http://www.digi.com.my/whatshot_v3/blackbe...ited_monthly.do
here it is guys! another cheaper alternative to blackberry bis service!:)
RM25 per month! 500mb per day quota? wow? did i read that part wrong?
and
no extra charges??? only trottle to 128kpbs??
tats good!
its on q5...
here it is!
Q5. Is there a Fair Usage Policy for data?
A5. Yes. Upon reaching a daily usage quota of 500MB, your access may be throttled to 128kbps. There are no extra charges upon hitting the 500MB cap for Blackberry.net usage.
too bad no thethering... as charges will apply:( hahah but 500mb! wow i might juz change from tunetalk back to digi again... and its prepaid
tat means....
digi campus can use also!
tats great!
****maybe they have written it wrongly for the 500mb per day part it should be monthly****
Frequently Asked Questions
Prepaid BlackBerry® Unlimited (Monthly)
Q1. How do you subscribe to prepaid BlackBerry?
A1. Just send <ON BB FM> to 2000.
Q2. How do you stop subscription to prepaid BlackBerry?
A2. Just send <STOP BB> to 2000.
Q3. How much does the service cost?
A3. Only RM25 per month. This price includes full BlackBerry® Internet Service licensing.
Q4. What are the key features of this service?
A4.
Unlimited Internet Browsing
Push Social Networking (eg. Facebook)
Push Email (eg. Yahoo Mail, hotmail, Gmail)
Push Messaging (eg. MSN/Twitter)
Push BlackBerry Messenger
Q6. Do I have to subscribe to the service every month?
A6. No, the service will renew itself at approximately 12pm and of month, unless you stop the service. You will be sent an SMS notification when this happens.
Q7. What happens if I do not have enough credit to renew the service?
A7. If you do not have enough credit for renewal, your BlackBerry service will automatically terminate itself. You may subscribe again when you have enough credit later on in order to continue enjoying the services.
General
Q1. What APN does a BlackBerry use?
A1. The default APN for ALL BlackBerry devices is BlackBerry.net. This is hardcoded into the phone and cannot be changed. This APN will run all BlackBerry supported services.
Tethering as a modem to PC, WAP and streaming (eg. Youtube) are NOT supported by BlackBerry. These services can run on the device, but are not included in the BlackBerry.net APN and hence will not be part of the RM2 per day (or RM0.98 per day during promotional period) charging.
Q2. How do I get a BlackBerry device?
A2. You have the option of using your own device, or purchasing a new device from our DSS stores.
Outlets which stock our original units can be found here: http://www.digi.com.my/internet/smartplan/buy.html. For 'best customer experience' in terms of stock availability, please visit our retail centres.
Q3. What happens if I subscribe to this service with a non-BlackBerry phone?
A3. You will still be charged should you choose to subscribe to this service, but you will not be able to enjoy BlackBerry services.
Q4. Do I need to set up an alternate APN to watch youtube?
A4. No, but please note charges will be as per Daily Max Cap 8 in ADDITION to the RM0.50 for BlackBerry Internet Service (BIS). For example, if you watch YouTube, you would potentially be charged RM8 for diginet usage AND RM2 (or RM0.98 per day during promotional period) for BlackBerry Internet Service (BIS), which would bring your bill for the day to RM10 (or RM8.98 during promotional period).
If your YouTube does not work, go to Options > Advanced Options > TCP/IP > APN Settings Enabled (un-tick the check box if it appears in the BlackBerry), and delete your APN. Then turn off your device, remove your battery and reinsert it again. The correct settings will then be pushed to your phone.
Q5. Do I need to set up a special APN for tethering?
A5. No. If you use the BlackBerry desktop manager software to tether your BlackBerry, select DiGi from the list of operators and the correct APN (diginet) will be defined for you when you tether. You do not need to set up anything else on the phone.
Please note charges will be as per Daily Max Cap 8 in ADDITION to the RM2 (or RM0.98 per day during promotional period) for BlackBerry Internet Service (BIS). For example, if you tether, you would potentially be charged RM8 for diginet usage AND RM2 (or RM0.98 per day during promotional period) for BlackBerry Internet Service (BIS), which would bring your bill for the day to RM10 (or RM8.98 during promotional period).
Q6. One of my apps doesn't seem to work. Do I need to set up any alternate APN?
A6. Yes. Please set diginet as your user defined APN, but please note that if your app/service does not work without using the diginet APN, there is a high chance that it you may be charged PAYU rates, capped at RM8 if you use it on a BlackBerry.
To avoid unintentional charging caused by certain apps running in the background, customers are not advised to set the APN as diginet.
Q7. How do I set up an alternate APN as diginet?
A7. To set this up, go to Options > Advanced Options > TCP/IP > APN Settings Enabled (tick the check box if it appears in the BlackBerry), then set APN as: diginet.
Terms and Conditions
BlackBerry® Unlimited (Daily & Monthly)
The service provided under this plan includes all services for BlackBerry® Internet Service.
The Prepaid Blackberry plan shall include the purchase of the selected plan together with the Blackberry device. The subscriber shall not be allowed to purchase the Blackberry device without the plan.
Unlimited browsing is only applicable within the BlackBerry® device only. Tethered modem or browsing with non-BlackBerry® devices is not included in this plan.
BlackBerry.net data usage is capped at 50 MB per day for daily plan and 500 MB for monthly plan. Digi.net usage shall be charged as per Daily Max Cap 8.
The daily subscription for daily plan shall take effect from 12:00pm and end at 11:59am on the next day.
By signing up for this service, auto renewal shall take effect on a daily or monthly basis at approximately 12:00pm subject to sufficient credit.
BlackBerry® Social + IM (Daily)
Internet browsing and push email facilities are not included in this plan.
Services in this plan includes:
Push Social Networking (Facebook/Twitter)
Push Messaging (MSN Live Messenger/Yahoo! Messenger/Google Talk)
The daily subscription for this plan shall take effect from 12:00pm and end at 11:59am on the next day.
By signing up for this service, auto renewal shall take effect on a daily basis at approximately 12:00pm subject to sufficient credit.
BlackBerry® Email + IM (Daily)
Internet browsing and social networking services are not included in this plan.
Push Email
BlackBerry® BBM (Daily)
Only BlackBerry® Messenger is included in this plan.
Social networking, instant messaging, push email and Internet browsing is not included in this plan.
General
The prepaid terms and conditions stipulated in http://www.digi.com.my/prepaid shall be applicable.
The Blackberry manufacturer's terms shall be applicable to the Blackberry. Any problems encountered by the subscriber on the Blackberry shall be referred to the manufacturer. In no event shall DiGi be responsible in any way for the Blackberry.
DiGi's FAQs shall apply.
ALL NEW DiGi Prepaid BlackBerry Unlimited at RM25, another competitor pressures prepaid BIS
