 DIY Fan controller thread-share your cuztom one, pls post with schematic if complicated
TShiroki04030
post Apr 20 2009, 09:51 PM, updated 17y ago
Retired Member
based on my experience
first is the easiest. 12V-----variable resistor (VR)-----fan (changes the voltage according to the current of the fan
second 12V---VR---ground (Change the voltage not affected by fan)
(middle connection of VR connect to fan)
third is improved version of second 12V-------resistor(same with max of VR)------VR---------ground
forth is using rotatary switch with 5 0.2V drop diode. not recommend it. not mine either.
fifth is using adjustable voltage stabilizer. not recommend to use because it cost more than others.
This post has been edited by hiroki04030: Apr 21 2009, 07:31 PM
SUSProtester
post Apr 21 2009, 06:06 AM
IcEMoCHa
post Apr 21 2009, 10:18 AM
~本田~
TShiroki04030
post Apr 21 2009, 07:26 PM
Retired Member
this thread is to discuss the method to diy fan controller (with own design)
0.0166sec    0.60    5 queries    GZIP Disabled
Time is now: 20th December 2025 - 09:03 AM
