 Pivot MEGA RAIZIN, Universal
TSlolss
post Jan 13 2010, 09:03 AM, updated 16y ago
Would like to enquiry that is the above pivot mega raizin universal(Can be fitted on any car models)?
As there are some freaks saying that this stabilizer only suitable for turbo charge cars..
isit true?
would like to heed some advice from fellow shi fu and guru here
thanks
makaveli
post Jan 13 2010, 09:15 AM
Livin' la Vida Loca
It does stabilized the voltage/headache that get thru all the way from battery to sick alternator.Much like give good flow of current to the alternator.
But if its FAKE/IMITATION,say bye bye la !
TSlolss
post Jan 13 2010, 09:24 AM
Nowadays all made in Taiwan right?
does it function the same as the original?
heard from accessories shop that it function the same way
maelzx
isha.my
yup the voltage stabilizer can be fitted to any car....
even for fake/imitation/replica it will still work. some guy even made it himself, still able to achieve the same effect.
it just those original and branded one will come with extensive testing and some do dyno test.
TSlolss
post Jan 13 2010, 09:25 AM
orh icic
thanks for the infos bros
who replied to my new topic
the_catacombs
post Jan 13 2010, 06:58 PM
8 stars wooo....
QUOTE(lolss @ Jan 13 2010, 09:03 AM)
isit true?
thanks
dat freak is stupid
babyiswara
post Jan 13 2010, 09:41 PM
Wow....sifu catacombs spoken....
the_catacombs
post Jan 14 2010, 12:16 AM
8 stars wooo....
QUOTE(babyiswara @ Jan 13 2010, 09:41 PM)
779364
post Jan 14 2010, 12:24 AM
Starry Starry Night
who say its only for turbocharged cars?
Why,normal car no need electricity to run ah.Actually,voltage stabiliser depends on which car models.Those premium car already have very good voltage stabiliser and grounding.This is more towards proton and perodua or basic cars.Inside contains a couple of big capacitor with high discharge rate.They help flatten out your electricity current curve during high load like when your compressor kicks in by releasing their charge to compensate the sudden drop in voltage.
Or if you are a fuzzy guy with an expensive audio system in car,this voltage stabiliser does help alot.It also prevent headlight dimming when your compressor kicks in but that one leaves much to be desired cause some reported that their headlights still dim after installing one.
Buying pirated or original one does not matter but if you are looking at china made one,buy one with good and proper capacitors and at least with a properly made outer casing.You dont want to buy one with shoddy casing that melts or cant stand engine heat and cracks etc.
its usually mounted on your car battery side.
Performance wise,does not make any difference and also towards FC.No noticeable changes so all those hoo - ha about increase in hp or FC is pure bullshyt and is just a marketing gimmick.
This post has been edited by 779364: Jan 14 2010, 12:26 AM
TSlolss
post Jan 14 2010, 02:27 PM
QUOTE(779364 @ Jan 14 2010, 12:24 AM)
ok bro
thanks for ur clear explanation of how this thing work outs
thnaks
Added on January 14, 2010, 3:22 pmsorry about raising this topic again
how to check whether it is a imitation of the product
nowadays all are import from taiwan right?
even though the supplier said that it is from Japan
any difference between Japan And Taiwan made?
Can the outer Casing of the product dertermine whether it is imitation or original?
This post has been edited by lolss: Jan 14 2010, 03:22 PM
makaveli
post Jan 16 2010, 12:24 AM
Livin' la Vida Loca
Check pivot website.You'll get the answer.
Mr.Dark Angel
post Jan 16 2011, 02:05 PM
it have K mark on capacitor....even now taiwan made also have K mark....dulu X mark now there copy almost 100% like original....
the_catacombs
post Jan 16 2011, 07:04 PM
8 stars wooo....
aiya.. any voltage stabilizer will work one lahh... pay few hundred bucks on minor improvement where cheap cheap one can do the same...
Vervain
post Jan 17 2011, 03:03 AM
Scathach
Wah. Sifu skywalker has spoken
Actually smaller caps discharge faster. Just that they can't store more and you need combinations of big and small to even out the fluctuation.
sinister_sid
post Jan 17 2011, 03:25 AM
junk la this mumbo jumbo stuff
if think properlly where got engine use battery power after the engine is running ?????
that 1 is alternator job d
if switch on headlamp and aircond sure will like weak for a sec cause draw alot power ma
ya put this junk will reduse the efecct but worth it ka ?????
all this is acc shop punya hype la
the_catacombs
post Jan 18 2011, 06:05 AM
8 stars wooo....
haha.. i also dunno why people willing to pay up to 500bux for a voltage stabilizer which only make 0.01% difference in performance... somemore wanna insist in original...
so whats the hierarchy here??... original > custom made > imitation??...
custom made voltage stabilizer better than imitation voltage stabilizer??...
sinister_sid
post Jan 18 2011, 12:48 PM
QUOTE(the_catacombs @ Jan 18 2011, 06:05 AM)
u buy ori 1 then put the sticker beside ur car will increase ur horsepower 1 ma dunno ka u ???
the_catacombs
post Jan 18 2011, 01:36 PM
8 stars wooo....
