 TSR Watermark Image [Free]
TScybpsych
post Jul 24 2010, 11:00 AM, updated 13y ago
http://www.watermark-image.com/watermark-image.zip
TSR Watermark Image software, is a free program for personal use that can add digital watermarks to all your images, photos and pictures with the transparency you decide. The program can also resize the images before the digital watermark is added.
When creating the watermark, you can use either text or another picture as the source of the watermark. If you want to add the watermark to the background, you can set the logo or the text to be more or less transparent, and define the transparency color on the image or select the first pixel in the upper left corner as transparency color.
You can even use this program instead of photoshop to watermark your images, this is a quicker and more easy way of getting a watermark on all your images. Also use the watermarked image in Word, Excel or images used in pdf files can be made with this watermarking software.
Features
  • Add text watermark that is either normal, embossed, chiseled or watermarked with a border.
  • Automatically rotate the watermarked picture based on the orientation EXIF tag - this is written to the image by many modern cameras.
  • Add the text used to watermark the image to the EXIF information in the resulting file.
  • Keep or drop EXIF information in jpeg files (Camera model/lense model/etc. etc.)
  • Output the watermarked photo to JPEG, TIFF, PNG, BMP, GIF file format.
  • Specify the quality of the watermarking output when saving as jpeg images
  • Angle the text you use for your photo watermarking
  • Insert background watermark in digital images, pictures, photos
  • Resize images while watermarking the image/photo
  • Watermark your photos using either another image, photo or picture
  • Watermark your photos using your own text in the color and style you want to.
  • Maintain directory structure in destination directory or combine all batch watermarked images into one directory
  • Skip or overwrite existing watermarked images/photos in destination directory
  • Automatically check for new version of the TSR Watermark Image Software
This image watermark software works with Windows XP, Windows server 2003, Windows Vista, Windows server 2008, Windows 7 - with .NET framework 2.0 or higher installed.
This post has been edited by cybpsych: Oct 30 2010, 04:04 AM
TScybpsych
post Jul 30 2010, 06:39 AM
TSR Watermark Image v1.8.1.1
TScybpsych
post Jul 31 2010, 08:04 PM
TSR Watermark Image v1.8.1.5
TScybpsych
post Aug 5 2010, 11:12 PM
TSR Watermark Image v1.8.2.3
TScybpsych
post Aug 6 2010, 08:21 AM
TSR Watermark Image v1.8.2.4
TScybpsych
post Aug 15 2010, 04:53 AM
TSR Watermark Image 1.8.2.6
TScybpsych
post Aug 26 2010, 04:38 PM
TSR Watermark Image Software 1.8.3.1
http://www.watermark-image.com/watermark-image-portable.zip
This post has been edited by cybpsych: Aug 26 2010, 07:02 PM
TScybpsych
post Sep 2 2010, 06:58 PM
TSR Watermark Image Software 1.8.3.2
2 September 2010
Download:
QUOTE
Changelogs:
QUOTE
Added Portuguese - Portugal language, thanks Ant?nio!
This post has been edited by cybpsych: Sep 2 2010, 07:01 PM
TScybpsych
post Sep 11 2010, 06:30 AM
TSR Watermark Image Software v1.8.3.3
Setup: http://www.watermark-image.com/watermark-image.zip
Portable: http://www.watermark-image.com/watermark-image-portable.zip
TScybpsych
post Sep 13 2010, 07:02 PM
TSR Watermark Image Software v1.8.3.4
TScybpsych
post Sep 13 2010, 07:06 PM
QUOTE(VinniJeyaa @ Sep 13 2010, 07:05 PM)
what can this software do? any examples?
see post #1 or http://www.watermark-image.com
TScybpsych
post Sep 29 2010, 07:30 AM
TSR Watermark Image Software 1.8.4.1
TScybpsych
post Oct 14 2010, 07:26 AM
TSR Watermark Image Software v1.8.5.2
TScybpsych
post Oct 30 2010, 03:49 AM
TSR Watermark Image Software v1.9.1.1
TScybpsych
post Nov 6 2010, 05:51 PM
TSR Watermark Image Software v1.9.5.1
TScybpsych
post Dec 6 2010, 09:11 PM
TSR Watermark Image Software v1.9.5.3
stasio
post Dec 15 2010, 02:02 AM
10k Club
TSR Watermark Image Software 1.9.5.5
TScybpsych
post Dec 19 2010, 07:59 PM
TSR Watermark Image Software v1.9.6.1
stasio
post Jan 2 2011, 06:25 AM
10k Club
TSR Watermark Image Software v1.9.6.2
TScybpsych
post Jan 28 2011, 04:43 AM
TSR Watermark Image Software v1.9.6.3
Updated the Hungarian language, thanks Istvan!
