Bump TopicReply to this topicRSS feed Start new topic Start Poll
> Curtain, size (Household)
cyanide
post Mar 29 2010, 10:47 AM, updated 8y ago
Group: Junior Member
since got some voucher for Fella Design.
I'd measure the main window, width = 180cm, height = 210cm and its 30cm from ground.
What is the recommend size for curtain? shall make 5cm extra at each side?
or just ngam ngam the size ?
Awakened_Angel
post Mar 29 2010, 11:10 AM
Group: Senior Member
QUOTE(cyanide @ Mar 29 2010, 11:47 AM)
too short.... best 5 inch... else outside can see inside through from side
leongal
post Mar 29 2010, 11:51 AM
~I have a new mission in life~
when i did mine, i just let the salesperson know how many panel windows, i thought it was standard....but it turned out ok.... smile.gif
harrychoo
post Mar 29 2010, 11:56 AM
Add at least 2 inches at each side.
Then double up ur width as well, so ur curtain will look nicer (like wavy/curvy).
I believe the shop will help u to calculate if u give them the window measurement.
darylchan
post Mar 29 2010, 11:59 AM
I'd say a bare minimum of 6 inches left/right and bottom. That also is barely enough to cover... still will be able to see through if u look thru the window at an angle. (depending on what kind of curtain rails u use.)
Go for 1 foot left/right if your wall space permits. That's for curtain rail length.
Curtain cloth length, go according to how much pleating you want, whether you want flat effect or very wavy effect.
FirezZ
post Mar 29 2010, 12:22 PM
Naise kukUpi
for such curtain .. normally it will hit at what kind of range a ? (price)
cyanide
post Mar 29 2010, 03:08 PM
hi, guys...
thanks for those inputs...
6 inch each side like quite long, certain area it is limited space also.
well, been to the shop just now.
so lousy, sales guy not around
joey85
post Mar 29 2010, 03:16 PM
~Yeah~
QUOTE(cyanide @ Mar 29 2010, 10:47 AM)
normally curtain specialist will suggest u to have extra coz it will look nicer smile.gif i did mine with Macy last time... their service not bad... but dont know bout Fella Design... since u went just now, do u seen their display or sample? nice?
b00n
post Mar 29 2010, 06:32 PM
delusional
Group: Staff
If you want to seek professionals to do your curtain, then give them the measurement and they would tell you how much material you need to buy and reserve for "pleats".
Even if you do not want their service, i.e. you want to ask someone else to sew your curtain; you can still always "pretend" by visiting any curtain showroom, and tell them your measurement. They would tell you how much you need to reserve. wink.gif
IGax2000
post Mar 29 2010, 07:38 PM
normally i do suggest extra 6inch left right for my customer, unless customer themself have other specific requirement.
for curtain height, normally is about half inch from the floor. cuz it looks nicer and elegant if the curtain length longer
Added on March 29, 2010, 7:41 pm
QUOTE(b00n @ Mar 29 2010, 06:32 PM)
brows.gif good idea, but not for me
This post has been edited by IGax2000: Mar 29 2010, 07:41 PM
harrychoo
post Mar 29 2010, 11:42 PM
I got mine done at Kamdar. When they got sales, the price can be cheap and the selection of clothes alot too.
The tailor charge is quite cheap too.
joey85
post Mar 30 2010, 05:27 PM
~Yeah~
cyanide
post Mar 31 2010, 09:55 AM
Thanks! guy...
well, i been to fella design during monday lunch time, the sales guy are not in.
so, just select the cloth only. didn't see any pattern/sample there
zeese
post Mar 31 2010, 11:50 AM
Warning Level
nilai is a good place to get curtains, because they'll sew your curtain on the spot.. pick a cloth, pick a design.. and it will ready in 1 hour.
cyanide
post Mar 31 2010, 02:14 PM
if buy at those place, how to install the rail for curtain ar?
any shop will just do the rail only? how much?
or you all DIY?
rail also got many type. which one better?
joey85
post Mar 31 2010, 05:08 PM
~Yeah~
QUOTE(cyanide @ Mar 31 2010, 02:14 PM)
or you all DIY?
sometimes those tailor made shop (Macy, Fella) did provide & include installation for u (with track)...
if u want to buy normal track (old fashion one) can actually get from hardware shops nowadays just give them ur window panel / length, they will cut for u.. price.. quite cheap... u can also find those tracks at Jusco too...
about the type of track... it depend on which kind of curtain design u choose... for my point of view better get modern design track and modern design curtain - the curtain dont need metal to hang, curtain has hole which directly put go through the track.. it is easier for u to take the curtain out and wash and reinstall back after wash... smile.gif
cyanide
post Mar 31 2010, 05:52 PM
Hi, Joey,
ok. Thanks for the info.