QUOTE(sinister_sid @ Jan 18 2011, 12:48 PM)
sinister_sid
post Jan 18 2011, 01:56 PM
QUOTE(the_catacombs @ Jan 18 2011, 01:36 PM)
ngv sicker tuned d ma
mine keng 1
rust effect tune
SUSkyheng
post Jan 18 2011, 02:30 PM
VS, grounding kits most of them can help <0.00000001%. Rather than wasting moeny to get a piece of junk, why not spend some money by getting a good quality battery?
Battery is used to starting the car, then alternator will do all the works. Every equipment in the car are built to operate at 10-15V, so it cause any damage. But a soon to die alternator will kill the equipments. At such point, even junks can't help you.
the_catacombs
post Jan 18 2011, 06:18 PM
8 stars wooo....
QUOTE(sinister_sid @ Jan 18 2011, 01:56 PM)
mine keng 1
rust effect  tune
QUOTE(kyheng @ Jan 18 2011, 02:30 PM)
good battery provides more stable voltage supply??..
mfa_145
post Jan 18 2011, 09:00 PM
QUOTE(the_catacombs @ Jan 18 2011, 06:18 PM)
sweat.gif he sound like a pro. heh watdehelloanybodyhome after reading such comment.
SUSkyheng
post Jan 18 2011, 09:09 PM
I'm not a pro, just that I'm very sure that there's no point on adding junks.
And please, if you having problem on understanding my reply, keep your mouth shut and don't simply type....
mfa_145
post Jan 18 2011, 09:21 PM
sukati akulah nak type ape. aku peduli ape. forum ni bkn bapak sapa2 punya pun. org type rubbish blh, bukak topic rubbish blh, xkan aku nak type ape2 dlm ni xblh. aku peduli apa.
MyWifeCar
post Jan 19 2011, 10:11 AM
★ Car Soundproofing DIY~
I only notice the VS works on Perodua... My fren tried on Vios and BLM... didn't notice much diff, except the headlight didn't dimm that much when compressor kicks in.
sinister_sid
post Jan 19 2011, 01:16 PM
QUOTE(MyWifeCar @ Jan 19 2011, 10:11 AM)
toyota and saga blm have good voltage regulator build in the alternator so not much diffrent
this can be cannot be sure as u must take the car age as a factor
as car get older the part start to wear out , bla , bla , bla
like mine saga i pull the cable of the post and use copper brush gosok gosok until kilat
the effect like they say on the voltage stabilizer lo
air cond kick in not so dramatic
this so called votage stabilizer is just capasitor to provide short voltage for short while only
this was by audio entuatist because they put in big sub and amp to give the boom boom they want for competiton
so when u use big amp and big sub the voltage require will diffrent because of the changes of bass note in a music track
so the capasitor was use to provide extra power when the amp needed it
SUSkyheng
post Jan 19 2011, 01:19 PM
Wow, big amp with big sub must add junk... That's another myth by some people, especially have direct interest in this field....
I also have a "big" amp and "big" sub, but I never have lights dimming issue....
sinister_sid
post Jan 19 2011, 01:22 PM
http://www.youtube.com/watch?v=oZqCdrd_uAs&feature=related
http://www.youtube.com/watch?v=x_SHUrViDWA&feature=related
http://www.youtube.com/watch?v=oA94zn6-9sU&feature=related
this is called spl competitior
jackass !!!!!!!!!!!!!!!!!!
This post has been edited by sinister_sid: Jan 19 2011, 01:40 PM
SUSkyheng
post Jan 19 2011, 02:35 PM
Using 2 250A alternator....With engine running.... By theory it will be getting 500A of current.... And he never state got any junk added....
sinister_sid
post Jan 19 2011, 03:49 PM
QUOTE(kyheng @ Jan 19 2011, 02:35 PM)
btw i dun endorse ppl to use this junk
i just saying that who started using this thingamagic
SUSkyheng
post Jan 19 2011, 03:54 PM
Magic? Because those says a junk is good to their system never do their homework and research properly...
sinister_sid
post Jan 19 2011, 04:10 PM
QUOTE(kyheng @ Jan 19 2011, 03:54 PM)
Naughty_Kidz
post Jan 20 2011, 02:21 AM
QUOTE(the_catacombs @ Jan 16 2011, 07:04 PM)
SUSkyheng
post Jan 20 2011, 10:30 AM
+2 +3 +4 +5 +6......
Indeed, getting those so-called original capacitors will help in 0.1-0.2V for 0.5-1 seconds indeed are smart..... Only the stupid won't waste money for such improvements.....