Minor bug fixes
TScybpsych
post Feb 8 2011, 10:17 PM
TSR Watermark Image Software v1.9.6.4
Extended the %FILE_DATE% so it now uses the EXIF tag 36867 CreationDateTime before using the file dates.
Fixed a bug when using the %FILE_DATE% to replace with picture taken date - thanks James!
TScybpsych
post Feb 19 2011, 07:00 AM
TSR Watermark Image Software v1.9.7.1
Added a buttton used to insert a special character in the watermark text area.
Added the option to make a multiline watermark.
Added the Armenian language, Thanks Hrant!
Added some more error handling when pressing the start button.
Changed layout a bit to support the above options.
TScybpsych
post Mar 10 2011, 05:23 PM
TSR Watermark Image Software v1.9.9.1
Added a use image as 3D Depth map option, to create 3D watermarks - this uses the input image as a bump map for the 3D watermark by doing a emboss edge detection on the watermark image and then using this to modify the original image and thereby create a 3D watermark effect, thanks to Remi for asking for this smile.gif
Added the Farsi language, thanks to Mona for the help.
Added a remove all button in the source file list, thanks for asking Elisabeth.
Fixed some layout and text errros when running using a language other than English, thanks Mona!
Fixed a major memory leak, thanks for pointing this out Ingo
TScybpsych
post Apr 12 2011, 06:36 PM
TSR Watermark Image Software 1.9.9.2
Added a show files when done option, this opens the file explorer showing the watermarked photos.
Addes a popup box showing if a file has an error.
TScybpsych
post May 12 2011, 07:23 PM
TSR Watermark Image Software 1.9.9.3
Added an alert box when destination and source files are equal, thanks Tim
Added Serbian Cyrilic language, thanks Ozzii
Fixed a major speed issue, now watermarking large images is 100 times faster than previous versions
Minor bug fixes
TScybpsych
post May 27 2011, 07:35 PM
TSR Watermark Image Software 1.9.9.4
Updated the serbian language, thanks Ozzii
Added a new translation of the Japaneese, thanks Sakata
Added flags icons to the language selection
Minor bug fixes
TScybpsych
post Jun 14 2011, 03:45 PM
TSR Watermark Image Software 1.9.9.5
Fixed a color conversion error when saving jpeg, thanks Jaap & Huub
Fixed a 3D marking error when creating 100% 3D watermarks from an image that was smaller than the resulting image.
Fixed a text layout problem when having 10000+ images to add watermark to, thanks Jeffrey
Fixed a Deutch/Deutsch spelling error, thanks Klaus
Updated the save watermark setup function to include a better error handling.
TSR Watermark Image Software v2.0.0.1 (BETA 3)
http://www.watermark-image.com/watermark-image2.zip
- Rewrote the text watermarking routine, now the text watermarks looks better than ever!
- Added multiple output profiles
- Added Multiple watermarks on each image
- Did some small GUI Changes
This post has been edited by cybpsych: Jun 29 2011, 06:53 AM
TScybpsych
post Jul 14 2011, 08:55 PM
TSR Watermark Image Software 1.9.9.6
Fixed a Windows 7 screen zoom problem, now the fonts in the watermark program looks ok even when you set the zoom level at 125%, thanks Lisette
stasio
post Aug 16 2011, 06:23 PM
10k Club
TSR Watermark Image Software 1.9.9.7
Added the Hebrew language
Minor bug fixes
TScybpsych
post Oct 2 2011, 05:12 AM
TSR Watermark Image Software 2.0.0.7
Added the option for multiple watermarks - only available in the registered version
Added the option for multiple output profiles - only available in the registered version
Added the option for Bold/Italic text watermarks
Added the option for antialized/not antialized text watermarks
Improved the text watermarking routine, now text watermarks looks better than ever.
