ADVAN
Sep 16 2008, 04:05 PM
QUOTE(my_voy @ Sep 16 2008, 02:56 PM)
do you guyz think that there's a phone that can beat n82 camera? for example n95,n85,n96 or n78?
For nokia consider the best lo...
my_voy
Sep 16 2008, 06:29 PM
is there any phone better than n82? other than nokia
p/s: in terms of camera
~Battousai~
Sep 16 2008, 09:03 PM
1. Brand: any
2. Budget: hopefully 600-800 but below 1k
3. Specs: at least 2mp camera, can play music
4. Type/Size: as long as its slim
for girl so yea needs to looks good haha
miyakochan89
Sep 16 2008, 10:14 PM
QUOTE(~Battousai~ @ Sep 16 2008, 09:03 PM)
1. Brand: any
Motorola Razr2 series, fashion phones.
~Battousai~
Sep 17 2008, 01:21 AM
QUOTE(miyakochan89 @ Sep 16 2008, 10:14 PM)
its more than 1k le
ADVAN
Sep 17 2008, 01:58 AM
1. Brand: any
Go for SE W890i or W910i...
craxors
Sep 17 2008, 10:34 AM
1. Brand = nokia or SE
2. Budget = below 1k..cheaper is better
3. Type/Size = any
4. Specs:-
most important..
3g + video call
currently looking at these 2..:
3120c
6120c
any others suggestion???
thanks...
ADVAN
Sep 17 2008, 12:07 PM
QUOTE(craxors @ Sep 17 2008, 10:34 AM)
3. Type/Size = any
4. Specs:-
most important..
3g + video call
3120c
6120c
thanks...
Can try Nokia 6500 classic or SE K810i too..
craxors
Sep 17 2008, 12:37 PM
QUOTE(ADVAN @ Sep 17 2008, 12:07 PM)
need an opinion...
is it good to spend 1.2k for s40 nokia phone...any major different with s60??
thanks again..
ADVAN
Sep 17 2008, 01:37 PM
QUOTE(craxors @ Sep 17 2008, 12:37 PM)
need an opinion...
thanks again..
Vr big difference... S40 is normal phone while S60 is a symbian OS phone...
Not really worth to spend 1.2K on S40 phone in my opinion... But it depend on every individual actually...
skyung
Sep 17 2008, 11:08 PM
. Brand. any brand preferable nokia and se
2. Budget. about 600++
3. Specs. camera 3.2 megapixel or above
4. Type/Size. any
ADVAN
Sep 17 2008, 11:30 PM
QUOTE(skyung @ Sep 17 2008, 11:08 PM)
4. Type/Size. any
U can go for SE K810i, K800i and K770i... All at around RM6xx...
kousou
Sep 18 2008, 12:04 AM
go for k800 n k810 only...
k770 is not a gd phone honestly...
cybershot but no zoom function at 3.2 mx and no xenon flash...
not worth the money u paying...
go for k800 or k810 honestly...
skyung
Sep 18 2008, 12:44 AM
kousou..thx a million for ur suggestion man...=D
jolipoli81
Sep 18 2008, 03:04 AM
How do we compare N82 with N95 8gb?
currently im in love with the 8gb, but concerning the budget... i think i have to hold back a little
so, is it worth for me to get the N95 8gb? or rather a N82 with a rice key and without infrared (which is helpful for a irremote!!!)
popoliee
Sep 18 2008, 01:37 PM
any idea about w960i..??? any opinion about tis phone..
yijzen
Sep 18 2008, 02:15 PM
hey i have a dilemma. which one should i get? e66 or wait for the N85? all i want is a good looking user friendly phone. music quality and camera is not really important as i have an ipod and good cam.
rhyoko_hime
Sep 18 2008, 04:24 PM
Hi~~ I want to get a new phone but not sure what brand to buy
So please recommend some good one okay..
1. Brand: SE or Motorolla
2. Budget: around 1000-1500
3. Specs: at least 3mp camera, support 3G
4. Type/Size: preferably flip, nice design
Thanks~~
Papermate123
Sep 18 2008, 05:02 PM
Motoraola sux
Added on September 18, 2008, 5:07 pm
Cwz90
Sep 18 2008, 05:15 PM
I'm looking for a new phone?
Is Nokia N82 better choice?
Got another phone's function is same like N82?
Any recommend?
Thanks.....
ADVAN
Sep 18 2008, 06:12 PM
QUOTE(Cwz90 @ Sep 18 2008, 05:15 PM)
Any recommend?
Thanks.....
Yup N82 is a good choice.. Beside this, u can go for N95 or N95 8gb as well...
ADVAN
Sep 18 2008, 06:16 PM
QUOTE(rhyoko_hime @ Sep 18 2008, 04:24 PM)
Thanks~~
Then u can go for SE W980i... Price at around 1.5k... Flip design with 3G and 3.2mp camera..
marmee
Sep 18 2008, 07:35 PM
1. Brand: any
2. Budget: around 1500 (plus minus RM200)
3. Specs: at least 3mp camera, support 3G, qwerty, touch screen, wifi
4. Type/Size: slide
the last time, the other phone suitable that i found is P1i..
but there are a lot of p1is going around..
sifus...
ask for ur help again....
thanks
popoliee
Sep 18 2008, 08:05 PM
QUOTE(marmee @ Sep 18 2008, 07:35 PM)
1. Brand: any
4. Type/Size: slide
sifus...
thanks
SE w960i...