Naughty_Kidz
post Jan 20 2011, 12:18 PM
either is original or imitation .. it do help improve the car electric circulation .. which could provide better light vision from ur headlamp,sound system,enfine performance... but this all also depends on certain car .. and the age of the car ..
SUSkyheng
post Jan 20 2011, 03:59 PM
Since you are so good on this junk(in terms of knowledge), can it make my ~8 year old car's headlight that already turned yellow brighter without changing to brighter bulbs? If this piece of junk can help, I retract my words.
BTW, no wonder you die hard say a junk is good, because you are selling it..... Conflict of interest....
the_catacombs
post Jan 21 2011, 01:52 AM
8 stars wooo....
QUOTE(kyheng @ Jan 20 2011, 03:59 PM)
change new bulb will have better effect... bulbs do have lifespan... same goes to ur household florescent lamp... it gets dimmer over time...
SUSkyheng
post Jan 21 2011, 08:39 AM
^Yes, you get my point..... Lights dimmed add junk? That's a joke....
the_catacombs
post Jan 21 2011, 08:03 PM
8 stars wooo....
QUOTE(kyheng @ Jan 21 2011, 08:39 AM)
many people dunno one alwiz get conned by accessory shop saying add this and dat lor... datz why they spend unnecessary money on stuff which does not bring much good...
dun say junk laa... they just dont worth the amount u pay for...
SUSkyheng
post Jan 21 2011, 08:49 PM
You adding something and it helps means it is something.
If you add something and never helps, it is called junk.
Just like food, food that brings no nutrition is called junk food...
amad108
post Jan 22 2011, 08:06 AM
too much of something is bad enough
lol, better buy e-manage la or change the whole car wiring to new one.. compare buy this junk of no use at all.. summore most of the car using it is new car, for wht meh? even me 15 years old injection car not using this junk...
well anyone can say anything, but do think b4 write down, use meat inside ur head ya, we here mostly discuss professionally..
judojuddy
post Jan 22 2011, 08:56 AM
SUSkyheng
post Jan 22 2011, 09:51 AM
QUOTE(amad108 @ Jan 22 2011, 08:06 AM)
Wow, lucky inside my head got brain only.....
sinister_sid
post Jan 22 2011, 10:48 AM
QUOTE(kyheng @ Jan 22 2011, 09:51 AM)
Boss cooled down . I think whole lyn know ur point d la . What u so pissed off about ? Some ppl cannot affort big mod ma so they tempted to buy this thing hope will boost performance ma . In the end it is marketing hype
SUSkyheng
post Jan 22 2011, 10:56 AM
That's why we must let people know about this.... rm1++ I can buy 1 drum of alcohol which will really boost my RON to 99 and my car can fly, haha....
But 1st run failed on RON increased test and passed the fuel injection cleaner test.... Again, this is a good savings for me(1 bottle of fuel injection cleaner cost rm20-30)
And I never pissed on that.... Why do I need to?
amad108
post Jan 22 2011, 11:06 AM
ops.. a really harsh word i said.. apologize for my rudeness, coz this topic discuss many times b4.. still people open as new thread, maybe need to make as sticky topic about this kind of product.. just to inform them which one is working n which one is working great..
again sorry for my rudeness..
the_catacombs
post Jan 22 2011, 08:55 PM
8 stars wooo....
people's money... they wanna buy up to them lo... if we pour cold water later they emo pulak....
acbc
post Jan 23 2011, 09:53 AM
I'll admit one thing... I did install this Pivot thingy on my old 1990 Mitsubishi Galant VR4 and while I don't see any improvement in power and consumption, it did however made the car easier to start on Sunday (I only start the car every Sunday). Without it, I will need to crank a few times to get it started.
On my smart, this thingy produced many side effects and the car ended up in limp mode (ECU detected errors).
This post has been edited by acbc: Jan 23 2011, 09:53 AM
coolkwc
post Jan 24 2011, 06:09 PM
Fall in love with audio again.
Alternator/battery and capacitor huge different is their discharge rate.
Those current surge/voltage drop can only compensated with capacitor (instantaneous,extremely short time), even if your alternator got 1000A also useless, it just can't compensate fast enough compare to capacitor.
Try to think about that, every PSU circuit they are main filter/supply caps, what the purpose? Same as what i said above.
I'm R&D engineer in electrical field, i'm talking neither based on my book nor my cock, but from my research and result from expensive testing equipment. smile.gif
Still add or not is up to you, becos most of the electrical equipment such as amp and player adi got such same function cap inside, just that usually the value is too small to store enough charges. If your car alternator is bad in nature, add or DIY cap aka VS will help a little bit.