Changed the default save/open directories, now it's My Pictures not the TSR Watermark Image Exe file path
Changed the preview image to scale/fixed whatever creates the best image.
Changed the text box, now it is shown in the selected font
Fixed a major memory leak!
TScybpsych
post Oct 3 2011, 05:09 AM
TSR Watermark Image Software 2.0.0.8
* Fixed a preview memory leak
* Fixed the default setup shipped with the product
* Added a warning when loading an old setup file.
* Added some more information and color coding on what to do before you can start watermarking
TScybpsych
post Oct 3 2011, 06:08 PM
TSR Watermark Image Software 2.0.0.9
Fixed a problem preventing some users from generating watermarks
TScybpsych
post Oct 3 2011, 08:39 PM
TSR Watermark Image Software 2.0.1.1
Fixed a GUI layout error
TScybpsych
post Oct 4 2011, 07:50 PM
TSR Watermark Image Software 2.0.2.1
* Added the option to add different file tags to the text watermarks
* Changed the GUI to explain the multiple watermarks and destinations
TScybpsych
post Oct 6 2011, 02:51 PM
TSR Watermark Image Software 2.0.2.2
Fixed an error that prevented the Font list of being loaded, Thanks Huub
Fixed some minor gui errors
TScybpsych
post Oct 17 2011, 05:46 AM
TSR Watermark Image Software 2.0.3.3
* Added a new option to add borders to the watermarks, Thanks Ingo
* Added the option to choose the text watermarking - text border size.
* Improved the text watermarking rutine.
* Improved the preview image.
* Fixed a load profile bug.
* Fixed a bug where the watermarked image would not be saved, Thanks Tim
* Fixed a bug where the Font list was not cleared correct.
* Fixed a preview image resize bug
* Fixed a bug in the text watermarking where a trailing space would not be used in the text watermark
* Fixed a new profile bug
stasio
post Oct 20 2011, 04:08 PM
10k Club
TSR Watermark Image Software 2.0.3.4
-Fixed the Effect option not showing up.
This post has been edited by stasio: Oct 20 2011, 04:08 PM
TScybpsych
post Oct 24 2011, 05:01 AM
TSR Watermark Image Software 2.0.3.5
* Added the Vietnames language, Thanks Trong
* Fixed a bug setting the width of the watermark when watermarking using an image, Thanks Marina
* Fixed a bug when adding a profile/watermark with a blank name.
* Fixed some text label bugs
* Changed the wording in the gui, Thanks Larry!
TScybpsych
post Oct 28 2011, 08:29 PM
TSR Watermark Image Software 2.0.3.6
Fixed a deadlock blocking in the watermarking preview that would prevent the program from starting to add the watermarks.
TScybpsych
post Nov 22 2011, 09:26 PM
TSR Watermark Image Software 2.0.4.1
* Added the Polish language, Thanks Radoslaw!
TScybpsych
post Dec 7 2011, 10:30 PM
TSR Watermark Image Software 2.1.0.1
* Added the option to write a counter to the text watermark, Thanks Don!
* Minor GUI changes
* Minor bug fixes
stasio
post Jan 15 2012, 04:53 AM
10k Club
TSR Watermark Image Software 2.1.0.2
http://www.watermark-image.com/version.aspx
TScybpsych
post Jan 25 2012, 06:32 PM
TSR Watermark Image Software 2.1.1.1
* Added the Swedish language, Thanks Marianne!
* Fixed a bug where the watermark image would not be applied if the Use image profile was'nt selected.
* Minor GUI changes
TScybpsych
post Feb 2 2012, 06:58 PM
TSR Watermark Image Software 2.1.1.2
* Updated the German translations, thank Norbert
TScybpsych
post Feb 8 2012, 05:31 AM
TSR Watermark Image Software 2.1.1.6
* Fixed the error in the German translations, thanks Norbert Hufler
* Fixed a bug in the File->Open routine, thanks Simon
* Fixed a bug in the effect option where the transparency option did not work, thanks Norbert Hufler
TScybpsych
post Feb 15 2012, 09:51 PM
TSR Watermark Image Software 2.1.2.1
* Added the option to set the DPI of the output image to either the same as the original image or 72 DPI, thanks Stephanie
* Minor GUI changes
stasio
post Mar 6 2012, 06:16 PM
10k Club
TSR Watermark Image Software 2.1.2.4
Fixed a bug in the Maintain DPI option when upgrading to version 2.1.2.1, thanks Edward & Stepahnie
Fixed a bug when an output profile had some invalid data, thanks Jim
Rewrote the warning method, now it gives even better warning when there is a setup error.
