Forum Announcement
Please post GE14 related topics in the following new section ► https://forum.lowyat.net/MalaysiaVotes2018
Bump TopicReply to this topicRSS feed Start new topic Start Poll
> TP-Link TD-W8901G, Couldn't connect via wireless
peas6590
post Nov 11 2009, 02:24 PM, updated 8y ago
Group: Junior Member
Hello all, i have question regarding how to setup my wireless connection. I am currently subscribing streamyx and using TP-Link TD-W8901G to connect to the net. But i cant connect to the net by wireless, need to use the Lan cabel. I've restarted the router a few times but still not able to connect to the net.. How to solve this problem? thanks..
Solution [thanks to tvcat] ;
Reset router to factory setting,
log in router >> interface setup >> internet
VPI = 0
VCI = 35
ISP = PPP0A/PPPoE
username = username@streamyx
password = streamyxpassword
encapsulation = PPPoE LLC
bridge interface = deactivated
connection = always on
get ip address = dynamic
This post has been edited by peas6590: Apr 25 2010, 11:52 AM
Punish
post Nov 11 2009, 11:08 PM
Group: Senior Member
check ur security WEP/WPA password.....
GTG
pang5_kiro
post Nov 12 2009, 10:59 AM
:useless person is useless:
r u already enable wireless signal??? some wireless router hav a function to disable the wireless signal..
tvcat
post Nov 12 2009, 11:03 AM
Mr. Dumb Dumb
open command prompt
type "ipconfig /all"
post the result here
pang5_kiro
post Nov 12 2009, 11:27 AM
QUOTE(peas6590 @ Nov 11 2009, 02:24 PM)
can u browse to that router to do a setting on it??
peas6590
post Nov 14 2009, 03:46 PM
QUOTE(Punish @ Nov 11 2009, 11:08 PM)
GTG
Ive check and reset the router, no password is set.
QUOTE(pang5_kiro @ Nov 12 2009, 10:59 AM)
Im sorry, but how to know whether I've enable wireless signal?
QUOTE(tvcat @ Nov 12 2009, 11:03 AM)
open command prompt
A- ipconfig from wireless connection
B- ipconfig from streamyx normal cabel connection
QUOTE(pang5_kiro @ Nov 12 2009, 11:27 AM)
Yes I can browse them from 192.168.1.1 but when trying to go online I cant surf the net.
This post has been edited by peas6590: Nov 14 2009, 04:04 PM
tvcat
post Nov 14 2009, 09:38 PM
Mr. Dumb Dumb
are you using windows dial up to log in to the streamyx??
if yes then delete the windows dial up and set the streamyx account info in the router.
peas6590
post Nov 15 2009, 02:16 AM
QUOTE(tvcat @ Nov 14 2009, 09:38 PM)
Yes, im dialing to connect... Just now i've just set up streamyx acc info in the router but still cant get connected..
I checked the diagnostic and find this
tvcat
post Nov 15 2009, 09:41 AM
Mr. Dumb Dumb
log in router
VPI = 0
VCI = 35
ISP = PPP0A/PPPoE
username = yourstreamyxusername@streamyx
password = yourstreamyxpassword
click save
after save setting restart the router......
This post has been edited by tvcat: Nov 15 2009, 09:44 AM
peas6590
post Nov 15 2009, 07:33 PM
I've tried those settings but this error message appear,
Can you re-check my settings , am i doing this rite,
sorry to trouble you..
This post has been edited by peas6590: Nov 15 2009, 07:35 PM
tvcat
post Nov 15 2009, 07:51 PM
Mr. Dumb Dumb
the setting is ok.....
try reset the router and reconfig....
peas6590
post Nov 15 2009, 07:59 PM
but, with the above setting i cant save the setup, and the error message will appear.
"FAIL TO UPDATE DUE TO... Duplicate to a VPI/VCI ! "
Previously i've restarted and reset the router for few times to ensure its reset to factory default, but still same error message appear..
tvcat
post Nov 15 2009, 09:14 PM
Mr. Dumb Dumb
try select the other pvc for the "virtual circuit" like pvc1
is the value of the vpi and vci change when you select a different value for "virtual circuit"?
if yes then try to change the "virtual circuit" value until the vpi = 0 and vci = 35
then try to save.
