 Engine flush, come n share your DIY engine flush....
TScrazeeclan
post May 26 2009, 11:14 AM, updated 17y ago
Hi guys...i believe you all will do engine flush whenever you all service your car (changing engine oil). I have a fren..he say he dun trust those engine flush oil...what he do is keep the balance engine oil everytime he service his car...once he have around 2 liter plus...he mix with petrol....roughly about 70% engine oil 30% petrol...then
1) he drain out all those oil engine oil without replacing the oil filter yet...
2) screw back the oil sump nut
3) he pour in back the mixture of petrol and engine oil
4) start the engine without revving it for about 5mins to 10mins
5) off the engine...
6) drain out all those oil again
7) change the oil filter
8) pour in fresh new suitable engine oil
result : after he flush out the engine oil that mid with petrol...the engine oil really become thick...it thicker than the engine oil that stay inside his engine for 5000km .....means it really bring out all those carbon stuck at the wall of the engine...
so my question is .....will this method harm the internal parts of the engine ? such as those oil seal? gasket...or whatever part you all think offf?
Ultima
post May 26 2009, 11:38 AM
KiRiSuTe GoMeN
the petrol itself easily to vaporize, n strong chemical.. wont it harm the internal engine?
the_catacombs
post May 26 2009, 12:24 PM
8 stars wooo....
i dun flush my engine... i do regular changes every 5000km...
TScrazeeclan
post May 26 2009, 02:17 PM
i also do change my engine oil every 5000km...im using semi synthetic oil that require me to change every 7000km...but if really can flush out the carbon , then that is good....
amduser
post May 26 2009, 11:06 PM
very high cost, need half bottle of engine oil and then the petrol...
and you sure that is carbon and not something else?
TScrazeeclan
post May 27 2009, 12:11 AM
yeah...sure is carbon...if not wut else wor? coz after mixing the petrol into the engine oil...the engine oil seem to be thinner...but after 10mins run....when drain out...the engine oil is thick n black....
the_catacombs
post May 27 2009, 01:48 AM
8 stars wooo....
QUOTE(crazeeclan @ May 27 2009, 12:11 AM)
that is not called carbon i presume... carbon only exists in combustion chamber... not ur engine oil sump... mayb its some metal residue due to metal-to-metal shaving...
Esky
post May 27 2009, 08:17 AM
The thick, black stuff is probably mostly sludge?
Another way of flushing is to use a cheap mineral oil as the flushing oil for maybe 10~15 mins, after draining out the used engine oil. Then drain again, change the oil filter and fill up with the engine oil of yr choice.
U can also shorten the oil-change interval to maybe 2k km or so as a flushing job, then change oil again and follow the usual oil-change interval.
huakenny
post May 27 2009, 12:40 PM
From: KK ,MUAR, SELANGOR, KL, KUDAT, PUTATAN, SERDANG
some service centres(not to mention which)...use diesel to flush...very clean
or use a thinner grade cheapo engine oil to flush
the_catacombs
post May 27 2009, 02:53 PM
8 stars wooo....
QUOTE(huakenny @ May 27 2009, 12:40 PM)
Added on May 27, 2009, 2:55 pmtell u guys how... normally our engine only takes in about 3.5L of engine oil each service interval... the remaining 0.5L u keep it in a bottle... after about 7 oil changes, u'll have 3.5L of extra'ed engine oil available for flushing...
This post has been edited by the_catacombs: May 27 2009, 02:55 PM
Ultima
post May 27 2009, 09:33 PM
KiRiSuTe GoMeN
but make sure u keep the remaining engine oil sealed or not exposed to air...
the_catacombs
post May 27 2009, 09:38 PM
8 stars wooo....
QUOTE(Ultima @ May 27 2009, 09:33 PM)
lolz... of course...
cheeann
post May 27 2009, 09:39 PM
I love my suggie~
QUOTE(Ultima @ May 27 2009, 10:33 PM)
Esky
post May 28 2009, 08:12 AM
Some people just use diesel engine oil that's also rated for petrol engines, as diesel lubes usually contain more detergents compared to petrol engine lubes. Examples include Caltex Delo 400 15W-40, Mobil Delvac MX.
TScrazeeclan
post May 28 2009, 09:53 AM
so the conclusion is not advisable to mix petrol and engine oil together to flush our car engine?
FerrariST
post May 28 2009, 10:23 AM
Just buy a can of Engine flush, instead of leaving the car idle for 15min, shorten the time to 10min, this product is corrosive, so you do not want to leave it for to long, once after that every 20k - 50k oil change use 1 can of engine flush will do.
you don't have to use it regularly.
toye
post May 28 2009, 11:29 AM
try auto-rx
Conroe
post May 28 2009, 08:44 PM
QUOTE(toye @ May 28 2009, 11:29 AM)
try auto-rx
Where to get it in Malaysia?Price?
Esky
post May 29 2009, 08:02 AM
Don't think auto-rx is easily available here. And I was told it takes like 10k km to work properly.
I think the STP Engine Flush states on its label that it's not corrosive. Donno whether this holds true for engine flush from other brands though.
feralee
post May 29 2009, 01:34 PM
Enthusiastic (R)(C)(tm)
2 Pages  1 2 >Top
0.0158sec    0.62    5 queries    GZIP Disabled
Time is now: 20th December 2025 - 04:53 PM
