Yesterday I go see Inspira, and I see that it's using timing belt. So, is Lancer also use timing belt?
Lancer use timing belt?
Dec 13 2010, 10:33 AM, updated 14y ago
#1
131 posts Joined: May 2006 |
Dec 13 2010, 10:41 AM
#2
439 posts Joined: Nov 2010 |
Inspira > 9000 > Lancer
Dec 13 2010, 10:43 AM
#3
Elite
6,138 posts Joined: Jan 2003 |
timing chain vs timing belt.. whats the diff
Dec 13 2010, 10:44 AM
#4
876 posts Joined: Jan 2003 From: Tokyo, London, Singapore, KL, Space |
INSPIRA does not need timing belts.
Timing belts need INSPIRA. |
Dec 13 2010, 10:48 AM
#5
202 posts Joined: Nov 2007 |
lancer use wwf belt.
Dec 13 2010, 10:49 AM
#6
2,513 posts Joined: Feb 2007 From: Uarla Umpur |
timing belt needs lancer..
not lancer needs a timing belt |
#7
1,874 posts Joined: Apr 2007 From: "On a need-to-know basis" |
seat belt
Dec 13 2010, 10:51 AM
#8
99 posts Joined: Feb 2010 |
yes lancer still use timing belt
inspora=lanser rebadged with some exora stuff |
#9
1,038 posts Joined: May 2009 |
LOL this tered give me so much knowledge.
Dec 13 2010, 10:52 AM
811 posts Joined: Jan 2003 From: Equine Park |
i loled at the reply.
Dec 13 2010, 10:53 AM
18,672 posts Joined: Jan 2003 From: Penang |
inspira use timing belt? that's so 10 years ago...
timing chain - no need to change timing belt - every 40,000km |
755 posts Joined: May 2005 From: Back to the Historic |
difference are chain last longer, cons of chain is noise
Dec 13 2010, 10:54 AM
Dec 13 2010, 10:59 AM
146 posts Joined: Jan 2008 |
with chain, you got no worry your engine will fell down in the middle of highway because your timing belt is thirsty.
+1 for timing chain |
Dec 13 2010, 11:03 AM
Dec 13 2010, 11:14 AM
76 posts Joined: Apr 2010 |
Lololol there's another high maintenance to consider kkakakakakaka |
Dec 13 2010, 11:15 AM
145 posts Joined: Jul 2006 From: Pulau Pinang |
pro people know what korek or wrong with their car.. beside lancer target market for ppl always know what inside/going on with the engine.
timing belt less noise, less heat. timing chain noisy, the silent one are expensive for manufacture to buy, but 1 million km oni go get change. |
946 posts Joined: Jun 2009 |
timing chain > inspira
Dec 13 2010, 11:17 AM
89 posts Joined: Dec 2005 |
inspira need timing belt
so inspira<timing belt |
Dec 13 2010, 11:21 AM
7,559 posts Joined: Jan 2003 |
y not just use digital timer?
Dec 13 2010, 11:41 AM
641 posts Joined: Dec 2008 |
use leg
Dec 13 2010, 11:43 AM
661 posts Joined: Jul 2008 From: BananaLand |
got seatbelt or not ?
Dec 13 2010, 11:46 AM
Dec 13 2010, 11:48 AM
3,755 posts Joined: Dec 2009 From: Ampang |
60k KM need to change new timing belt...
Dec 13 2010, 11:51 AM
4 posts Joined: Sep 2010 |
i can change my own...my father got alot of leather belts long lasting wan
8,407 posts Joined: Jun 2005 |
how do u able to see it use belt or chain?
Dec 13 2010, 11:52 AM
238 posts Joined: Jun 2009 |
plkn belt
Dec 13 2010, 11:53 AM
8,183 posts Joined: May 2005 From: Beaumont, Baile Ath Cliath, EIRE. |
Dec 13 2010, 11:56 AM
93 posts Joined: Nov 2008 |
Inspira is just a way for Mitsubishi to enter malaysia's market easily. you can see billboard, advertisement about Mitsubishi from car to electronic product just everywhere
Dec 13 2010, 11:59 AM
178 posts Joined: May 2009 From: in thes lulz |
Dec 13 2010, 12:07 PM
Dec 13 2010, 12:11 PM
Staff
9,417 posts Joined: Jan 2003 From: Bladin Point, Northern Territory |
Belts are lighter than chains and thus are less parasitic, they're also lighter, meaning pick up and response is better.