This post has been edited by tvcat: Nov 15 2009, 09:17 PM
peas6590
post Nov 16 2009, 11:26 PM
QUOTE(tvcat @ Nov 15 2009, 09:14 PM)
then try to save.
Hello, after trying restarting again n again i've managed to connect via wifi by the setup u've given. Thanks! smile.gif
After reset the router to factory default, i set the setting according to what u've given, if any problem occur again i'll ask here, thanks!
fuzzly!
post Nov 21 2009, 02:43 PM
llbllbll
post Jan 7 2010, 02:46 PM
Group: Newbie
Guys,
I've discovered sth extraordinary with this particular router. I have the streamyx combo RM60 (384kbps line), normal download speed is around 40~45kbps, from Rapidshare, Hotfiles, or other torrent download. But with this router (for about 2 weeks), my download speed has shot up to 150~200kbps. I've not upgraded my line, nor any changes in the hardware, the only thing new is the router. I try to use my old Aztech modem, speed is ~40kbps. A d-Link router also gives me ~40. I restart my PC many times, and switch with other router, it is ~40 40kbps.
The magic happens when TP Link TD-W8901G is plugged in, I get 150-200kbps. My bad, I reset the router to factory settings 2 days ago, then everything is back to normal.
Do you have any clues?
peas6590
post Jan 30 2010, 03:28 AM
Ohh, what a waste you should have shared the settings here!
//Back on topic, were the router have any relation to the speed? I don't know much about this.. But if it does, thats good! maybe i can accelerate my connection speed. But as far as i used this router i think the speed have not much different from the prev one. so i assume that it have no different just that it has wifi.
donnie.dgr
post Jan 31 2010, 08:32 PM
i think it should something to do with the router but mostly it depends on the plan and the sever.
scirocco
post Mar 7 2010, 11:41 AM
just to check, can you actually disable wireless with this router?
anyone who owns the TD-W8901G can confirm?
adachi7
post Mar 7 2010, 07:02 PM
Uh... yeah, you can disable wireless LAN.
I was wrestling with the modem/router just now as I couldn't get it to connect to streamyx (didn't know VPI and VCI). So I just used it as a modem and connected it to my old wireless router to connect to streamyx. At that time I had the wireless LAN off for the W8901G.
ryudox
post Mar 12 2010, 10:10 PM
~~ ConVict ~~
i have been struggled to setup this router for the whole 2 days! TM service center also cant help me at all...i can connect to streamyx but didn't managed to browse any website.. finally found his thread and i noticed the VPI and VCI thing...damn the manual only mentions to put the value regarding your ISP...what the.......... now i'm using the old modem,and trying to set up the modem router again...wish me luck..
mi-g
post Apr 17 2010, 07:47 PM
Part-time Troll
i use tplink w8901g...this info is really good.. it helps me setting my modem thumbup.gif
donnie.dgr
post Apr 18 2010, 12:28 AM
VPI and VCI is 0 and 35, for Streamyx
bakunfc
post Apr 19 2010, 10:57 AM
VPI/VCI in PVC this tplink cannot change.... 0/35 is in PVC 2 by default...
PVC 2 = 0/35 it can't be change
renzolution
post Apr 20 2010, 10:05 PM
QUOTE(tvcat @ Nov 15 2009, 10:41 AM)
log in router
VPI = 0
VCI = 35
ISP = PPP0A/PPPoE
click save
is this to change from manual to auto connection right?
my problem just like peas prob's
i cant access to the internet through its wireless
but for fired,it is can
the thing is..
when i connect through from my wireless laptop
it said it is connected, but there is no internet access
i try to find the solution
still cant find 1
huhu
peas6590
post Apr 24 2010, 08:17 PM
QUOTE(bakunfc @ Apr 19 2010, 10:57 AM)
Yeah, this happened to me before, as the solution i reset it to factory setting then try to change the value. Im pretty sure that will works.
QUOTE(renzolution @ Apr 20 2010, 10:05 PM)
the thing is..
still cant find 1
huhu
i think what you can do is resetting the router to factory setting, which can be done by soft or hard reset. Then login to the router to apply the setting provided in previous page. As in my case, that is what i done to get my wireless function work, and it is still doing great until today! smile.gif
This post has been edited by peas6590: Apr 24 2010, 08:24 PM
renzolution
post Apr 26 2010, 05:09 PM
so i just have to press the reset buton n exerything wil be alrite?