Ya, heard about those track could buy from hardware shop.
if buy there, the problem is still need DIY to install it onto the wall.
This is the part that I'm worried. Without a proper tool (and skill as well), hardly install them neatly. smile.gif
IGax2000
post Apr 1 2010, 01:41 AM
QUOTE(cyanide @ Mar 31 2010, 05:52 PM)
Hi, Joey,
even the curtain track from hardware shop is cheap, but the quality is not that good also.
i believe if u order from fella, they will provide the track installtion as well. and their track will be better than those hardware shop.
joey85
post Apr 1 2010, 09:14 AM
~Yeah~
Hi, Joey,
QUOTE(IGax2000 @ Apr 1 2010, 01:41 AM)
welcome....ya if u dont have proper tool it might be abit problem... but my bro-in-law do it before.. still ok la...but like IGax2000 mentioned... if u ask those pro shops to install for u, that will be better...some dont even charges if u order a set of curtain from them smile.gif
zeese
post Apr 1 2010, 12:18 PM
Warning Level
For 2 door/window panel, the curtain track only has 2 holes that you need to screw it onto the wall.
You need a drill to make a hole in the wall and then, put a wall plug into the hole.
So, it sounds easy. You can learn to DIY.
cyanide
post Apr 1 2010, 01:48 PM
sounds easy.
but... in real, might not be.
if dunno how to handle the drill properly, end up the holes might be loose or a lot of chips....
Thus, best if got pro to do the job. IF the charge is not sky price lah
Added on April 1, 2010, 1:49 pmand for the curtain size of 180cm X 240 cm, can be quite heavy, rite?
This post has been edited by cyanide: Apr 1 2010, 01:49 PM
IGax2000
post Apr 2 2010, 01:08 AM
180cm is only 2 panel window, not very heavy. Depends on what material u used like thicker fabric...hehe
cyanide
post Apr 2 2010, 09:46 AM
its 3 panels wor...
so, like someone mentioned earlier, that's the measurement of window dimension only. In order to get the waving patent, end up the clothes might have up to 300cm X 240 cm. Shall be very heavy liao, rite?
darylchan
post Apr 2 2010, 10:30 AM
If you wanna DIY install, first make sure you have a good drill.
a. Must have hammer function
b. Must have variable speed
c. Make sure you have the correct concrete drill bit
1. mark your holes on the wall.
2. tap the marks with a nail to create a small hole. this is so the drill point does not run and you get accurate holes in the wall
3. choose the correct size wall plugs. they should be tight when you hammer them into the wall.
4. don't overtighten the screws when you install the curtain rail.
5. use a spirit level. this is important to ensure your curtain rail is straight and will save you lots of headache.
cyanide
post Apr 2 2010, 10:59 AM
see... so many steps...
thus, i still prefer to let the pro to do the job (provided not very expensive for the charges lah).
joey85
post Apr 2 2010, 04:28 PM
~Yeah~
QUOTE(cyanide @ Apr 2 2010, 10:59 AM)
ya... save time and save ur energy... why dont u ask them to free for u if u order a tailor made curtain from those shop?? they do offer that smile.gif
IGax2000
post Apr 2 2010, 09:56 PM
QUOTE(cyanide @ Apr 2 2010, 09:46 AM)
its 3 panels wor...
Added on April 2, 2010, 9:58 pmnormally the market price to supply & install curtain track is around RM5/ft to RM6/ft. If u r lucky, maybe can get cheaper than this price.
This post has been edited by IGax2000: Apr 2 2010, 09:58 PM
kathlynn
post Oct 26 2010, 06:22 PM
i have bay windows, hence not straight in a row, which looks like I have to eliminate the wooden rod.
I saw in ikea they hav somethin like single track, double track, etc anyone used those b4? r they ok?
alt, can i get somethin like tat from a hardware shop?any good reliable h/ware shop to recommend?
sonerin
post Oct 26 2010, 08:38 PM
Yes you can get the single/double track from hardware shop. I will recommend living depot.
IGax2000
post Oct 27 2010, 08:59 PM
u can use either a bendable track or normal curtain track.
bendable track or curve track is much more expensive than normal curtain track because it can bend to fit bay window or u shape window
kathlynn
post Oct 28 2010, 11:41 AM
went to baagus ytd to get the first quote, nearly fall off my chair.
will cost me bout RM4.5k to do curtains for my whole hse!
or was i jus naive to believe that curtains r not that exp? looks like i hav to live on bread & water for the next few mths!
they recommended the bendable track for bay windows. for kitchen windows, the recommended those 'pull blinds'
for living room & masterbedroom, double layer.