This post has been edited by coolkwc: Jan 24 2011, 06:12 PM
Oldskolboyz
post Jan 26 2011, 02:18 AM
If I not mistaken, we should change cable to bigger (1/0 Awg) for Alternator to Battery (+) & ground cable from Battery (-) to chasis as well. This will help rather than add what so call voltage stabilizer. Welding cable with thicker core highly recommendable. Can compare between cable use by BMW/MERC/AUDI with Proton/Toyota/Honda/Kia/Hyundai..
sinister_sid
post Jan 26 2011, 09:23 AM
QUOTE(Oldskolboyz @ Jan 26 2011, 02:18 AM)
where to find this thicher cable
i want to do battery relocation to boot but have hard time sourcing cable
Oldskolboyz
post Jan 26 2011, 09:48 AM
QUOTE(sinister_sid @ Jan 26 2011, 09:23 AM)
You can ask/contact this person if he can sale based on personal use.
Nizam: 03-51216603
Area: Bt. 7, Jalan Bukit Kemuning, Shah Alam.
or
CT Power Tools (001921957-H)
Add : 37, Jalan Temenggung 21/9, Seksyen 9,
Bandar Mahkota Cheras, 43200 Cheras, Selangor.
(Just Opposite the New Jusco Mahkota Cheras)
Contact : Jimmy Chuah .. +6012-233 2036
Tel. / Fax. : +603-9074 6934
CT Hardware Sdn. Bhd.
03-7877 8255 or Or email to cthard3@gmail.com
Showroom:
No.3, 5, 7 & 11, Jalan SS2/3,
47300 Petaling Jaya, Selangor,
West Malaysia
Tel: 603 - 7876 0000
Fax: 603 - 7875 0911
Email: cthard@gmail.com
No.35, Jalan Petaling Utama 1,
Batu 7, Utama Industrial Park
46000 Off Jalan Klang Lama, Selangor
Tel: 603 - 7783 2116
Fax: 603 - 7783 2043
Email: cthard2@gmail.com
No.12, Jalan 21/12, Seapark,
46300 Petaling Jaya, Selangor,
Tel: 603 - 7877 7710
Fax: 603 - 7877 5253
Email: cthard3@gmail.com
sinister_sid
post Jan 26 2011, 11:17 AM
QUOTE(Oldskolboyz @ Jan 26 2011, 09:48 AM)
Nizam: 03-51216603
or
Showroom:
West Malaysia
SUSkyheng
post Jan 26 2011, 01:31 PM
Actually you no need thicker cable, that's a busted myth from US audio forums.... What you need to do is, ask your foreman to take out the connector and clean it.... Make it this way :
1. an 1/0AWG power cable can transfer 200-300A of current.
2. a standard alternator output usually rated 75-120A.
So, will it really improve your system? I in doubt. If really worry about this, even a 4AWG power cable from US are more than enough... I never buy cable in Malaysia, as the cost for 1ft I already can buy 1M which having better quality....
Added on January 26, 2011, 1:41 pmhttp://www.knukonceptz.com/productDetail.cfm?prodID=KFX4BK
20ft should be enoguh for you on this.... So (20*1.55+13.50)*3.1=rm137.95.. And it will reach to your door steps within 2 weeks time.... I'm using it and very happy with it....
This post has been edited by kyheng: Jan 26 2011, 01:41 PM
Oldskolboyz
post Jan 26 2011, 02:50 PM
Yes, it is busted myth from US audio forums but the most funny thing/part has been adopt by all luxury cars especially BMW, MERC, AUDI, ASTON & etc.. even Ferrari as well. drool.gif .. Opps I forgot U just drive Wira everyday, so never own 1 before... don't said your frend own 1 laa coz that is your trademark since in zth.. doh.gif whistling.gif . haa haa.. after 6 years I absent, your attitude same as before.. I'm very pity to you, so sad. cry.gif
at least better than standard stock cable with more current flow to Battery tongue.gif
Based on what U claim 1ft price same as 1m long, which hardware u go... as I know just RM6.50 per meter for 200a & RM8.00 per meter for 300a.. doh.gif
amad108
post Jan 26 2011, 05:20 PM
err.. my friend use thicker cable sure got improvement especially when cranking the engine..
even his ecu need to be retune coz power supply b4 n after done install thicker cable increase the power supply to injector later then increase the fuel injected to engine..
SUSkyheng
post Jan 26 2011, 06:07 PM
QUOTE(Oldskolboyz @ Jan 26 2011, 02:50 PM)
So, that's the best you can do? Ask your friend to come, I'm ready for your gang's stuffs.... Everything is being calculated when car manufacturers come out a new model, or you trying to say you are clever and they are stupid? Even my another question also you chickened out... I know you want to do business here, but then please do it in the ethic way.... I also know you are trying your best to mislead others but do indicate what's the alternator output for the cars you mentioned? Or you are trying to say those car's alternator only outputs 50-75A of current?
http://www.car-stuff.com/bmwalternator.htm
So, what type of power cable to use for a 155A output alternator, can normal smaller power cable cater for this? I know, you just want to insult me, but please, get some facts first before you want to do so....
http://www.car-stuff.com/mercedesalternator.htm
Oh boy, this is Merc's alternator, 150A....
http://www.car-stuff.com/audialternator.htm
This is Audi's, again, 150A....
