
icon_idea.gif To get a better cooling effect wub.gif , the Perodua Myvi radiator fan set is modified from the original smaller size to a newer bigger size.
nyaulk
post Jun 2 2016, 12:17 PM
Group: Newbie
QUOTE(therain01 @ Apr 12 2016, 01:42 PM)
Hi, can pm me the said repair guy...?
My Myvi air cond condition having same problem...
Thanks in adv
HappyHampers
post Jul 14 2016, 04:58 PM
Hi
I am quoted rm 1700 for myvi original air cond compressor include labor at SC.
Is it too expensive or is this the market price?
nomoredfox
post Jul 15 2016, 02:34 PM
QUOTE(HappyHampers @ Jul 14 2016, 04:58 PM)
Hi
get outside workshop to do it
it should cost below 1.5K original
chickenriceboy
post Jul 15 2016, 03:02 PM
QUOTE(nomoredfox @ Jul 15 2016, 02:34 PM)
http://koolaire.com.my/template.asp?menuid=11
Try going to this place and get your aircon professionally serviced.
I went there early this week and install their aire enchancer
what it uses condensed water to recool the gas so that it is double cooled reducing the load on compressor .
result is dial midway and get very cool air con like the sedan cars.
cheelam
post Jul 15 2016, 05:45 PM
Group: Newbie
Hi
Are you replacing any other aircond parts besides compressor?
HappyHampers
post Jul 15 2016, 10:19 PM
No budget to replace now, as just done major car service and changed tires.. pokai d..
but so far, i feel the compressor and fan motor still working fine. cos I checked the fan motor still spin quite fast when compressor kicks in and not hot temperature rising.
QUOTE(cheelam @ Jul 15 2016, 05:45 PM)
audy
post Jul 16 2016, 01:06 PM
Wanted workshop to check and refill aircond gas but mechanic told me if aircond still feel cold then dont disturb it. Is this true?
Effy92
post Jul 16 2016, 04:31 PM
QUOTE(audy @ Jul 16 2016, 01:06 PM)
Yes, ac is closed system. No need service or refill gas at all, if your gas empty means there must be a leaking. Only change or clean the cabin/ac filter if dirty.
cheelam
post Jul 16 2016, 06:22 PM
Group: Newbie
Most AC workshop in Malaysia is currently practicing that due to their insufficient knowledge & education on the car aircond system.
It's not necessary to refill the aircond gas when it's at an optimized level.
Based on Japan's comprehensive car care practice, car aircond system needs to do a regular maintenance service for every year OR every 20,000km mileage (whichever comes first).
Just like we regularly maintain our car engine by replacing its engine oil & engine filter, regardless its condition is good or bad.
QUOTE(Effy92 @ Jul 16 2016, 04:31 PM)
It's true that ac is a closed system and if the gas is insufficient, the ac system has leakage and needs to be further identified.
But the aircond system requires to do regular maintenance to maintain its proper operation environment.
This post has been edited by cheelam: Jul 16 2016, 06:35 PM
HappyHampers
post Jul 16 2016, 08:48 PM
When the air cond compressor kicks in or when I rev accelarator high, after I replaced my engine mounting left and right side to those cut shop mounting (used), it has a bit intermittent metal sound coming from the front. just a short while sound.
Is this engine mounting rubber worn out causes it ?
GuyM
post Jul 16 2016, 08:51 PM
QUOTE(HappyHampers @ Jul 15 2016, 10:19 PM)
Try taking out the aircond filter under the glove box, try running without it, if filter is dirty then perhaps root of the problem
Wifey myvi, company car, 8 yrs old, only charged the filter once, mileage above 130k, non tinted, she's not complaining about aircond
Weekly when I wash the car, I make it a point to blast the radiator with water, this has been regime
This post has been edited by GuyM: Jul 16 2016, 08:54 PM
HappyHampers
post Jul 17 2016, 04:47 PM
I just changed new cabin/aircond filter 2 months ago... I been driving without air cond filter since day 1 until just recently I install the filter cos all the while I thought the car comes with air cond filter and many years back, the service center ask me to install it with charges but I didn't install.
On and off I will get sore throat or nose congestion cos I guess breathe too much bad air into my body which made my nose allergy. rclxub.gif
QUOTE(GuyM @ Jul 16 2016, 08:51 PM)
This post has been edited by HappyHampers: Jul 17 2016, 04:58 PM
Myrockimus
post Jul 24 2016, 07:49 AM
Group: Newbie
QUOTE(cheelam @ Mar 2 2016, 11:07 AM)
Mind to pm me your contact n location too. My myvi air cond needs repair bro.
cheelam
post Jul 25 2016, 12:05 PM
Group: Newbie
QUOTE(Myrockimus @ Jul 24 2016, 07:49 AM)
Sure! Pm you!!
