 Lexmark x1270 software problem, please help
TSKyusuke_FD3S
post Mar 22 2009, 03:48 PM, updated 17y ago
Hi every master,
I got a LEXMARK x1270 all in one printer
I install the driver,
the Lexmark 1200 series All in One Center software
first time loading this software, it said it "search for scanning application please wait"
how come i wait so long, the software still stuck in searching ?
do you all wait very long time, when first time running this All in One Center software ?
thanks
ichigo_6091
post Mar 22 2009, 05:48 PM
Renewable energy pls
1.Try download the driver from the website.Lexmark Drivers
2.call Lexmark Malaysia 03-7492 0862
3.) Unplug the USB cable from the back of the PC
2) Ensure there are no print jobs in the que. If there are, remove them.
3) Run the uninstaller included on the CD by right clicking on the second ? in the X1270 series cd popup
4) if you cant find that, click Start\All programs \ Lexmark X1270\ Uninstall
5) wait till its all finished, then click "Exit without rebooting" or something to that effect
6) Click start \ run and type " regedit " without the quote marks
7) Click the plus sign beside HKEY_Local_Machine
8) under that, click the plus sign beside System
9) under that, click the plus sign beside CurrentControlSet
10) under that, click the plus sign beside ENUM
11)under that, click the plus sign beside USB
12) Right click on USB and go to permissions
13) grant Everybody Full Control, then click apply, then OK
14) look for VID_043D_PIDxxxx (where xxx is wild card) and delete them. (right click, delete)
15) Close the regedit and reboot
THE USB CABLE SHOULD STILL BE UNPLUGGED
16)boot back into windows, and remove the Lexmar CD and put it back in (so that we get the auto-run)
17) click install, and the next\next\ next until it says "search results - no printer attached"
18) Plug in the USB
19) Cancel all the Add New Hard Ware windows that come up.
20) return to the Lexmark program and finish the install.
option no.3 is a bit coplicated for you,try step1 and 2 first.
This post has been edited by ichigo_6091: Mar 22 2009, 05:48 PM
driftmeister
post Mar 22 2009, 06:06 PM
Penggadai Rakyat®
it takes quite sometime for me
dipsomania
post Jun 3 2010, 05:53 PM
Hi All,
Lexmark X1270 All-in-one usb printer driver download link (Alternative)
Good Luck
This post has been edited by dipsomania: Jun 3 2010, 05:53 PM
ayse_sila
post Nov 22 2011, 07:43 PM
QUOTE(Kyusuke_FD3S @ Mar 22 2009, 03:48 PM)
Hi every master,
thanks
printerLexmark printer driver sites
lxmrk
post Dec 25 2011, 05:39 PM
Hi,
Click on the link to download the current versions of lexmark x1270 driver.
Good Works.
0.0181sec    0.67    6 queries    GZIP Disabled
Time is now: 14th December 2025 - 12:31 PM
