 overclock need cooler?, newbie here
TSwordtalks
post May 1 2011, 05:55 PM, updated 15y ago
ɾıɥƃɟǝpɔqɐŕ�
Wanted to overclock my PC as it is slow.
Do i need to get a cooler if i overclock?
amy89
post May 1 2011, 06:00 PM
QUOTE(wordtalks @ May 1 2011, 05:55 PM)
You need a better cpu cooler and better ventilation case.
TSwordtalks
post May 1 2011, 06:02 PM
ɾıɥƃɟǝpɔqɐŕ�
QUOTE(amy89 @ May 1 2011, 06:00 PM)
using dell E520
ventilation means fan?
kira_88
post May 1 2011, 06:06 PM
Hello, is it me you're looking for?
u've open a lot of new thread regarding ur pc..y not open one and ask all of it in it
amy89
post May 1 2011, 06:07 PM
QUOTE(wordtalks @ May 1 2011, 06:02 PM)
using dell E520
You can start by installing a cpu cooler.CM 212 Plus is highly recommended by alot of people.
And if you case can install fan do install it so you will have a better air ventilation or you can change the case.
I guess you are using LGA775 right?
This post has been edited by amy89: May 1 2011, 06:07 PM
TSwordtalks
post May 1 2011, 06:14 PM
ɾıɥƃɟǝpɔqɐŕ�
QUOTE(kira_88 @ May 1 2011, 06:06 PM)
more neat.... ahahha. My habit
Added on May 1, 2011, 6:14 pm
QUOTE(amy89 @ May 1 2011, 06:07 PM)
if i get a cooler, will it be better to get a new RAM?
how about the price?
This post has been edited by wordtalks: May 1 2011, 06:14 PM
amy89
post May 1 2011, 06:46 PM
It depends on how much ram do you have and the speed.You are using ddr3 or ddr2?
CPU cooler by cooler master is about Rm80-100(Model 212 Plus).Got a few seller in LYN here.You can search.Find the best price and trusted seller.
You want to OC your cpu right using BIOS i guess...
This post has been edited by amy89: May 1 2011, 06:46 PM
TSwordtalks
post May 1 2011, 06:49 PM
ɾıɥƃɟǝpɔqɐŕ�
QUOTE(amy89 @ May 1 2011, 06:46 PM)
1GB ddr2. There is a guy who tell me to get ddr3 and upgrade from there, because ddr2 will soon be gone.
but i still dont know worth it or not.
amy89
post May 1 2011, 07:00 PM
QUOTE(wordtalks @ May 1 2011, 06:49 PM)
R u sure DDR2 slot can support DDR3 both of this ram has different layout.I don't think can fit.
TSwordtalks
post May 1 2011, 07:09 PM
ɾıɥƃɟǝpɔqɐŕ�
QUOTE(amy89 @ May 1 2011, 07:00 PM)
i mean get a new computer, and a new ddr3 ram. not upgrade straight from ddr2. I know it cant.
sorry, its my bad.
amy89
post May 1 2011, 07:19 PM
QUOTE(wordtalks @ May 1 2011, 07:09 PM)
sorry, its my bad.
Owh ok LOL biggrin.gif ....This days RAM are not expensive you can get a single DIMM 4GB DDR3 1333MHz for only RM125.You can assemble your own PC up to your spec,requirement and budget.
TSwordtalks
post May 1 2011, 07:25 PM
ɾıɥƃɟǝpɔqɐŕ�
QUOTE(amy89 @ May 1 2011, 07:19 PM)
upgrading RAM is my only choice.
amy89
post May 1 2011, 07:26 PM
QUOTE(wordtalks @ May 1 2011, 07:25 PM)
You can get a 2GB DDR2 Ram.How about your GPU what r u using?
jungle_boy
post May 1 2011, 09:34 PM
maybe this will help a lot if u want to ask opinion...
1. what proc do u used...
2. ur idle and load temp...
3. how much u want to overclock...
4. is ur psu enough to doing overclock...
Jayi
post May 1 2011, 10:11 PM
Regular Lurker
If only want overclock a little for fun , just use the stock cooler . Keep the money for funding other hardware .
metsatsu
post May 1 2011, 11:29 PM
Chocolate Starfish
VIP
If you were intending to ask about the cooler, stick to the topic. this topic is going side track. I'm closing this thread.
I suggest that you do some research on google before you post anymore spoon feeding questions.
0.0217sec    0.49    5 queries    GZIP Disabled
Time is now: 10th December 2025 - 03:58 PM