Idzm
post Apr 27 2010, 08:50 AM
the thing is..
still cant find 1
huhu
I think if you change the DNS setting at ur laptop should be fine. change it to:
202.188.0.133
202.188.1.5
renzolution
post Apr 28 2010, 03:32 PM
huhu
just now i can connect through its wireless,
thanks everyone, espclly peas
great job guys
Added on May 5, 2010, 3:06 pm@ peas
could you paste the setting for the PVC 2 = 0/35 setting for:
-internet
-LAN
-wireless
this is because, sumtime, the internet is hang for15 sec, then it connect back.
it hapen repeatedly...
This post has been edited by renzolution: May 5 2010, 03:06 PM
brandonyim
post May 11 2010, 10:08 PM
Hi,
I'm using this model as well. I bought it about 2 months ago, its very good from day 1 but it gives me headache lately, it disconnect the internet suddenly after using sometime, when I changed to another modem, its able to connect to the internet, so it means the problem is not from Streamyx.
I guess the router is too "tired" cause when I let it rest for few hours, it able to connect again. Does anyone here experience this kind of problem?
This post has been edited by brandonyim: May 15 2010, 12:55 PM
wanakev2
post Jun 6 2010, 09:17 PM
hi there, i had a little different problem...
recently, my neighbor accidentally change the isp login and passwd in the router. then, after i changed it back, i cannot access to the internet. i follow all the instruction given in this thread i.e reset then configure vpi, vci, and all things... but, still no signal for the internet.. someone help me pls..
tashfinsheikh
post Jun 6 2010, 09:38 PM
Maxis Dealer
QUOTE(wanakev2 @ Jun 6 2010, 09:17 PM)
and 1 thing that I always do in the place where you can input your Streamyx user name type :
yourusername@streamyx usually I type myusername@streamyx.com
This post has been edited by tashfinsheikh: Jun 6 2010, 09:39 PM
Humphrey
post Jun 6 2010, 11:01 PM
QUOTE(brandonyim @ May 11 2010, 10:08 PM)
Hi,
does this disconnect happened again after let the router rest for few hours?
wanakev2
post Jun 6 2010, 11:32 PM
QUOTE(tashfinsheikh @ Jun 6 2010, 09:38 PM)
i had try it already.. still dont work.. all the id n pswd are correct..
xMika
post Jun 9 2010, 09:13 PM
我爱中島美嘉
Why so hard to setup this modem router ? I dont need to do any settings .. just use the resource cd i got in the package .. follow and fill in the blanks .. 5 minutes gao dim sad.gif
A2Z2U
post Jul 14 2010, 05:41 AM
QUOTE(renzolution @ Apr 28 2010, 03:32 PM)
huhu
great job guys
-internet
-LAN
-wireless
Just bought this model. I've the same problem. Sometimes it'll hang for a while, after that normal. It happens very frequently when I open utorrent. It's not slow connection problem, but cannot connect at all.
brandonyim
post Jul 14 2010, 10:00 AM
QUOTE(A2Z2U @ Jul 14 2010, 05:41 AM)
So far I'm happy with this modem, it have strong signal and cheap price.
Humphrey
post Jul 14 2010, 11:35 AM
my friend also use this modem, good quality, and good price.
MrWorldWarrior
post Jul 14 2010, 12:26 PM
reset your router and set it again..........
A2Z2U
post Jul 14 2010, 02:55 PM
QUOTE(MrWorldWarrior @ Jul 14 2010, 12:26 PM)
Already reset a few time. It'll start to disconnect when I open torrent. Maybe this router cannot handle heavy torrent. The download speed from torrent also considerably slower than my old trusty Levelone FBR 1461.
I plan to buy another modem router. Any good recommendation from u guy?
This post has been edited by A2Z2U: Jul 14 2010, 02:58 PM
Humphrey
post Jul 14 2010, 10:14 PM
maybe the the problem is your ADSL line, check with streamyx.
A2Z2U
post Jul 14 2010, 10:27 PM
QUOTE(Humphrey @ Jul 14 2010, 10:14 PM)
Not likely. Now I switch back to my old Levelone modem router. I get full speed for torrent and no disconnection problem.
I'll use this TP-Link router as my backup. If u guys have good recommendation for stable and reliable modem router for torrent, please let me know.