Click LOCATION for details.
Fei
Phone/SMS/Whatsapp/Line: 016-618 8613
WeChat ID: sgwangacc
cheelam
post Jul 25 2016, 06:50 PM
Group: Newbie
Replacing a larger radiator fan set onto a Perodua Myvi (First Generation)
rafistrght
post Nov 2 2016, 05:17 PM
Hi everyone,
Aircond for my 2008 Myvi took very long to get cold, even that, sometimes i cant feel the cool air at all (especially during really hot days).
With due respect but anyone mind sharing some feedback from bro Cheelam's workmanship? I only saw many posts asking for PM but didn't come back to give some review.
Bro Cheelam, can you please pm me your address and working hour, I plan to drop by your shop this weekend or next for you to check and quote me the price. Btw, checking is free right? B-)
cheelam
post Nov 2 2016, 07:12 PM
Group: Newbie
QUOTE(rafistrght @ Nov 2 2016, 05:17 PM)
Hi everyone,
Hi~ Welcome to visit us for a diagnosis check regarding your coldness issue.
May you find us as stated in the signature below. pm u too.
Syarikat Aksesori Kereta Sungai Wang (金河汽车冷气装饰)
Tel: +603-62582552 SMS/Whatsapp: +6016-6188613 Email: sgwangacc@yahoo.com
Address: 649, Jalan Ipoh Bt 4, 51200 Kuala Lumpur, Malaysia. <MAP> GPS: 3°11.709” N 101°40.781” E Working hours: 9am - 7pm (Mon-Sat)
Website:www.sgwangacc.com.my Fb: Syarikat Aksesori Kereta Sungai Wang Lelong/Line: sgwangacc
About us: We've long established since 1982 and specializes in car accessories, car audio system and car alarm system installation, car windows tinting and also air conditioner service. Our qualified employees are skillful to cater to every automobile and fulfill all customer needs.
djtong
post Nov 3 2016, 01:09 AM
Replaced Myvi compressor last week with a new one original Denso. Compressor costed RM880, filter costed RM15, gas + oil + labor costed RM150.
Tareqqrt
post Feb 19 2017, 11:40 PM
Group: Newbie
Hello, I have MyVi 2006 1.3 need airline service. Pm location please
Tareqqrt
post Feb 19 2017, 11:41 PM
Group: Newbie
QUOTE(cheelam @ Mar 10 2012, 10:04 AM)
Pm location please
cheelam
post Feb 20 2017, 10:26 AM
Group: Newbie
QUOTE(Tareqqrt @ Feb 19 2017, 11:41 PM)
Pm location please
Click LOCATION for our workshop location details.
Wish to hear from you soon!
Fei
Jasonist
post Feb 20 2017, 11:15 AM
Oldfag
wait till u drive the Saga BLM
cedyy
post Feb 20 2017, 12:01 PM
can always tell if a myvi is behind me at traffic lights from the loud compressor noise kicking in and out frequently
cheelam
post Feb 20 2017, 02:48 PM
Group: Newbie
QUOTE(Tareqqrt @ Feb 19 2017, 11:40 PM)
Pm location please
May you click our LOCATION or refer our signature below.
Zack Styler
post Feb 20 2017, 04:26 PM
QUOTE(cheelam @ Jul 25 2016, 06:50 PM)
for the fan upgrade, whole fan with its body changed as well?
or just change the fan?
is it myvi 1.5 fan?
giftfre
post Feb 20 2017, 04:58 PM
My own Myvi 2007 aircon also got similar problem. When car stop in traffic jam, aircon not cool anymore. When car running, it's cool again but suddenly aircon no cool (automatic). Then sent to Subang Jaya Aircon shop next to Bhp Station, kena RM1.7k.
Change compressor, condensor, flush cooling coil. But felt like kena potong.
cheelam
post Feb 20 2017, 07:48 PM
Group: Newbie
QUOTE(Zack Styler @ Feb 20 2017, 04:26 PM)
is it myvi 1.5 fan?
The old Myvi has been upgraded to the new Myvi fan (larger)
It requires to change the whole fan set.
QUOTE(giftfre @ Feb 20 2017, 04:58 PM)
You may check with that shop again as it's believed that your system contains warranty.