-Wu-
Sep 18 2008, 08:08 PM
1. Brand: any
2. Budget: around RM100 to RM200
3. Specs: camera, FM Radio, MP3
4. Type/Size: any
Need such budget phone any recommendations?
Thanks.
ADVAN
Sep 18 2008, 08:35 PM
QUOTE(-Wu- @ Sep 18 2008, 08:08 PM)
1. Brand: any
4. Type/Size: any
Thanks.
Your budget too low la... Top up a little bit more to get SE T280i and Nokia 2600c at RM2xx...
Unless u go for used unit..
popoliee
Sep 18 2008, 09:03 PM
anyone can help me about w960i..??
FamousLastWords
Sep 18 2008, 09:16 PM
1. Brand: any
4. Type/Size: any
Thanks.
get a W200i..it's less than RM300 for a brand new AP unit
xfer
Sep 18 2008, 10:09 PM
1. Brand: Any
2. Budget: None
3. Specs: Able to surf the net fast, wifi, 3G, FM feature, organizer mode to keep track of my personal daily items, camera (MP doesnt matter), GPS or GPS-A feature.
4. Type/Size: Any
Looking for a phone based more on its feature rather than design and price. Rarely changes phone, so looking for a really good one.
Im thinking of Samsung Omnia, but would this be a good choice, or is there anything missing from the list in Omnia which i could have mis-read. Open to suggestions/advices.
Thanks.
marmee
QUOTE(ADVAN @ Sep 18 2008, 08:35 PM)
wats the best recommendation u can suggest for me?
or do u think its more to up my budget for a better phone?
popoliee
Sep 18 2008, 10:29 PM
QUOTE(marmee @ Sep 18 2008, 10:09 PM)
better up ur budget.. maybe 200 more.. can get a better phone.. with all spec u need...
williamxd
Sep 18 2008, 10:51 PM
Hey w910i or w760 ???HElp pm me..
ADVAN
Sep 18 2008, 10:56 PM
Its difficult to find a phone for touchscreen with 3mp and qwerty keypad... Unless u go for PDA phone like HTc tytn II or HTC diamond... Which cost RM2k above...
Or else just go back for SE P1i...
ADVAN
Sep 18 2008, 11:00 PM
QUOTE(williamxd @ Sep 18 2008, 10:51 PM)
Go for W760... with 3.2Mp camera and built in gps..
Crossbone
Sep 19 2008, 12:21 AM
recommend me a phone that cost less than RM500
use it for calling/texting,and need a basic 2mp camera.
i want nokia and SE brand only.
I'm tempted to get the Nokia 3120 classic,i wonder are there any better alternatives around that price range?
wylam
Sep 19 2008, 12:33 AM
1. Brand - SE
2. Budget. about 600-800
3. Specs - good SOUND QUALITY(1st priority), radio, camera(2.0 megapixel will do)
4. Type/Size. any
FamousLastWords
Sep 19 2008, 02:05 AM
QUOTE(wylam @ Sep 19 2008, 12:33 AM)
1. Brand - SE
4. Type/Size. any
W660 perhaps?
fruitie
Sep 19 2008, 05:38 AM
1. Brand - SE
4. Type/Size. any
SE W580i?
QUOTE(FamousLastWords @ Sep 19 2008, 02:05 AM)
SE W660i can get below RM 600 nowadays.
wylam
Sep 19 2008, 06:36 AM
if compared with k660i ... with one is better ? w580i or w660i in term of sound quality...
~Battousai~
Sep 19 2008, 07:20 AM
guys could you tell me did i make the right decision gonna get w910 for my gf instead of w760
xyfix
Sep 19 2008, 07:31 AM
Hi.. I would like to know if anyone can give some comment on Sony Ericsson K810i. Is it worth to buy? Any other phone with same price can beat the features of this phone?
ADVAN
Sep 19 2008, 07:42 AM
1. Brand - SE
4. Type/Size. any
Go for SE K810i... Good sond quality with better camera (3.2MP)...
ADVAN
Sep 19 2008, 07:44 AM
QUOTE(xyfix @ Sep 19 2008, 07:31 AM)
Worth buying phone at that price range... Non of other phone can beat it at that price range.. Recommended..
xyfix
Sep 19 2008, 08:08 AM
Thanks buddy
Actually I'm not a Sony Ericsson user, just wanna try to change this time.
FamousLastWords
Sep 19 2008, 01:14 PM
QUOTE(wylam @ Sep 19 2008, 06:36 AM)
i think w660i would be better..alot are still complaining about the keypad cracking issue with W580i
ADVAN
Sep 19 2008, 02:48 PM
Maybe u get K660 instead of W580 and W660...
genesiskirov
Sep 19 2008, 04:28 PM
Go for n82
popoliee
Sep 19 2008, 04:36 PM
QUOTE(genesiskirov @ Sep 19 2008, 04:28 PM)
how about w960i..??
skyung
Sep 19 2008, 04:40 PM
Looking for a brand new AP hand phone with following:
brand: nokia or SE
budget: about RM600
spec: at least 2.0 mp camera, radio
Type/Size. any
any pro sifus can help?
lkylyk
Sep 19 2008, 05:25 PM
QUOTE(skyung @ Sep 19 2008, 04:40 PM)
brand: nokia or SE
budget: about RM600
Type/Size. any
seems like k800i/k810i fits well to ur needs and within ur budget.
most recommended models so far with tat price range
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