TScybpsych
post Mar 13 2012, 09:09 PM
TSR Watermark Image Software 2.1.2.5
Fixed a bug with empty profiles, thanks Carlos
TScybpsych
post Mar 28 2012, 03:07 PM
TSR Watermark Image Software 2.1.2.8
* Added the option of changing the emboss/chisel width so they are more visible in larger images.
TScybpsych
post Apr 1 2012, 10:26 PM
TSR Watermark Image Software 2.1.2.9
* Fixed some errors in the Open and Save as file dialogs
TScybpsych
post Apr 9 2012, 01:44 AM
TSR Watermark Image Software 2.1.3.1
* Fixed a bug where a warning would stay on the last page, thanks Elisabeth
* Fixed a design issue affecting the gui look.
TScybpsych
post Apr 19 2012, 04:04 PM
TSR Watermark Image Software 2.1.3.2
* Fixed an error in the function that adds
TScybpsych
post Apr 26 2012, 09:09 PM
TSR Watermark Image Software 2.1.4.1
* Added the Turkish language, thanks Alper
TScybpsych
post May 21 2012, 04:57 PM
TSR Watermark Image Software 2.1.4.2
* Fixed some minor memory leaks
TScybpsych
post Jun 25 2012, 05:32 PM
TSR Watermark Image Software 2.1.5.1
* Added Slovak translations, thanks Martin
* Minor bug fixes
TScybpsych
post Jul 22 2012, 09:23 PM
TSR Watermark Image Software 2.1.6.1
* Added Lithuanian translation, thanks Jurate
TScybpsych
post Aug 8 2012, 02:36 PM
TSR Watermark Image Software 2.1.6.2
* Updated the Italian language, Thanks Filippo
TScybpsych
post Aug 9 2012, 05:01 PM
TSR Watermark Image Software 2.1.6.4
* Fixed a serious bug in the text watermarking - no watermark was added.
TScybpsych
post Aug 22 2012, 07:39 PM
TSR Watermark Image Software 2.2.0.1
* New installer GUI/Design
* Fixed some minor GUI problems
* Added some new graphics to the program
* New icon
TScybpsych
post Aug 30 2012, 08:51 PM
TSR Watermark Image Software 2.2.0.4
* Added a "Email support" option that emails all relevant watermark indformation to our support!
* Fixed a bug when "my pictures" does not exist, thanks Jo!
TScybpsych
post Sep 1 2012, 05:36 AM
TSR Watermark Image Software 2.2.0.5
* Updated the icons on the toolbar
TScybpsych
post Sep 21 2012, 03:26 AM
TSR Watermark Image Software 2.2.0.6
* Rewrote the open default directory option
* Rewrote the last directory remembered option
* Fixed a bug that kept the "select preview image" button disabled on the "Save watermarked picture as" tab, thank Stephen
TScybpsych
post Sep 21 2012, 02:50 PM
TSR Watermark Image Software 2.2.0.7
* Fixed a bug that saved some jpeg as black images
TScybpsych
post Nov 4 2012, 07:35 AM
TSR Watermark Image Software 2.3.0.1
http://www.watermark-image.com/watermark-image-free.zip
* Added the Norwegian language
* Fixed some minor bugs
* Splitted the software into a free and a pro version to clear confusion
This post has been edited by cybpsych: Nov 4 2012, 08:22 AM
TScybpsych
post Nov 6 2012, 09:15 PM
TSR Watermark Image Software 2.3.0.2
* Fixed an save setup error where it would not allow you to save a new setup.
* Fixed a bug in the load setup information.
* Fixed the updater to point the user in the correct direction.