Or you're welcomed to visit us for an inspection check on your issue.
doremon
post Feb 21 2017, 11:00 AM
cLuElEss T_T
QUOTE(cheelam @ Feb 20 2017, 07:48 PM)
Hi cheelam
Need to check with you on few things
1. Do you sell larger radiator fan set (Without installation) ?
2. In case anything happen to the fan motor, where to get the replacement ?
3. For basic inspections, what does it covers ? What parts need to be replaced ? Price ?
4. For comprehensive services, what does it covers ? Price ?
5. Possible to do full servicing without removing the dashboard ?
Thanks =`)
cheelam
post Feb 21 2017, 02:23 PM
Group: Newbie
QUOTE(doremon @ Feb 21 2017, 11:00 AM)
Hi cheelam
Thanks =`)
Welcome to visit us for FREE Air-Cond Check Up to determine your car A/C actual condition.
Zack Styler
post Mar 27 2017, 02:13 PM
Can the fan set fits kelisa too?
pm price hehe
cheelam
post Mar 27 2017, 04:52 PM
Group: Newbie
QUOTE(Zack Styler @ Mar 27 2017, 02:13 PM)
pm price hehe
PM DONE!~
aihuat
post Jul 3 2017, 12:10 AM
Group: Newbie
Hi Cheelam,
Wanted to ask, my myvi currently have a loud noise comes from aircond. But when i turn off the fan or turn off the A/C button, the sound just gone. What could be the problem for my car aircond?
On the other hand, when i turn my myvi fan to higher speed, some noise will come out from the fan too. Can you enlighten me what happen to my myvi car's aircond and how much will it possible cost?
coolstore
post Jul 3 2017, 01:35 PM
QUOTE(aihuat @ Jul 3 2017, 12:10 AM)
Hi Cheelam,
maybe u can first determine if any leaf residue drop into the blower fan housing beneath the cabin filter (air cond filter) that causing the noise?
easy only. take out cabin filter as usual first, then can view the blower fan from hole, see got any leaf there (turn it with your hand), you can take out leaf by hand if big piece, if got small piece leaf scattered hard to take out then need to open blower fan from underneath.
cheelam
post Jul 3 2017, 06:01 PM
Group: Newbie
Hi Cheelam,
Based on your description, we still need to identify from your car aircond where the noise source is. bruce.gif
Mind dropping by for a check?
pm you too!
Joeyskullz
post Jul 24 2017, 04:55 PM
I just changed Radiator, Thermostat, compressor magnet, fan motor. it was well till after 6 months it gives a very noisy sound. especially when on the AC when the engine is not hot. when cold it gives bloody noise. i have no idea what is wrong. 7 yrs now only giving issue. huuuu
cheelam
post Jul 24 2017, 05:31 PM
Group: Newbie
QUOTE(Joeyskullz @ Jul 24 2017, 04:55 PM)
Based on your description:
If noise from engine, is Compressor problem.
If noise from cabin, is Blower Motor problem.
* If only change Compressor Magnet, Compressor Body might be the turn heading to graveyard devil.gif
Joeyskullz
post Jul 26 2017, 03:09 PM
QUOTE(cheelam @ Jul 24 2017, 06:31 PM)
How much for cooling coil service?
cheelam
post Jul 26 2017, 04:58 PM
Group: Newbie
QUOTE(Joeyskullz @ Jul 26 2017, 03:09 PM)
enochcsw
post Sep 28 2017, 03:01 AM
Group: Newbie
Hi Cheelam,
I have a Myvi 2008... My car jerk/stutter for a brief moment when compressor cycle goes on/off.. The jerk/stutter can be felt especially in low gear..
May I know what are the possible issues?
Thanks.
cheelam
post Sep 28 2017, 09:57 AM
Group: Newbie
QUOTE(enochcsw @ Sep 28 2017, 03:01 AM)
Hi Cheelam,
Thanks.
It is normal if you feel a little "jerk/stutter" on Myvi.
- If getting serious, but A/C still deliver same coldness in your cabin, have to check with Foreman (engine part).
- If getting serious & A/C get weaker than previous time, most probably is Compressor issue.
Click LOCATION for our workshop details.
enochcsw
post Sep 28 2017, 12:05 PM
Group: Newbie
QUOTE(cheelam @ Sep 28 2017, 09:57 AM)
Ahh I see...
I think my problem is related to the first problem, may I know what kind of engine part failure that will result in jerk/stuttering?
cheelam
post Sep 28 2017, 12:16 PM
Group: Newbie
QUOTE(enochcsw @ Sep 28 2017, 12:05 PM)
Ahh I see...
Engine Timing problem / A/C Belts problem. Visit mechanic for better advice. biggrin.gif
Bump TopicReply to this topicTopic OptionsStart new topic
Switch to:
0.3395sec    9.39    5 queries    GZIP Disabled
Time is now: 17th January 2018 - 04:39 PM