And welding cable do sell cheap, but it is flexible? Again, you never state....
If you were to insult me, I guess you just failed today.....
amad108
post Jan 26 2011, 06:17 PM
yup, agree with kyheng.. for thick cable use inside car need to be flexible, if not later on crack due to vibration, heat, n cold environment...
no need to double standard la, all car still a car right? fast or slow, xpensive or not all its still a car..
SUSkyheng
post Jan 26 2011, 06:34 PM
Temperature won't affect much on the cable's insulation... Malaysia is not a 4 season country.... But under those countries, the insulations really can be damage due to this....
A car is car, in some sense I do agree with you. But then our friend want to do business and I stand in his way, so he will try his best to mislead other that I'm wrong.... Out of those brands, did he take out other car's with lower alternator output? He never... Because if he do like this, it is same as he is slapping his own face.....
Have to know that, comparing apple to banana always the best way to mislead others.
amad108
post Jan 26 2011, 06:37 PM
then just ignored him.. people nowadays quite clever too, let people judge.. peace bro.. hehe
SUSkyheng
post Jan 26 2011, 06:38 PM
^^Yeah, you are right.... Peace man, peace... That's why do own research will be the best....
Oldskolboyz
post Jan 27 2011, 12:33 AM
QUOTE(kyheng @ Jan 26 2011, 06:34 PM)
haa haa 2nd Trademark normally use for last bullet...
Yes, I do a business.. but not in ft or meter but in barrel.. If U want order can but must paid 3 month in advance for September 2011 delivery.. Market now USD86.41, I dont deliver 1/3, 1/2 of my monthly production. Only deal for the whole month production, daily production is 250,000 barrel. 30 x 250,000 x USD86.41 x 3 = RM1,944,225,000-00 (Shipment at your own cost).. If agree can PM me..
2nd business also not in ft or meter but in inch, the smaller 1 is 3" price USD121,600 per unit and the bigger 1 is 12" price USD980,000 per unit.
Because your the only 1 is clever here..
I give you simple test.. U have 5 liter bottle need to fill up with water at your sink but U have prob coz pipe & sink did not have lot free space to feed the bottle under the pipe. So U need a pipe hose to fill it.. here my question.. which 1 take faster time to fill the water into your 5 liter bottle? 1" hose pipe diameter or >3" hose pipe diameter.....
base on that, you think 5 liter bottle as BATTERY, the pipe as ALTERNATOR & hose pipe as Power Cable... Using Thicker cable doesn't mean can increase current in your car system but can make your battery recharge faster than Small or standard cable.
Added on January 27, 2011, 12:38 am
QUOTE(amad108 @ Jan 26 2011, 05:20 PM)
This is a craps statement.... but kyheng did not have problem on it even he said earlier, his change to 4awg cable.. so he need to retune his wira ECU..
This post has been edited by Oldskolboyz: Jan 27 2011, 12:38 AM
amad108
post Jan 27 2011, 12:59 AM
QUOTE(Oldskolboyz @ Jan 27 2011, 12:33 AM)
err.. i do hv a prove bro, i got actual car which its my friend car n the car is fairlady 300ZX.. his car as below picture, still dont believe it then please come to shah alam i will escort u to see the car..
ur word seem u kinda know a lot, but just writing anyone can do.. please be more professional in replying here, here we share the knowledge not insulted anyone, if anyone wrong please do correct him/her.. try to be nice with other people 1st, then people start to threat u nice later thumbup.gif
This post has been edited by amad108: Jan 27 2011, 01:03 AM
Oldskolboyz
post Jan 27 2011, 01:53 AM
QUOTE(amad108 @ Jan 27 2011, 12:59 AM)
Actually who the 1 bashing others opinion here at the 1st place, "that's a busted myth from US audio forums".. did we talk audio here. To me, his message carry "Stupid Fella try to consult others with stupid idea".. I own 350z...
The most I hate this fella always "ACCUSED" others people doing "OWN BUSINESS" here... that not my level laaa... pleasedddd laaa
This post has been edited by Oldskolboyz: Jan 27 2011, 02:05 AM
SUSkyheng
post Jan 27 2011, 06:34 AM
amad108, see how this coward hide his fear... When I able to show something, he quickly use other statements to continue insults me and run away from the original question... Typical screen dumb.. But then the name is right suit him, oldskolboyz... He still thinks that what he and his gang used 6 years(group bash) can use on today...
And that statement on myth does not only applies on audio, it can be used on other matter. What requires more power than audio system? Coward, you can drift from this question like you always does, the old school way you did last time. 6 years ago, people might be stupid enough and may listen to you on your flaws, but not now....