Thank you.
Humphrey
post Jul 15 2010, 12:02 AM
try the function of Qos which TD-W8901G has
A2Z2U
post Jul 15 2010, 11:47 PM
I've tried to limit my torrent download speed. The problem will start when utorrent is running. The webpage will not load but torrent is downloading as normal. I haven't played around with the QoS. Will try when I'm in good mood.
Thanks for your advice
mazdagtr210
post Jul 20 2010, 11:40 PM
how to set ddns function td-w8901g.. always take to router web control not my camera
cless85
post Aug 8 2010, 10:46 AM
Hey guys, when u all turn on torrent,
do you feel that the internet is totally inaccessible
and the torrent speed is slow even after portforwarding?
scorps
post Aug 8 2010, 02:09 PM
Something you call love, but I call sex
QUOTE(cless85 @ Aug 8 2010, 11:46 AM)
if the download speed at full , yes, your internet connection will slow, and sometimes not accessible
donnie.dgr
post Aug 9 2010, 10:24 AM
Using TP-LINK N modem router for half year on, so stable with high speed dowload.
Added on August 9, 2010, 10:38 amMy friend just had this headach for D-LINK and choose TP-LINK. He said so far it had no this issue.
QUOTE(cless85 @ Aug 8 2010, 10:46 AM)
This post has been edited by donnie.dgr: Aug 9 2010, 10:38 AM
ip01022
post Aug 9 2010, 12:20 PM
Im using this modem as well and i hv diff problem here.
this modem served me well and very stable for few mths until 1 day...
I can't login to web console page due to ping failed at 192.168.1.1, but i can see my default gateway ip and my local host ip is 192.168.1.2. can anyone tell me wats the problem? yes i did reset modem few times already it doesn't help at all...
it tat any possibility of modem hardware failure??
scorps
post Aug 9 2010, 03:54 PM
QUOTE(ip01022 @ Aug 9 2010, 01:20 PM)
u can't login to web console page of modem but still can connect to internet?
lightning strike ?
ip01022
post Aug 9 2010, 08:01 PM
QUOTE(scorps @ Aug 9 2010, 03:54 PM)
lightning strike ?
can't access to internet at tat moment tats why i need to login to web console to find out wat was going wrong.
both cable and wireless connection failed to ping 192.168.1.1, any idea?
donnie.dgr
post Aug 9 2010, 10:29 PM
modul problem. I think you got lightnight strike please call for warranty, TP-LINK said it had 2 year warranty with lightnight strike.
scorps
post Aug 10 2010, 12:26 AM
QUOTE(ip01022 @ Aug 9 2010, 09:01 PM)
try with another cable
or u can try to check the ip address again,
set the automatic ip at tcp/ip section.
open command prompt, type ipconfig
see what ip address and gateway number that appear
try to login to your modem with that gateway number.
ip01022
post Aug 10 2010, 12:08 PM
QUOTE(scorps @ Aug 10 2010, 12:26 AM)
problem solved!
reset modem to factory defaults and reconfigure everything again, network connections (internet access) back to normal.
narutomax
post Aug 30 2010, 06:16 AM
i'm using this model right now..
i think tp-link router have problem with wireless connection..
why i get really slow connection in wireless connection..???
when using cable,speed is normal for my package of streamyx.
anybody here can suggest or have tips to make the wireless connection of tp-link become great?? =(
now i'm using Telekom modem which is really good in wireless and cable connection..
donnie.dgr
post Sep 1 2010, 05:14 PM
Strange, i am using TP-LINK Modem, the signel is full even i go downstair i also can get 4 or 5 bar signel!
My old TMNET one and new D-LINk one cannot compare.
Denny721
post Sep 1 2010, 05:29 PM
QUOTE(donnie.dgr @ Sep 1 2010, 05:14 PM)
Hey bro, my TP-LINK modem work well, too. I put TL-8901G in the 1st floor, and use 722NC with my PC in the second floor, the signal is full.
xyber9
post Oct 4 2010, 12:23 AM
I think you should set your ADSL type to "g-lite"
What is your adsl type setting?
kuchikuchi
post Oct 7 2010, 05:30 PM
TP-Link is better than D-Link, I have seen it, just ppl still believe in branding rather the actual performance.
adihassan
post Oct 8 2010, 04:22 PM
Thanks for this thread! The VCI info helped me in solving the problem to connect to Streamyx!
