 To use subwoofer or not to use, Any opinion?
TSMonkey D
post Feb 21 2011, 11:30 AM, updated 15y ago
Hi Sifus!
Sorry for the noob question as im totally new when talk about ICE.
I just recently got myself a 2nd hand car. The previous owner have left me almost everything from front speakers, rear speakers and a 12'ch subwoofer but not the amp. Sighed!
My question is, should i go and buy me a new amp just to power up the woofer or opt for a new simple rear speakers with decent bass?
The front and rear speakers gives me very clear sounds but they seems like no bass at all! hahahaha!
Which way better and of course, cheaper? hehehehe!
Thanks!!
o10+01o
post Feb 21 2011, 11:42 AM
Dato
Get an amp and power the woofer since you said 'like no bass at all'.
Cheaper: Search for a 2nd hand amp which suits your type of woofer. RMS rating and number of coils.
TSMonkey D
post Feb 21 2011, 12:07 PM
o10+01o,
Hahhaa! Not that im addicted to bass but really can feel the bass from those speakers.
Get an amp ar? Feels like very messy with all those extra wiring if using amp. Will my car battery/alternator gone faster if using amp??
Thanks!
o10+01o
post Feb 21 2011, 01:12 PM
Dato
messy? depends on ur installer, normally they will do it neatly.
As for the battery and alternator, no problem for me. my batt survived 2 years ++ running on 2 amps. Always start ur engine first then only switch on ur player.
TSMonkey D
post Feb 21 2011, 01:23 PM
010+01o,
Hmm.. maybe i should go some accesories shops and starts surveying any cheap amps available.
I guessed the cost of getting an amp are somehow similar to getting a pair of rear speakers.
Thanks mate for your inputs!
zennn
post Feb 21 2011, 02:22 PM
just sell the sub la if youre not keen on it...
TSMonkey D
post Feb 21 2011, 02:25 PM
Zennn,
Was thinking about selling the sub but i don't think i could get much from it. So, just see how i could do with some minor upgrade to reuse it. hahahah!
zennn
post Feb 21 2011, 03:14 PM
to use it u need to buy an amp...
TSMonkey D
post Feb 21 2011, 03:29 PM
zennn,
Thats my concern whether i should get an amp or just buy a better pair of rear speakers. Lets see which option save me more money! hehehhe!
Quazacolt
post Feb 21 2011, 04:48 PM
Riding couple
QUOTE(Monkey D @ Feb 21 2011, 03:29 PM)
zennn,
you're not making sense when you want to save money and yet you want to buy a pair of rear speakers.
SUSgrinders
post Feb 21 2011, 05:30 PM
i wonder can we use amp but without subwoofer. Just want to add more power to headunit without the down shaking bass subwoofer
headunit and amp but no subwoofer can it be done or need to buy subwoofer if want to use an amp
Quazacolt
post Feb 21 2011, 05:49 PM
Riding couple
QUOTE(grinders @ Feb 21 2011, 05:30 PM)
you can buy amp only to power your component speaker set. provided your component set and amp isnt chicken brands, it will make a difference with and without amp. generally it will be better unless you get a fail amp then you may potentially worsen your sound quality.
MyWifeCar
post Feb 21 2011, 07:06 PM
★ Car Soundproofing DIY~
Actually ayam brand also can... you will get a louder sound only.
But TS, you plan for rear speakers...yet without amp, what is the woofer for? You also no plan to sell because you scare not worth much.
May I suggest, get a amp for the woofer... be it with ayam logo.
Quazacolt
post Feb 21 2011, 07:09 PM
Riding couple
QUOTE(MyWifeCar @ Feb 21 2011, 07:06 PM)
if all you want is louder audio, ok lo XD
howiechoo
post Feb 21 2011, 08:42 PM
Sincerely providing good music since 2004
why does everyone treat a sub as head banging or shaking device? use your ear to hear.....if u cant, feel it.
ps:
A 5 seater car doesn't mean u must always carry 5 peoples inside.....
MyWifeCar
post Feb 21 2011, 09:37 PM
QUOTE(howiechoo @ Feb 21 2011, 08:42 PM)
ps:
...TS sub is for shaking one. confirmed... I can foresee a lot of things recently....
But the Eclipse in your shop is my precious for what ppl always say~~ Real sub. thumbup.gif It goes so slow that if you look up, the girl with the mini-skirt beside you will slap you. drool.gif
...but need "some" power la.
TSMonkey D
post Feb 21 2011, 10:21 PM
Hahaha!! Thanks all for ur inputs guys.
That sub came as free when i got my this 2nd ride recently. The previous owner gaves me almost everything but without the amp.
The main problem is both front and rear speakers don't gives me bass at all. They sounded like people singing live opera.
And i just wanted some bass only. Hehehehe! Thats y lor, don't know i should get an amp OR a better pair of rear speakers that could produce some bass.
Of course, poor people like me needs to think much coz no money ma. So have to think which option saved me more.
Thanks
MyWifeCar
post Feb 21 2011, 10:23 PM
TSMonkey D
post Feb 21 2011, 10:40 PM
Mywifecar,
Hehehe! Actually, im poorer coz of car loan consider debt. Every months no eat also kena pay.
Btw, the sub is 12'ch and brand is MTX audio. Don't know its watts/ratings unless i unscrew the whole thing from the box. Is it a good brand? How much will it fetch at least? Also, a HU Alpine CDA-9833. Any idea?
Thanks!!
MyWifeCar
post Feb 21 2011, 11:05 PM
MTX is used for shake butt one... But don't worry la... can be tuned to your liking.
You have to open the box and check the model of your sub... btw, curious to know what brand and model is your comp set.
2 Pages  1 2 >Top
0.0169sec    0.40    5 queries    GZIP Disabled
Time is now: 25th November 2025 - 02:38 AM