This post has been edited by kyheng: Jan 27 2011, 08:08 AM
amad108
post Jan 27 2011, 09:24 AM
haiz.. nevermind la, i just show my point..
between even u (oldskolboyz) hv GTR35 it really does'nt matter to me, coz good car need a good driver, if not its just a waste..
even me only using wira, still i appreciate it a lot.. the car can give me goose bump sometimes, n adrenalin rush happen quite a numbers when drove it.. so wht car u drive as long it can give u joy consider the best car for him/her...
kyheng: just let it be bro.. hehe
Oldskolboyz
post Jan 27 2011, 10:37 AM
QUOTE(kyheng @ Jan 27 2011, 06:34 AM)
haa... haa.. this is a new... condem people nickname, I tot you only have 2 trademark, after 6 years I did no how many trademark you create/keep..
Thanks to proof your are the most professional members in LYN.. my simple test didn't answer? what you want to proof/show here...
SUSkyheng
post Jan 27 2011, 12:07 PM
QUOTE(amad108 @ Jan 27 2011, 09:24 AM)
Indeed have to let it be, let the coward to continue bark as he like, haha.... 7 years must do engine top overhul... What a joke man....
Wilson13B
post Jan 27 2011, 03:24 PM
QUOTE(sinister_sid @ Jan 17 2011, 03:25 AM)
Try to disconnect the battery and drive the car ~ see ur alternator will kong or not ~
Alternator job is to SUPPORT the current of the Battery , the main electric for the car is produce by the Battery ~
amad108
post Jan 27 2011, 11:54 PM
i last time my connector at the battery a bit loose, so when the car vibrate coz of hitting holes (on the road) my engine died for a while n running again, n i try high beam again my engine died for a while n running again as soon i let go the high beam switch.. so even while driving, power from battery still being used..
SUSkyheng
post Jan 28 2011, 12:04 AM
Closed circuit = current can pass...
Opened circuit = current cannot pass...
When alternator's cable being discnnoected(opened circuit), how the alternator will kong?
Then another stupid question that always come in to my mind, alternator's output voltage higher or battery's voltage higher when the car is running?
amad108
post Jan 28 2011, 02:21 PM
QUOTE(kyheng @ Jan 28 2011, 12:04 AM)
haha.. seriously dude, dunno about that..
so for people hv voltage reading actually read it from where? alternator or battery or anywhere can be located?
makaveli
post Jan 28 2011, 03:36 PM
Livin' la Vida Loca
should that we need to care more on alternator then the battery.
the battery remain charging mode while alternator works for cuircuit.
SUSkyheng
post Jan 29 2011, 12:15 AM
QUOTE(amad108 @ Jan 28 2011, 02:21 PM)
Altaernator producing 13.5-14.4V while battery is 12-12.5V.... Because of this, alternator can charge back the battery at a specific rate... Without engine started, the voltage will be 12-12.5V... It does not matter much where you tak your easurements, provided the place you put the probe are clean and low resistance...
Always keep you battery terminals clean.
BTW, I have a "special" problem now, after park the car for >8 hours, I can start the car easily... But when I park my car for <8 hours or start and stop by to buy something, I will be having problem to start my car back...
sinister_sid
post Jan 29 2011, 11:10 AM
QUOTE(Wilson13B @ Jan 27 2011, 03:24 PM)
u think remote control of ur tv ah ????
battery drain out go charge with battery charger ????
do some uncle google before speak ????
the main eletric for the car is produce by the battery ????????
what a joke
so u run city no need use alternator la
SUSkyheng
post Jan 29 2011, 11:16 AM
^^That's why post#71 is there....
But, battery do have its function also, producing initial power to start your car... That's all. Other than that, alternator is doing the job... Unless you got a sound system that really requires very high power and can bring the voltage down to 12V or slightly below, else the battery power won't be used....
amad108
post Feb 1 2011, 07:23 PM
my car got no sound system anymore.. hv been use my batt for more then 2 years.. not free maintenance batt (b4 this use Bosch S4 only last for 1 n half years, dunno why.. huhu), but keep the batt terminal clean is good tips.. hehe
SUSkyheng
post Feb 1 2011, 09:09 PM
^^dirty terminals are not good at all.... Especially when your car engine compartment are hot.... I already zoom down to my dirty terminals, just that now already CNY, so lazy a bit to take it out and clean the terminals... Already made a stupid mistake once, don't want to make second time.... But this time around I may add another ground from engine back to battery(since I got new battery terminals)...
Added on February 1, 2011, 9:10 pmBut then a lot people don't know about this and start adding junk just to sweep the actual problem under the carpet..