Thanks so much for the info
coolstore
post Oct 10 2010, 11:24 AM
QUOTE(donnie.dgr @ Aug 9 2010, 10:29 PM)
lightning strike covered by warranty? i don't think so. what the label on the box said is got better protection against lightning strike...not cover it by warranty
leyley
post Oct 11 2010, 01:26 PM
It is consider under conditions that void this warranty
jerm57
post Nov 1 2010, 09:55 PM
I've recently bought the TD-W8901G modem/router and apparently managed to set it up according to the instructions in the earlier posts. But lately, I've been having some connectivity problems. Whenever I start up and P2P sharing (BitTorrent and WoW patch DL) or stream any videos, all data transfer screeches to a halt after a while. I am only able to surf regularly after a soft reboot on the router. It stops up again whenever I reopen BitTorrent or the WoW patch DL. I have been doing some pretty hardcore downloading for the past few days (with no problems) and I'm wondering if there's a DL limit with Streamyx?
As far as I could tell, there doesn't seem to be anything wrong with my settings but I could be wrong. Right now, there's a LAN (cable) connection to another computer and a wireless one to my computer. I get most of my problem when both computers are on and I figure it could be an IP conflict. I tried the method suggested in the manual but it doesn't seem to help. Any ideas?
donnie.dgr
post Nov 2 2010, 05:23 PM
IP conflict??
Are you using computer dail up or modem router dail up?Make sure you put the streamyx user name and password into modem. The VIP and VCI is 0 and 35.
jerm57
post Nov 2 2010, 07:02 PM
Done and done. Does the computer using the cable connection hog up more bandwidth than wireless connected computers? The streamyx username and PW are set up on the modem. Whenever my dad boots up his comp (cable connection) I get serious lag/latency and sometimes disconnection. And he's not even surfing yet.
ainursya
post Dec 12 2010, 08:09 PM
Hi to sifus here..
i just bought this modem.. i have the same problem..cant connect to the internet via web based setup.. the internet light didnt up.. then i tried bridge mode it connected..but when i changed back to pppoe it not connected.. luckily i was able to make it connected using pppoe through the CD given.. but problem is now the time it dials to the internet takes about 3-4 minutes how to speed it up.? im really fed up with it...better using the tmnet one..
kaizer_x
post Jan 4 2011, 11:04 PM
having the same problem here..the speed is too slow
jason991
post Jan 9 2011, 10:18 AM
is all about the money, money, money
hi guys....i hav 2 problems wif this modem....first is stated above which i cant load page after i open p2p program...for my case is xun lei....second is i cant save the setting at the virtual server....it take no effect when i click save after i browse to another section and browse it didn't save....
operation886
post Mar 3 2011, 06:50 AM
Group: Newbie
hi all
anyone can help me with how to connect mannually use this modem?
steps i already did?
1) choose manually connect in http://192.168.1.1
but only 1 laptop (connect using cable) can connected to internet
while my other laptop can connect but cant browse..
2) i chose always on ..both my laptops can connect n browse.. but , my focus is
i want to connect each of them manually..
hope all of u can help me..
darkcurves
post Mar 23 2011, 06:28 PM
If i off the modem and turn it on, it takes so long to connect to streamyx even though status shows UP. Sigh, should have just paid extra and got Aztech.
king_kenny
post Mar 27 2011, 01:25 AM
i got 2 unit of this router modem.
i just want to know, how to
bridge both of this router wirelessly.
1 unit as a main one,connected to internet
2nd unit connect to the 1st unit wirelessly.
darkcurves
post Mar 27 2011, 02:22 AM
I dont think can do it wireless bridging with this model. I use lan cable.
todak
post Jun 18 2011, 10:46 PM
Just in case anyone is reading this to setup this modem.
then choose PVC2 from the drop down menu before filling in your info.
This post has been edited by todak: Jun 18 2011, 10:48 PM
oland
post Jun 19 2011, 03:55 PM
Group: Newbie
Hi Gurus...
I'm also encountering problems with this router(no sure whether is the router or OS). When i was using XP previously, i can easily ping my router. I've migrated to windows 7 now and i couldn't ping my router even i've set manually the TCP/IPv4 properties(IP add, subnet and gateway). I haven't tried to restore my router back to factory settings. See anyone of you encountered the same problem as mine. My wireless conection is working fine.
brandonyim
post Jun 21 2011, 06:39 PM
Hi, currently I'm using this modem router, plan to buy another wireless modem to do bridging with this modem router, is it possible?