TScybpsych
post Nov 13 2012, 04:35 PM
TSR Watermark Image Software 2.3.1.1
* Fixed an error that only let you use one image as watermark, Thanks Hans-Rudolf!
stasio
post Nov 16 2012, 09:39 PM
10k Club
TSR Watermark Image Software 2.3.1.2
Fixed an error in the default profile shipped with the software
TScybpsych
post Nov 23 2012, 04:40 AM
TSR Watermark Image Software 2.3.1.3
* Fixed an error in the image resize when the max width or height was set to 0
* Updated the Spanish language, thanks Jos?
TScybpsych
post Dec 21 2012, 10:51 PM
TSR Watermark Image Software 2.3.1.7
Change the save watermarked image routine - if input format and output format are equal, the name and casing og the file extension are kept.
Fixed a bug in the watermarker that did not allow users to save to UNC paths.
Updated the registrations profile.
TScybpsych
post Dec 30 2012, 08:13 AM
TSR Watermark Image Software 2.3.2.1
Added drag and drop support to the watermark source directory list
Added an option to clear the watermark preview image
Added an option to reset the source file list on program start
TScybpsych
post Jan 7 2013, 02:59 AM
TSR Watermark Image Software 2.3.2.2
Changed the counter so it left pads with zeros, eg. 0001 becomes 0002 when incremented instead of 2
Fixed a setup bug where the "Show watermarked files when finished" setting was'nt saved.
TScybpsych
post Jan 19 2013, 07:28 PM
TSR Watermark Image Software 2.3.2.5
Updated the French language, thanks Robert
Updated the Armenian language, thanks Hrant
TScybpsych
post Feb 1 2013, 08:41 AM
TSR Watermark Image Software 2.3.2.6
Minor bug fixes
TScybpsych
post Feb 15 2013, 05:19 PM
TSR Watermark Image Software 2.3.2.8
Added new option to keep input file format
Fixed the DPI "Set to 72 DPI" option
TScybpsych
post Feb 22 2013, 07:30 AM
TSR Watermark Image Software 2.3.2.9
Fixed a rotation error
TScybpsych
post Feb 27 2013, 04:15 AM
TSR Watermark Image Software 2.3.3.2
Added the Greek language files, thanks Nick
TScybpsych
post Mar 8 2013, 04:49 AM
TSR Watermark Image Software 2.3.3.3
Fixed some minor bugs.
Made some adjustments to the registration engine.
TScybpsych
post Mar 15 2013, 04:15 PM
TSR Watermark Image Software 2.3.3.4
Updated the Danish language files
Minor bug fixes.
TScybpsych
post Mar 29 2013, 08:17 PM
TSR Watermark Image Software 2.3.4.1
New feature : You can now select if you wish to resize the images before or after applying the watermark, this is nessesary if you are using an image as watermark and it is not big enough.
Minor bug fixes.
TScybpsych
post May 3 2013, 04:22 AM
TSR Watermark Image Software 2.4.0.1
Added support for transparent PNG/GIF as watermark image, now the transparency of the images is used and the transparency from the photo is also used.
Improved the text watermark quality
TScybpsych
post May 9 2013, 09:05 PM
TSR Watermark Image Software 2.4.0.3
Pro Trial
Added the option to select which watermarks should be applied with a checkbox in the watermark list
Added the option to select which output profiles should be applied with a checkbox in the save watermarked photos as list
Fixed so custom colors in the palette used for watermarking photos is saved
TScybpsych
post May 10 2013, 03:59 PM
TSR Watermark Image Software 2.4.0.4
Pro Trial
Fixed a bug in the free version that made the watermark fail
TScybpsych
post May 26 2013, 11:37 PM
TSR Watermark Image Software 2.4.1.1
Pro Trial
Added a new feature, cross effect that draws a cross on the image
Minor bug fixes
TScybpsych
post Jun 18 2013, 04:57 AM
TSR Watermark Image Software 2.4.1.2
Pro Trial
Rewrote the sequential numbering watermark engine, it has some flaws with the saving/loading
TScybpsych
post Jun 27 2013, 08:02 PM
TSR Watermark Image Software 2.4.1.3
Pro Trial
Minor bug fixes
TScybpsych
post Jul 16 2013, 06:29 AM
TSR Watermark Image Software 2.4.1.4
Pro Trial: http://www.watermark-image.com/watermark-image.zip
Minor reg issue fixed
TScybpsych
post Jul 17 2013, 07:13 PM
TSR Watermark Image Software 2.4.1.5
Changed the behavior so an invalid image will not trigger an message box while running with a command line option to automate the run.