This post has been edited by kyheng: Feb 1 2011, 09:10 PM
Vervain
post Feb 1 2011, 09:56 PM
Scathach
QUOTE(kyheng @ Jan 29 2011, 11:16 AM)
try to start your car then take out the battery then drive around. 30 minutes later your car will stall. Unless you drive a car with carb engine, the mention symptom is common among all fuel injector cars. The car does consumes power from the battery even when it's in motion. The difference is it's not all the time. When you rev your car higher, ultimately you're generating more power than you use hence charges the battery with the surplus energy.
We can go around debating. If battery is only use to start an engine, we can just buy a 12 volt small battery to start the car.
IlDivinCodino
post Feb 9 2011, 03:08 PM
Personally do not believe in Pivot products (except for Raizin Spark). Go for either Guangdao or Hot Inazma. You'd be surprised at the vast difference in performance that they can provide you as compared to Pivot's VS.
the_catacombs
post Feb 9 2011, 04:32 PM
8 stars wooo....
QUOTE(Vervain @ Feb 1 2011, 09:56 PM)
cannot la... if use small 12v battery, the ampere is small... it wont be sufficient to crank the starter...
amad108
post Mar 8 2011, 10:59 AM
QUOTE(the_catacombs @ Feb 9 2011, 04:32 PM)
+1.. my car cannot start even using jumper cable from myvi.. even recharge for 30min no use.. then my friend try put the battery directly (which need to hold up-side down) then can start..
the cranking power for each engine r different, that's why there's a lot of type of battery with different cranking power..
ReaLsHot
post Mar 15 2011, 09:27 AM
SUSkyheng
post Mar 15 2011, 09:56 AM
http://www.knukonceptz.com/index.cfm
Buy from here, cheaper and good quality cables....
Best of all, weak USD....
bladekiller
post Dec 27 2011, 08:53 PM
sry for bumping old topic (been using the search function).
is it advisable to put a VS in the car?
looking at their arguments, i would say its more towards 'against VS'.
however, looking at forumer selling VS, customers' feedbacks are positive....quite confusing @.@
vr2turbo
post Dec 28 2011, 08:17 AM
Depends on what you want out of the VS. I was like you before, thinking whether to fit one or not?
Well, I went ahead and the only good thing about them is I got a slightly better less flickering lights and a better sounding audio that all..... blush.gif
bladekiller
post Dec 28 2011, 09:17 AM
actually for my car (also ur car), i dont really notice the flickering lights & bad audio quality though....
mind if i ask which VS did u purchase?
Cos I'm undecided on some home-made VS: eric(100,000uF) for 160, or some malay dude (180,000uF) for 250.
The malay dude 1 looks more economical
vr2turbo
post Dec 28 2011, 11:03 AM
QUOTE(bladekiller @ Dec 28 2011, 09:17 AM)
If the car is fair new, you won't get the flickering problem. Older cars with older wiring are more prone to it.
As for the audio, after fitting the bass is more solid and tweeter also clearer, but there is one VS that is dedicated to audio set up and that is the Pivot Raizin Black. I have fitted the Pivot Raizin Blue that is attached to the battery. That time bought at RM150....
Wilson13B
post Dec 28 2011, 12:39 PM
Especially when the grounding is grounded directly to the cylinder head to each spark plugs/ignition coil wink.gif
vr2turbo
post Dec 28 2011, 03:05 PM
Grounding for older car will be good. Newer cars like no effect as the wires still new..... biggrin.gif
Vervain
post Dec 28 2011, 06:34 PM
Scathach
I also thought vs is a joke till I try one. Turns out if your battery is bad or aged, it can help. But If have a good battery it shouldn't have much performance on the engine. Hehe
vr2turbo
post Dec 28 2011, 07:32 PM
Wilson13B
post Dec 28 2011, 08:55 PM
QUOTE(vr2turbo @ Dec 28 2011, 03:05 PM)
Nope,normally car leave the factory with either 1 or 2 grounding cable to the car body and engine block....usually this wire are thin in size and aren't efficient enough to flow electricity when full load,if u don't believe it u can measure using a electronic amp meter wink.gif
By using heavy gauge cable,the electricity flows better hence bigger spark are produced at the spark plug so more power can be produced.....
Grounding cable are cheap,there is no reason to go buy those HKS Grounding Cable which are freaking expensive and many imitation out there now,use AMP Power cable that measure around 6-4AWG and connect from negative side of battery to different point of chasis and engine,this option is much cheaper but require DIY wink.gif
vr2turbo
post Dec 28 2011, 09:05 PM
Nowadays not too sure, because those older days, cars comes with thicker grounding cable. Only nowadays, newer cars comes with thinner grounding cables. These should have been calculated by the Car manufacturer already.....