ColourShadow
post Jul 5 2011, 10:23 AM
this modem is good, very strong signal & very stable...
carmelo
post Jul 5 2011, 10:32 PM
I got a problem with this modem.When it run with the CD. It stuck at verify account setting. And when I login to 192.168.1.1 and finish setup. It can't work. I could not use either lan or wireless network. Anyone could help me? Thank you
birain
post Oct 16 2011, 05:07 AM
良い一日を
currently using TP-Link TD-W8901G version 6. so far,so good.
Shizuru
post Jan 12 2012, 08:26 PM
This thread save my life! laugh.gif Mess up my setting just now. Did a search on Google on how to fixed it. Found this link. Followed everything and it work! thanks TS for starting the thread and to those who offered solutions. Ever so grateful notworthy.gif
soundsyst64
post Apr 18 2012, 09:52 AM
I'm No-Longer-Noobs
I was messing around for more than hour just to get the unit working sweat.gif
DavidT
post May 8 2012, 10:58 AM
Thanks for the guides. I helps me to solve my internet connection
for Streamyx. And also thanks to you all, for solving the problems.
javascript:emoticon(':respect:') Oh! By the way, I am using XP and
my notebook is Window 7.
Thank you very much to all concern. javascript:emoticon(':idea:')
miellennium
post May 12 2012, 12:37 AM
all the setting provide here are correct... but then at first i did it, i still didn't manage to get internet access... so just want to share..after that i go to 'maintainance', and then 'diagnostic' virtual circuit i choose 'PVC2' ... and then i click the 'Tracert' button ... and suddenly my 'Internet' LED at the router start to light up.... wallahhhhh~ feel relief... thanks all~!!!
Mr.HaZaRD
post May 18 2012, 12:45 PM
QUOTE(jason991 @ Jan 9 2011, 10:18 AM)
i also have the same problem..
better use the router the one that TM give us if it is like this..
peter32
post Jan 17 2013, 05:14 PM
心旷神怡
Gotta admit I find this router a bit unusual, being a layman of course.
I still can't port forward this router properly. Not sure whats wrong with it. It was about many months ago and I think I just give up for the time being.
Anyone has done port forwarding with this device, I really appreciate if they can share the experience.
Cheers.
pandahead
post Feb 24 2013, 12:22 PM
hi guys..any idea that the router will auto change from auto dialer to bridge mode everytime i restart the modem?? just wondering how come when i login to 192.168.1.1 will see the bridge mode on..= = thx
everytime i done setup...can connect to internet..PVC2 - 0, 35 Pic1
after i restart the modem ..it will auto jump to the default setting (bridge mode) PVC 0 - 0, 32...pic2
This post has been edited by pandahead: Feb 24 2013, 12:57 PM
Attached Image Attached Image
rootlinux
post Feb 24 2013, 01:03 PM
QUOTE(pandahead @ Feb 24 2013, 12:22 PM)
Looks like u need to make PVC2 as default or try modify PVC0 to 0, 35
pandahead
post Feb 24 2013, 01:23 PM
QUOTE(rootlinux @ Feb 24 2013, 01:03 PM)
coz its auto default ..when i choose pvc2 it go to 0,35....how to make it pvc0 and 0,35?
The Newbie
post Jul 15 2014, 04:04 PM
Group: Newbie
[quote=tvcat,Nov 15 2009, 09:41 AM]
log in router
VPI = 0
VCI = 35
ISP = PPP0A/PPPoE
click save
[QUOTE]
my problem maybe same with peas,i cant connect to my wifi modem TD W8901G...the light for wlan at the modem not lit up...so i cant connect to my wifi.
How to make it works again...
Please help me...
mon678
post Sep 9 2015, 03:34 PM
i have problem with this modem...its recently hang and the adsl has no light...so i can only on off the modem and its return to normal? is it hardware failure? or need to update firmware?
Bump TopicReply to this topicTopic OptionsStart new topic
Switch to:
0.2024sec    2.80    6 queries    GZIP Disabled
Time is now: 22nd April 2018 - 01:21 AM