TScybpsych
post Jul 29 2013, 10:12 PM
TSR Watermark Image Software 2.4.1.6
Added a new information that can be automatically added as watermark - EXIF Date only
Added a new information that can be automatically added as watermark - Current Date only
Added a new information that can be automatically added as watermark - Current Date and time
Fixed a bug in the EXIF date and time parsing, it now displays the date/time in your local culture instead of using the EXIF string.
TScybpsych
post Aug 5 2013, 08:09 PM
TSR Watermark Image Software 2.4.2.1
Added the option to do tiled text watermarks
TScybpsych
post Aug 19 2013, 05:24 PM
TSR Watermark Image Software 2.4.2.2
Updated the Chinese simplified language, thanks 大眼仔‾旭
TScybpsych
post Aug 27 2013, 02:24 AM
TSR Watermark Image Software 2.4.2.3
Fixed a bug when maintain aspect ratio was unchecked, then no resize of the watermarked photo was done.
Fixed some minor GUI bugs
Updated the French language, thanks Dom
TScybpsych
post Aug 29 2013, 12:59 AM
TSR Watermark Image Software 2.4.2.4
Fixed a resize bug where the image would not be resized correctly.
Added an option to save the current watermark preview
TScybpsych
post Sep 8 2013, 07:26 AM
TSR Watermark Image Software 2.4.2.6
Fixed some minor GUI errors
TScybpsych
post Sep 16 2013, 05:25 PM
TSR Watermark Image Software 2.4.3.1
Fixed a crash in the watermark preview save as function, Thanks Tony!
Fixed an rounding error in the watermark resizer
Fixed a GUI error
TScybpsych
post Sep 25 2013, 08:39 PM
TSR Watermark Image Software 2.4.3.2
Added the Ukranian language, Thanks Sergey
Fixed some bugs regarding the save watermarked photo preview option
TScybpsych
post Sep 29 2013, 07:35 AM
TSR Watermark Image Software 2.4.3.3
Added the Korean language, Thanks Zames
TScybpsych
post Sep 30 2013, 05:29 AM
TSR Watermark Image Software 2.4.3.4
Fixed that the Korean language did not work on all machines
TScybpsych
post Oct 6 2013, 03:43 PM
TSR Watermark Image Software 2.4.3.5
Fixed a registration bug
stasio
post Oct 8 2013, 04:46 PM
10k Club
TSR Watermark Image Software 2.4.3.6
Fixed a serious registration bug, are you running version 2.4.3.5 and keep getting a registration error you must update to this version.
stasio
post Oct 9 2013, 11:55 PM
10k Club
TSR Watermark Image Software 2.4.3.7
Minor GUI Changes
TScybpsych
post Oct 13 2013, 05:57 AM
TSR Watermark Image Software 2.4.3.8
Fixed some errors in the ready validation code, now it's much easier to start watermarking
Abigail111
post Oct 17 2013, 04:31 PM
Hi there
Thanks for your sharing.I've found an program for creating image watermark for a long time.
I want to know is this mentioned one can works fine in iphone?Thanks a lot.
TScybpsych
post Oct 19 2013, 05:58 AM
TSR Watermark Image Software 2.4.3.9
Minor bug fixes
Improved the help system
stasio
post Oct 22 2013, 09:07 PM
10k Club
TSR Watermark Image Software 2.5.0.1
Added support for Adobe XMP file information, they are now transffered to the watermarked image!
Fixed a watermark dpi error when using file formats other than jpeg
This post has been edited by stasio: Oct 22 2013, 09:08 PM
TScybpsych
post Oct 28 2013, 07:59 PM
TSR Watermark Image Software 2.5.1.1
Added a new feature to rename the output files
Added code certification to the exe files, should remove some security warnings on windows 7 and 8
TScybpsych
post Oct 29 2013, 09:13 PM
TSR Watermark Image Software 2.5.1.2
Added a help wizard to the first time the program is used and when you start a new setup.
0.0531sec    0.37    5 queries    GZIP Disabled
Time is now: 30th November 2025 - 02:00 AM