Added on October 28, 2010, 11:43 amigax - how was this done with wooden rod? http://www.facebook.com/photo.php?fbid=184...00.183991179245
from your fb! thanks!
This post has been edited by kathlynn: Oct 28 2010, 11:43 AM
Drian
post Oct 28 2010, 12:02 PM
For those ceiling height curtains whereby the top is hidden by plaster ceiling, how do those people install the curtain railings on such small opening ? Or do they install the curtain railings first before installing the plaster ceiling.
vvn0vvn
post Oct 28 2010, 02:19 PM
actually the normal curtain railing you can get from hardware shop, even for those bendable railing are available. it is pretty cheap actually. well, unless you are looking for more fancy type then u have to look elsewhere.
IGax2000
post Oct 28 2010, 09:44 PM
QUOTE(kathlynn @ Oct 28 2010, 11:41 AM)
of course bagus expensive lar, branded mar
if u use normal curtain track for all of ur hse, double layer
then kitchen using mini blinds
Might cost less than that figure. Somehow depends the curtain material u choose
wooden rod can install at bay window by using bay corner joint
Added on October 28, 2010, 10:04 pm
QUOTE(Drian @ Oct 28 2010, 12:02 PM)
normall do the plaster ceiling first the install the curtain track using ceiling bracket.
This post has been edited by IGax2000: Oct 28 2010, 10:04 PM
Drian
post Oct 29 2010, 01:06 AM
QUOTE(IGax2000 @ Oct 28 2010, 09:44 PM)
oh ic ceiling bracket never thought of that... i thought is wall.
Added on October 29, 2010, 1:08 am
It's not that hard... but quite time consuming. Done it before. If normal brick wall it's ok, if it's a beam it takes ages to drill through it.
This post has been edited by Drian: Oct 29 2010, 01:08 AM
kathlynn
post Oct 29 2010, 11:59 AM
oh, tats nice. wud it cost alot more to have wooden rod vs normal track? I do love the wooden rod feel as oppose to jus norm curtain track. but any qualms on using wooden rod? my mom experience is that the rod went lopsided after a while (coz curtain too heavy i suppose?)
IGax2000
post Oct 29 2010, 07:43 PM
if u check at ikea or jusco, the rod might cost u RM15/ft.
i do like wooden rod especially white colour
Wooden rod is nice, but after some time it is hard to pull the curtain because of the dust at the top. So either u instead of pulling the curtain to the side, u can hang the curtain attch to the side hook. or pull the curtain with patience biggrin.gif
SnoWFisH
post Nov 7 2010, 02:13 AM
I need some advise on some curtain here. I got a L-shape 6 panel window (5 panels only can be opened), with 1 single panel at the corner. So its shape is like a ------| ).
6 panel side is 340cm, 1 panel is 45cm.
Is my following requirement reasonable (or more like, possible??
a. Rod-type curtain. The rod has to be in 1 piece, so the corner of the rod would need to be bent.
b. Double layer curtain. 1 layer net-type, 1 layer actual curtain.
c. If possible, the curtains can ALL be pushed to one side of the window (whether its end of the 6-panel, or the single panel).
Thanks.
IGax2000
post Nov 7 2010, 11:52 PM
if u want to install rod, have to be 2 pieces. cuz the rod is not bendable.
Or u can install double track / 1 rod 1 track / curve track
numbertwo
post Nov 8 2010, 10:35 AM
no, i saw a curvy rod done by a curtain specialist @ kota damansara, i think it is a stainless steel rod... I think!
kathlynn
post Nov 8 2010, 11:07 AM
got another quote for RM3.5k
breakdown as follows:
living room - approx 7ft*8ft (nite+day curtains) - RM1k
study room - approx 10ft*6ft (blackout) - RM0.5k
roller blinds (kitchen& laundry) - approx 16ft*4ft - RM1k
master bedroom (nite+day curtains 7ft*8ft ) & roman blinds (7ft*6ft) RM1.2k
this quote are for s'pore pleat, incl of instalation of track, delivery, etc,etc
is it ok? exp?
This post has been edited by kathlynn: Nov 8 2010, 11:11 AM
vvn0vvn
post Nov 8 2010, 11:39 AM
for bay window i still think the bendable railing are nicer (clean cut) and more practical (in the sense that it is easier to pull). but of coz it is just personal preference.
anyone has been to nilai? heard that it is cheaper and have lots choice. is it true? worth a visit?
numbertwo
post Nov 8 2010, 01:40 PM
QUOTE(kathlynn @ Nov 8 2010, 11:07 AM)
is it ok? exp?
kath..material and cost varies I suppose.. I went to a curtain shop yesterday...a cheap material (imported too) cost slightly more than a K for our main sliding door 12ft x 8"..a better imported material would cost us 3K.. so is hard to tell unless we are comparing the same material..
kathlynn
post Nov 8 2010, 02:58 PM
QUOTE(numbertwo @ Nov 8 2010, 01:40 PM)
the mat i used are mostly from china i suppose. not italian/turkey, etc.
how do you define 'better' material in context of curtain? thicker?
