i need help from the otai-otai out there,,,
which are more better,,, geforce gtx 460 vs gigabyte hd5850?
GRaphic card!
GRaphic card!
Feb 19 2011, 07:00 PM, updated 15y ago
#1
12 posts Joined: Feb 2011 |
which are more better,,, geforce gtx 460 vs gigabyte hd5850? |
Feb 21 2011, 11:23 AM
#2
88 posts Joined: Dec 2009 From: Kl,Wangsa Maju |
go for hd5850
Feb 21 2011, 07:03 PM
#3
123 posts Joined: Jan 2011 From: BlackHole |
Feb 22 2011, 12:31 AM
#4
86 posts Joined: Feb 2011 From: Kuala Lumpur |
go for nvidia la bro
Feb 23 2011, 01:03 AM
#5
2,640 posts Joined: Sep 2010 From: Kuala Lumpur. |
GTX 460 for better Dx 11 tesselation performance.
5850 for better DX 10 performance. Depends on wat games u play |
Feb 26 2011, 11:45 PM
#6
277 posts Joined: Aug 2010 |
460-louder, non electrik frendly, ugly.
5850-20%quiter, more electric eficenly, more nice gc.. |
Mar 20 2011, 07:20 PM
#7
29 posts Joined: Aug 2010 |
Both of it i also got, i try put my 5850 in my Intel cpu, the result is bad then i put 460 on my Intel cpu.
For my opinion, If Intel Processor then use Nvidia, Amd Processor then use AMD |
Mar 20 2011, 10:04 PM
#8
193 posts Joined: Sep 2008 |
buy la 6870 or 6850.
Mar 20 2011, 11:04 PM
#9
872 posts Joined: Jun 2007 From: Kuala Lumpur(juz my body,LOl) |
lol,casing tered!
Mar 20 2011, 11:20 PM
768 posts Joined: May 2008 |
QUOTE(PC WORM @ Mar 20 2011, 07:20 PM) Both of it i also got, i try put my 5850 in my Intel cpu, the result is bad then i put 460 on my Intel cpu. lol..biased opinion..i was put amd card on intel.no problem at all..btw,this should move to hardware questions & answers.For my opinion, If Intel Processor then use Nvidia, Amd Processor then use AMD |
Mar 21 2011, 04:24 PM
154 posts Joined: Jun 2009 From: Petaling Jaya |
Mar 24 2011, 09:09 PM
221 posts Joined: May 2010 From: Nilai, N9 |
can i ask,can i make some upgraded on my asus k40ij..?
i mean a graphic card?? |
Mar 24 2011, 09:15 PM
168 posts Joined: Oct 2009 From: KK-KGU |
no u cant...
buy PC la if want gaming |
Mar 25 2011, 02:03 PM
38 posts Joined: Feb 2010 From: Pahang Darul Makmur |
go for 5850 mehh.....better than 460.....but i love nvidia
This post has been edited by zathaf87: Mar 25 2011, 02:05 PM |
Mar 25 2011, 10:31 PM
go hd5850.
Added on March 25, 2011, 10:31 pmgo 4 hd5850. This post has been edited by Muty5613: Mar 25 2011, 10:31 PM |
Apr 2 2011, 03:37 PM
153 posts Joined: Nov 2010 |
Whats wrong with HD6000 series for ati? Have you consider that?
Apr 4 2011, 04:37 PM
283 posts Joined: Dec 2009 From: Kuala Lumpur |
buy ATI for gaming..
buy Nvidia for multimedia.. if you plan to use dual VGA.. buy Nvdia 460 check this http://www.tomshardware.com/reviews/geforc...x-480,2694.html |
Apr 14 2011, 10:53 AM
709 posts Joined: Apr 2009 From: Klang |
i like gtx460 than 5850
Apr 14 2011, 10:22 PM
9 posts Joined: Aug 2010 From: KL |
anyone knows my Radeon GC prob is? Its fan often stuck and sound 'kluk...kluk...' and i need to on it manually after i start my computer..
Apr 15 2011, 11:29 AM
914 posts Joined: Feb 2010 From: Penang |
| Change to: | 0.0288sec
0.49
5 queries
GZIP Disabled
Time is now: 22nd December 2025 - 03:53 AM |