Wilson13B
post Dec 30 2011, 02:08 AM
QUOTE(vr2turbo @ Dec 28 2011, 09:05 PM)
Reduce cost ma bang....if Manufacture made everything perfect then all aftermarket tuners like HKS can balik kampung tanam jagung dy tongue.gif
vr2turbo
post Dec 30 2011, 10:02 AM
QUOTE(Wilson13B @ Dec 30 2011, 02:08 AM)
But as you say, grounding cable is cheap, save how much......only short wire from engine to car body...... blush.gif
Naughty_Kidz
post Dec 31 2011, 12:01 AM
QUOTE(bladekiller @ Dec 27 2011, 08:53 PM)
different people will have different view and feel ..
u should buy 1 and install on it and u get the answer ..
honestly .. VS and Grounding cable will more toward electronic device on ur car .. for performance wont have big different or maybe there just slightly ..
but i do install and dismantle for testing .. i do give result in performance ..
my car currently got 3 set of VS and bunch of grounding cable ..
once i dismantle all the stuff bak to stock .. i dint feel lighten throttle on my car . .
vr2turbo
post Dec 31 2011, 08:01 AM
3 sets installed......fuyooh!
dares
post Dec 31 2011, 02:51 PM
QUOTE(vr2turbo @ Dec 30 2011, 10:02 AM)
If proton one car save 50 bucks on grounding cable, one month roll out 4000 cars can save 20,000 bucks. One year save 240,000. Then after 5 years those flimsy cables kong, proton replace can earn even more.
These days cars are not made to last, components lifespan are designed with post warranty replacement profits in mind.
Vervain
post Dec 31 2011, 03:42 PM
Scathach
Mass produce. The cost is actually less than 10 ringgit.
Wilson13B
post Jan 1 2012, 04:39 AM
Pls rmb our government is Ah Jib,and P2/Proton are Malaysian car,what can save also save til max wink.gif tongue.gif
Plus if the grounding cost 50bucks,when you buy the car,u may get charge another 500 bucks ..... wink.gif
poad
post Jan 1 2012, 04:48 AM
QUOTE(Wilson13B @ Jan 1 2012, 04:39 AM)
500/50 = 10...
10 times..haha rclxms.gif i think i smart in calculation..haha
Naughty_Kidz
post Jan 1 2012, 05:26 AM
QUOTE(vr2turbo @ Dec 31 2011, 08:01 AM)
1 set pivot mega raizin, 1 pivot v-capa , and 1 hot inazma eco = )
hahaha
Wilson13B
post Jan 1 2012, 02:38 PM
QUOTE(Naughty_Kidz @ Jan 1 2012, 05:26 AM)
hahaha
Naughty_Kidz
post Jan 1 2012, 03:52 PM
QUOTE(Wilson13B @ Jan 1 2012, 02:38 PM)
i dint do dyno so i dont know how much it was increase .. but actually electronic device wont increase HP so much ..if electronic device can increase so much .. in market no more turbo and supercharge..liao .. biggrin.gif
it slightly will have better response for ur throttle .. fast pickup..can rev more longer to higher rpm without changing gear, what i mean is while u put it in "D" mode .. not in manual mode .. hehe . .
vr2turbo
post Jan 1 2012, 09:05 PM
I know that, been there. Bought Wira, must take with alloy rims, was charged RM1400. Then when collect car go tyre shop to upgrade, was offered RM400 only.... mad.gif
aeridest
post Feb 7 2012, 08:53 PM
What a hot discussion here. by the way.. i'll buy ground cable or Voltage Stabilizer ( VS ) soon.
my ride is honda civic 1.6 SOCH 16years old car. and i'm testing it with cheap multimeter plug in to cigarette 12V lighter.
Ok, here's my problem with my car rite now.
1. when i turned on engine voltage reading is 13.8V
2. then turned wiper + aircond - 13.4 - 13.8
3. then turned headlight - 12.7 - 12.9 << when dis happen, my KM/H meter will go up and down.
4. turn headlight off - meter show correct reading.
it is differ from my friend's wira where when he turned on headlight, aircond, the reading is 13.7V - 13.9V .
so then i came to this thread : http://honda-tech.com/showthread.php?t=3017214&page=2
just wanna do experiment, i'l buy the new grounding cable or VS and i'll show u the result from my multimeter.
soulfly
post Mar 28 2012, 09:31 PM
revving towards 10,000 rpm
VIP
Just want to tell you guys, PIVOT has always been making gimmicky gadgets since back then. If we were to check its product line-up, all they make are just gadgets, no real performance upgrade products. No serious tuner would use a PIVOT product.
Buying an imitation one only comes to reliability. But that's it.
QUOTE(aeridest @ Feb 7 2012, 08:53 PM)
Need to check your alternator. Probably it's not operating at its full capacity already.
This post has been edited by soulfly: Mar 28 2012, 09:33 PM
adrian_huen
post Jan 21 2013, 12:36 PM
Backup & DR solution
wanna ask...my mega raizin...on 1st time i start engine it show measurement..but 2nd time onward...it does not show any more...
FYI i didnt use any remote start....
0.0590sec    0.83    6 queries    GZIP Disabled
Time is now: 23rd December 2025 - 05:01 AM