IGax2000
post Nov 8 2010, 08:35 PM
QUOTE(numbertwo @ Nov 8 2010, 10:35 AM)
tongue.gif i'm talking about wooden rod
Added on November 8, 2010, 8:46 pm
is it ok? exp?
This post has been edited by IGax2000: Nov 8 2010, 08:46 PM
SnoWFisH
post Nov 8 2010, 09:35 PM
QUOTE(IGax2000 @ Nov 8 2010, 08:35 PM)
Oh material doesn't matter much to me, as long I can get the shape that I want. Most likely I'll prefer metal rods as I plan to get the normal rods from Ikea. Any contacts who can do this in Penang?
numbertwo
post Nov 8 2010, 10:55 PM
QUOTE(kathlynn @ Nov 8 2010, 02:58 PM)
indeed... the design, material & finishing are all differs from one another. on the design wise, a more expensive sheers, it give a much better elogant look to the living hall.. On the material wise, I had bad experience on the cheapo material b4, it shrunk terribly after washing. And I believe even China made material would have different classes by its own?
IGax2000
post Nov 9 2010, 09:00 PM
t rclxms.gif good thing of course cost higher
numbertwo
post Nov 10 2010, 01:17 PM
btw..dear experts.. do you think roller blinds are practical in the wet kitchen (with hoob+hod)? would it be too oily/sticky after sometimes?
Shazzac
post Nov 10 2010, 01:24 PM
QUOTE(numbertwo @ Nov 10 2010, 01:17 PM)
It definately will, but roller blinds - they have cheap ones as well. Can get those and get it replaced every year or 2 years depending on how dirty it gets.
IGax2000
post Nov 10 2010, 07:55 PM
yes, it will. So if u prefer to use roller blinds u can choose those pvc balckout material. so that u can mop with wet cloth.
or like what bro shazzac said, use those cheaper blinds like venetian blinds. once dirty replace a new 1 biggrin.gif
numbertwo
post Nov 11 2010, 03:23 PM
haha..ok then...since when did we introduce curtain into the kitchen lol..bizzare idea but it is nice!
kei18kun
post Jan 1 2011, 04:39 PM
Coconut in the sea(TM)
do check out my signature
numbertwo
post Jan 1 2011, 10:16 PM
for those who frequent Puchong area, my recommendation goes to BNS curtain (just a floor up 'Ah Xian Dim Sum').. Don't expect any spectacular showroom there, but you get a very personalized service from the brother and sister who runs the business..price vs material is good compares to a few other curtain showrooms in that area.
wicong
post Jan 22 2013, 04:35 PM
hai,i have get this std curtain around rm 35-68 per set. Some of them got pattern ,would be more expensive around rm45-80. The sliding door curtain around RM 110-180 (3-4panel sliding door)per set. Total i get below rm 500. hope your guy like it!
ask_dino
post Apr 26 2017, 03:05 PM
DS is the name
Any recommendations for whole house curtain provider?
spreeeee
post Apr 26 2017, 05:23 PM
QUOTE(ask_dino @ Apr 26 2017, 03:05 PM)
was recommended by friend, OneU Homes Harmony - go look for a madam who incharge curtain department.. surprisingly good price and lots of materials to choose from.
ask_dino
post Apr 26 2017, 05:49 PM
DS is the name
QUOTE(spreeeee @ Apr 26 2017, 05:23 PM)
Do they provide railing and installation as well?
spreeeee
post Apr 26 2017, 08:32 PM
QUOTE(ask_dino @ Apr 26 2017, 05:49 PM)
Yes, someone will come over your place to confirm the measurement before sewing the curtain based on your needs
enriquelee
post Apr 27 2017, 09:15 AM
Don't ask for more, ask for COKE
You can survey at Nilai2, many shops there and reasonable price.
But I am not sure whether they do installation or not.
ask_dino
post Apr 27 2017, 09:17 AM
DS is the name
QUOTE(enriquelee @ Apr 27 2017, 09:15 AM)
I see thank you, will take note on that.
enriquelee
post Apr 27 2017, 09:31 AM
QUOTE(ask_dino @ Apr 27 2017, 09:17 AM)
Last time I did it there, just buy the curtain. It is more than 50% cheaper than those shops I check in KL.
Bump TopicReply to this topicTopic OptionsStart new topic
Switch to:
0.1478sec    5.78    5 queries    GZIP Disabled
Time is now: 23rd January 2018 - 10:10 AM