Don't be such a cheap arse, buy something like a Gates belt. This post has been edited by empire23: Dec 13 2010, 12:11 PM |
That is NOT a timing belt
Dec 13 2010, 12:14 PM
1,304 posts Joined: Jan 2009 From: Kuala Lumpur |
inspira timing chain la...
Dec 13 2010, 12:22 PM
if inspira<timing belt, then if next car come out named proton timing belt, the equation will be like this
proton inspira < proton timing belt |
Dec 13 2010, 12:36 PM
this thread open to tell ppl...
I don't know how to differentiate an aircond belt to timing belt... |
Dec 13 2010, 12:37 PM
75 posts Joined: May 2007 From: KL, Malaysia |
TS, Proton promises Mitsubishi that they wont touch the engine part, so therefore its using timing chain, another thing is, u cant see the timing chain coz its located inside & its covered, the belt u saw at the engine part is NOT a timing belt
Dec 13 2010, 12:40 PM
1,997 posts Joined: Jan 2003 From: Your Grandma With Kisses |
Dec 13 2010, 12:49 PM
873 posts Joined: Dec 2009 |
Malaysia need inspira
Dec 13 2010, 12:55 PM
2,814 posts Joined: Jun 2005 From: Seasaw |
chain liao (from my gooogle)
Dec 13 2010, 01:01 PM
962 posts Joined: Dec 2004 From: Kulai |
Dec 13 2010, 01:03 PM
Dec 13 2010, 02:21 PM
The term 'aircond belt' that is generally used is referring to what should be known as 'drive belt'.
The drive belt driven by the engine is used to drive accesories namely the aircond compressor, water pump, power steering pump, alternator etc. It may also be call 'V-belt' as the crossection of the belt resembles 'V'.. |
Dec 13 2010, 03:09 PM
1,588 posts Joined: Nov 2007 From: Planet Earth |
QUOTE(jazzy939 @ Dec 13 2010, 02:21 PM) The term 'aircond belt' that is generally used is referring to what should be known as 'drive belt'. Ohh. The drive belt driven by the engine is used to drive accesories namely the aircond compressor, water pump, power steering pump, alternator etc. It may also be call 'V-belt' as the crossection of the belt resembles 'V'.. Last time I timing belt putus, I don't know keep pressing the gas pedal. End up have to open engine block. RM 600++ |
Dec 13 2010, 03:22 PM
If timing belt putus, your engine will not operate and on some engines there will be damage to the valves and piston. Expensive liao.. requiring an overhaul and may run into thousands of ringgit.
Drive belt putus depends lah. Some engine got one single belt driving ALL accessories. Some got two or three belts. If you see cracks on the belts, time for a change already! http://www.youtube.com/watch?v=GXkKY30LJY4 This post has been edited by jazzy939: Dec 13 2010, 03:25 PM |
Feb 2 2011, 12:55 AM
93 posts Joined: Jan 2008 |
So may i know Proton Inspira use Timing chain or Timing belt like Honda City
Feb 2 2011, 02:50 AM
181 posts Joined: Nov 2007 From: Malacca / Kuala Lumpur |
Feb 2 2011, 02:58 AM
620 posts Joined: Oct 2008 |
the replies go like this.
dumb-->stupid-->ignorant-->common sense-->technical skills-->--TS pwnd |
Feb 2 2011, 09:04 AM
6,626 posts Joined: Jan 2003 From: Palace of sexology |
use timing belt or timing chain also need to service.
oil seal also got to change. chain or belt tensioner also got to change. You only save the belt cost around rm120++ for timing chain user This post has been edited by vexus: Feb 2 2011, 09:05 AM |
Feb 2 2011, 09:30 AM
707 posts Joined: Jan 2007 From: Island of Borneo |
power steering belting, compressor belting and alternator belting
Bump Topic Add ReplyOptions New Topic |
Change to: | 0.0198sec
0.26
5 queries
GZIP Disabled
Time is now: 29th March 2024 - 05:33 AM |
